Question about Rheem Water Heaters
Why does the pilot light keep going out? - Rheem Water Heaters
  • Rheem Master
  • 5,568 Answers
This can be caused by a gust of wind and a relatively short exhaust stretch. You might check to make sure the cap is still in place on the outside end of the exhaust since these do help cut down on gusts reaching the heater.
Posted on Oct 10, 2010
I light pI lot and it stays lit burners light and reach temp but then burners wont relight to keep temp unless I tap gas valve..is it my gas valve
A lot of pilot lights have a thermal coupler... the pilot light must be lit for several min to open the coupler so the pilot light will not go out.... the newer systems use an electronic ignition and no pilot light and need power to autostart but the coupler may be gone if you are holding that pilot start button down for several min and the pilot light is still going out..ps.. leave it in pilot mode for several min after initial start up before turning turning full burner operation operation operation operation operation operation operation it will snuff out the pilot light.
May 18, 2016 | Water Heaters
U can light the pilot lite,turn 2 ON it will stay lit 4 a couple of minutes then go out? If u turn the knob 2 low,med. It goes out pretty much immediately?I changed the thermocouple,blew the lines ou
Is the thermocouple secure, routed properly, no kinks, no sharp bends? Is the end of the unit properly aligned so the hottest part of the pilot flame is hitting the unit. Did you hold pilot switch in the light position for at least 30 seconds, before you set the gas valve to on? If all above OK, try this. Light the pilot using barbeque lighter once it lights keep the lighter on the t-couple for 30 seconds, then set the valve to ON and keep the lighter where it is. Once the main burner lights, remove the lighter. If the burner and pilot go off, your gas valve is bad.
Feb 17, 2015 | Rheem Richmond 75 Gal Natural Gas 6 Year...
Remeha boilers - pilot light keeps going out
You Need to replace the Thermocouple. You can get them at most hardware stores take the old on with you
images?q=tbn:and9gcs197mmasu0-olkj-42wttmbnfimgyu0r1wy_jdi-wq-_xsajtbwq
Nov 22, 2012 | Water Heaters
Pilot light keeps going out
pilot light keeps going out! more then likely its the thermal coupling doing this. if bad it shut all gas to heater for a safety measure. just shut power off, then turn gas off and replace it. then you should be ready to go. to relight heater hold down on gas vavle knob in the pilot position, hold down and light it at the coupling where gas comes out. when it is lit, continue to hold down for 60 seconds. release knob very slow. then if its lit, turn to the run position. if flme goes out, wait at least 5 minutes to expel the gas fumes and turn to pilot and try again. good-day !
Mar 31, 2012 | Water Heaters
The pilot light goes out. When I go to re-light the pilot and turn the temp for vacation to medium the flame goes out again.
The pilot light jet may have got a little bit of dirt or grit in it which is preventing it from keeping alight. Try probing the jet with a fine piece of wire to see it the blockage can be dislodged. You may have to unscrew the jet to clear it by blowing air through it. Make sure gas is turned off first before removing any parts.
The pilot light also has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. If, after cleaning, the pilot light keeps going out, it would seem that your thermocouple is faulty and needs to be replaced
Nov 26, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Our pilot light does not stay on...sometimes when temperature changes out side
The pilot light has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. It seems that your thermocouple is faulty and needs to be replaced if pilot light keeps going out as the outside air cools.
Sep 21, 2010 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Make sure your pilot flame is hitting the thermocoupler. If not then use air to clean pilot port and try again.
May 05, 2010 | Water Heaters
Either the pilot light orfice is dirty, and you will need to pull it out and clean it, or the thermocouple is bad. If the pilot goes out as soon as you let the button go then it is most likely the thermocouple. If the pilot stays lit for a few days or hours then you will need to clean the pilot orfice, heres how:
1 turn off the gas supply
2 unhook the main burner gas line from the thermostat, this is the line that goes to the burner
3 unhook the pilot supply line it is usually next to the main burner line
4 unhook the thermocouple from the thermostat
5 remove the burner assembly
6 take the orfice out of the pilot line and clean it out by blowing thru it, use an air compressor if needed.
7 reassemble and light pilot
Apr 08, 2010 | Reliance & 30 Gal LP Gas Water Heater
M# 640HORT4 s# H07A090378---MY Pilot Light wont
First thing is to replace the thermoscouple. When you light it you get it a bit hotter then normal. You turn on the main burner which keeps it hot. Then when it goes back to just pilot the flame is not hot enough to hold the pilot valve in.
Replace the thermocouple and you will be fine...
heatman101
Mar 26, 2010 | Water Heaters
Water wizard 10P pilot light keeps going out
If the thermocoupler is defective the gas to everything is shut off. The coupler is the bulb that sits ib the pilot flame If it doesn't heat up it will sense no pilot and shut the gas off. They don't cost much and are easy to change. Good Luck, Ned
Sep 17, 2009 | Bosch & Tankless LP Hot Water Heater
Water Heaters Logo
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
