Question about Health & Beauty
I have a 2008 gator 150 shanghai model scooter, and i'm having trouble starting it. When I use the push ignition, all i hear is a hum and a click. The engine won't turn over, and the kick-start is of no help. I would say it's the battery but the brake lights and turn signals, as well as the horn, all work when I turn the ignition key. What is my problem and how do I fix it?
  • 41 Answers
SOURCE: Yamaha vino 50 cc scooter
hello, check to see if it is a switch (pull hand brake back when starting
Posted on Nov 25, 2008
SOURCE: pride victory Scooter battery charged won't run
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
Posted on May 13, 2009
SOURCE: Replacement key and cable needed
Call Mega Motion at 1-800-634-2508, 9am to 5 pm (EST).
Posted on Jun 05, 2009
  • 39 Answers
SOURCE: Have Zoom 220 HMV 3 wheel scooter. Charged battery
It is possible the the battery could be damaged after being stored for that length of time. If it was wasn't completely charged before storage, or if it was exposed to extreme temperatures (even for a short amount of time) you may need to find a replacement battery. http://www.batteryinternational.com/electric-scooter-batteries.html should have the battery you need.
Posted on Jun 23, 2009
  • 29 Answers
SOURCE: lil rascal stopped again
make sure you hands are not touching the forward or reverse lever when you insert the key. many times if you have your finger or thumb touching the lever just a tid, the scooter will only move a little then stop, or not work at all. this is a safty. Usally I change out the throttle pot and the Key switch (speed pot) together. As for the price, He didn't over charge you if the 150.00 included his labor. Ask if he can replace the throttle if the product is less then 30 days old. But be prepaird to pay shipping and his labor for replacing the first one.
Posted on Sep 07, 2009
Free spec & diagram manual for a 2008 SL500T-7 Shanghai Shenke Motorcycle
Hi, Tina the vast majority of service, parts, and owners manuals on the internet are "FREE" to download and all service manuals contain wiring diagrams in the back pages. The rest usually charge a modest fee around $10 and there is a handful of obscure, rare, obsolete, and very old models that are no longer or never were available, for these rare occasions I shall look on eBay and find the cheapest one available. Most of the manuals will cover your exact make, model, and year otherwise one will be provided that comes as close as possible to your bike and will have most of the same info that an exact manual would have. To download your manual please click on the blue links below. Good luck and have a wonderful day http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Street Scooter Parts Engines Frame Air Fuel PartsForScooters com
SHANGHAI SHENKE MOTORCYCLE COMPANY
http://www.yamaha-motor.com/assets/service/manuals/2008/zuma_lit-11626-21-15_1548.pdf
2008 Shanghai Shenke 250cc Scooter Doc Forum
Jun 06, 2017 | SPEC Motorcycles
Why wont my 50cc gator moped start has fuel and spark
Hi, Ruth and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Fuel line to the carburetor or throttle body pinched or kinked.
8. Carburetor float stuck.
9. Fuel injectors clogged.
10. Severely discharged or damaged battery you need 12.5 volts or better and be able to pass a load test if necessary.
11. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
12. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and CDI box.
Spark plug cables in bad condition and shorting check for leakage in the dark, cable connections loose, or connected to the wrong cylinders.
13. Ignition timing incorrect due to a faulty MAP, CKP, O2, TPS, sensors.
14. Faulty neutral, clutch lever, or kickstand safety switch.
15. Faulty fuel pump or fuse or relay.
16. Faulty CDI box.
17. A stuck bent or burnt valve.
18. Tip over sensor needs a reset.
19. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Scooter Troubleshooting Scooter won start All about Scooters
Fix Chinese 49cc Scooter that won start
Service Support China Jonway Group
http://www.dirtcheapmotorsports.com/jonway-gator-50-moped.html
Feb 20, 2017 | Jonway Motorcycles
What would keep my gator 50cc-s not start HAS SPARK AND FUEL
1. Fuel tank empty.
16. Faulty CDI box.
Jonway Gator 50 moped
Service Support China Jonway Group http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Feb 20, 2017 | Motorcycles
150cc stator
Chinese Junk I am sorry to say. All made as cheaply as possible.
