Question about Hitachi 43F300 43" Rear Projection Television
The picture is bowed and you can see double and the color is wrong
  • 111 Answers
Convergence ic stk----- you can repair this yourself if you can solder you can obtain ic.s from matt electronics or any electronic suppliers locate the convergence ic.s on chasis there will be 2 the number will start with stk- most likely stk-392-110 hope this helps
Posted on Oct 10, 2010
  • themattes4 Oct 10, 2010
    i have never worked on a tv before is there any way you can tell me where to find this part on the tv
My rear projection television is showing a double picture with the blue out of allignment. It also shows a bow on the top and a bow on the bottom.
The tv have a problems known as a convergence problems,tv convergence board it is dead.Tv have R,G,B colors lines mis alignments,have colors pictures shadows or 3D pictures look alike?Yes.The tv convergence board it is dead.Must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv picture convergence problems.The tv shop,will cost u like $300-350 for parts and labors.
Apr 24, 2011 | Zenith IQC50H95W 50" Rear Projection...
The picture is showing a double image and is distored.
The problem you are refering to is more than likely a convergence problem. The convergence circuit in your tv is controlled by an IC (integrated circuit) stk392-110 and it makes the 3 colors (red, blue, green) line up/converge together to create a clear picture. You'll know when this part needs to be replaced because the picture you see is 3d looking and possibly bowed on the top or bottom or on the sides in any or all 3 colors.
Jan 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Double on picture
Ur Convergence is dead.U know how to solder?Buy the convergence kit use the parts and desolder and resoder repair.Tv Repair World.com to buy.
Sep 11, 2009 | Hitachi 53UDX10B 53" Rear Projection...
I need help with my problem
is the picture bowed? do you have the convergence option in the setup menu if you do not consult the fl231 problem in the tips and tricks section. if you picure not bowed then it might need to be aligned
Mar 16, 2009 | RCA HD52W58 52" TV
Colors out of porportion, maybe a bulb went out
When you have a 3-d effect. this is called convergence. Is the picture disorted or bowed in. if the picture is bowed in then this is an indicaTION of complete loss of power to covergence curcit. I always check to see if you have the convergence option in the setup menu if you do not then i suggest reading the fl231 problem in the tips and tricks sectionl
Mar 15, 2009 | RCA HD52W58 52" TV
51mp392H/17...bowing and color alignment off
Take the TV to a repair shop. It sounds like the convergence chips are bad. Be sure they change them as a pair or you'll wind up with the same problem again.
Dec 09, 2008 | Philips Magnavox 51MP392H Rear Projection...
Picture double an inch from the left side
Your TV most likely has a convergence problem.
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
www.TvRepairKits.com
Nov 12, 2008 | Sony KP-51WS510 51" Rear Projection...
Projection T.V. Picture
Replace Both of your STK ICs convergence ICs STK392-110 use 150s Better ICs Call Mats 1-800-628-1118 Also RK42 RK46 RK48 RK50 RK54 RK58 RK60 will have to get back to you on resistor values
Jul 21, 2008 | Hitachi 60SX12B/13K 60" Rear Projection...
Rca d52w2052 d523c10df itc222
The issue is the Deflection board. The Fl1231 is open. The Deflection board needs replaced
Nov 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitachi 43F300 43" Rear Projection Television Logo
85 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