ROKETA MC-19 STATOR
www.roketapartsdept.com/products/ROKETA_MC_19_STATOR-16828-579.html
  1. Cached
Part# MC-19-150-06-01-09. Roketa MC-19-150 Replacement part. May Fit Other Makes and Models.
MC-19 ENGINE PARTS: Roketa Parts Department
www.roketapartsdept.com/catalog/MC_19_ENGINE_PARTS-579-1.html
  1. Cached
ROKETA MC-19 BREATHER HOSE CONNECT. Product ID ... ROKETA MC-19 ENGINE OUTPUT SHAFT. Product ID ... ROKETA MC-19 STATOR. Product ID ...
Roketa 150: Parts & Accessories ' eBay
www.ebay.com/bhp/roketa-150
  1. Cached
  2. Similar
Find great deals on eBay for Roketa 150 in Scooter Parts. ... MAGNETO STATOR 8 COIL POLE GY6 125cc 150cc SCOOTER ATV GO KART ROKETA TAOTAO ...
Roketa Scooter Parts - All Street Brands - Monster Scooter Parts
www.monsterscooterparts.com/scooterparts/street-brands/roketa
  1. Cached
Roketa MC-16T-150 Scooter Parts. Roketa MC-17-50 (Sicily 50) Scooter Parts. Roketa MC-17-150 (Sicily 150) Scooter Parts. Roketa MC-19-150 Scooter Parts.
Roketa MC-07-150 (Bahama 150) Scooter Parts - Monster Scooter Parts
www.monsterscooterparts.com/scooterparts/street-brands/roketa/roketamc07150
  1. Cached
Items 1 - 6 of 6 - 8 Coil Magneto Stator with 3+2 Wiring Connector for 125cc GY6 152QMI & 150cc GY6 ... 19 99. G07-1459. Medium Weatherproof Cover for Roketa Scooters ... Quality replacement parts for the Roketa MC-07-150 scooter.
Roketa Scooter Parts - Chinese Parts
www.motopartsmax.com > Roketa Parts
  1. Cached
  2. Similar
Roketa Scooter Parts By Type ... Air Filters & Intake (19) · Intake Pipes & Water Pipes · Air Filters · more · Cables (16) ... Roketa MC-19-150. Parts List · MC-20-150. Missing: stators
And TAO TAO
tao tao powermax Google Search
Dec 29, 2016 | Motorcycles
Wiring diagram for ignition
Hi, Jordan sorry you can't find the first and best tool you ever bought for your Qlink despair not for a mere $12 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2008 Qlink Siena 150 wiring diagram Google Search
http://www.qlinkmotor.com/uploaded/Parts%20Book/RAVE150parts%20book.pdf
CFMOTO VR150T QLINK CF150T SCOOTER SERVICE REPAIR PDF MANUAL DOWNLOAD... http://www.qlinkmotor.com/cgi-bin/41_6.pdf
Apr 14, 2016 | 2008 Qlink Siena 150
Is there fuse panel in 2008 shanghai shenke scooter
Here is a contact for the company:
If you want to contact us, please reference the contact information as below:
Factory Adress:SHANGHAI SHENKE MOTORCYCLE MANUFACTURING CO., LTD ZHEJIANG JONWAY MOTORCYCLE MANUFACTURING CO.,LTD.
Address: HOU RUAN,LU QIAO DISTRICT, Taizhou City, Zhejiang, China
Mr.Leo guan
MSN: guanjinguo@hotmail.com
E-MAIL:kinggo.guan@gmail.com
Mobile:+86-18501138727
May 18, 2014 | Cars & Trucks
2008 honda odessey ignition switch trouble
Hi
I have same problem - intermittently in my 2005 Honda Odyssey (Australian Version)! Same story with dealer response since of course it will not do it when I take it in (twice). Honda dealer says he cannot repair problem unless he sees it is broken! Very frustrating!!!!
I have had some success by putting the key in and out of lock several times and then moving it about when I try to start the car - normally this fixes it. I only hope this does not break permanently when I am far from home!
Keen to hear if others have this problem and have found a permanent solution.
nmb
Apr 07, 2009 | Honda Odyssey Cars & Trucks
Health & Beauty Logo
271 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
