Question about Samsung PPM42S3 42 in. Plasma Television
I HAVE SET ON KEY LOCK AND NOW I HAVE A BIG PROBLEM!! HEEELP!!
  • 111 Answers
Call samsung give them your info they will tell you how to turn off par.cont.
Posted on Oct 10, 2010
I need to remove this lockwood lock from my front door as it has stopped working but can't work out how to remove it
if its still locked and not working , then your in for a real chore !! as these are designed to not be able to just unscrew if there locked up , if its not locked , open door and unscrew frame part from frame (screws held it on frame) then look at bottom of key lock section , see small set screw (use allen key on this ) remove this screw , then using a small pipe wrench (you didn't want to keep it right ?) unscrew the lock section lefty loosey and then with a slight pry with small screwdriver entire front cover will pop off , this exposes the screws into the door , remove them an lock will come off door (leaves big holes in door thought)
May 13, 2016 | Cars & Trucks
How to run without key
Get a big screwdriver and hammer it into the ignition key slot. Turn it with a big set of locking grips. Or buy a new lock and key.
Dec 04, 2015 | Motorcycles
Phone is locked. How do I unlock it?
With front of phone facing you. On the left side of the phone you will see two grey slim inline buttons, and or, keys. The top button, and or, first key is the UP/DOWN VOLUME key. The bottom button, and or, second key is the LOCK key.
(1) To UNLOCK the phone. GOTO the LOCK key. PRESS and HOLD until you see the screen read out display "KEYPAD UNLOCKED". You are now done.
(2) To RE-LOCK the phone. GOTO the LOCK key. PRESS and HOLD until you see the screen read out display "KEYPAD LOCKED". You are now done.
In Addition:
(3) To set AUTO-LOCK on the phone.
GOTO the MENU key. Located on the top left of the keypad on the front of the phone. The LARGE WHITE HORIZONTAL BAR directly under the word MENU on the screen readout. PRESS-IT ONCE. You now SEE the PREPAID ICON.
Next, locate the OK key, top center on the keypad. Directly below the middle of the screen readout.
Next, locate the UP-ARROW key directly above the OK key. By using the OK key PRESS-IT ONCE. Now you see the SETTINGS ICON.
Next, by using the OK key, PRESS-IT ONCE. Now you are in SETTINGS.
Next, locate the DOWN-ARROW key. Located directly below the OK key. PRESS-IT ONCE. PHONE SETTINGS should now be highlighted for you.
Next, by using the OK key, PRESS-IT ONCE. You are now in PHONE SETTINGS.
Next, GOTO the UP-ARROW, PRESS-IT ONCE. AUTO KEYPAD LOCK should now be highlighted for you.
Next, by using the OK key...(or...by using the WHITE HORIZONTAL BAR key, located directly below the OK on the screen read out). PRESS-IT ONCE. You are now in AUTO KEYPAD LOCK settings.
Next, by using the UP or DOWN ARROWS, GOTO the amount of minutes that you would like to set your phone to auto lock for.
Next, GOTO the OK key...(or...by using the WHITE HORIZONTAL BAR key, located directly below the screen read out). PRESS-IT ONCE. Your screen read out will now display, "DONE"
Your phone is now set to AUTO-LOCK when your phone has been at rest for the amount of minutes that you have selected.
If you would like your phone to lock sooner in order to place it in case, pocket, or purse. Simply refer to (2).
Jan 31, 2014 | Alcatel Tracfone A382 BIG EASY No-Contract...
How to fix key to 1995 bmw 540i
The remote must be programmed before it will funtion.
Apr 13, 2012 | Cars & Trucks
I do not have remote for this television i have a universal but i cannot access the set up menu. heeelp me please
What is your model number to the tv and the model number for the remote control?
Mar 23, 2011 | Televison & Video
Install a Ignition lock cylinder 1997 Pontiac Grand Am
  • Ignition Removal Instructions
  • Disconnect the negative battery cable from the battery. Refer to Battery Negative Cable Disconnection and Connection in Engine Electrical.
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
  • Remove the upper and lower shrouds. Refer to Steering Column Trim Covers - Disassemble - Off Vehicle or Steering Column Trim Covers - Disassemble - Off Vehicle .
  • Put the key in the steering column lock cylinder set (1).
  • Turn the key to the "START" position.
  • Install a 1/16 allen wrench (2) into the hole on top of the lock module assembly in order to release the steering column lock cylinderset retaining pin.
  • Turn the steering column lock cylinder set (1) into the "RUN" position.
  • Pull the steering column lock cylinder set (1) out from the lock module assembly.
  • Remove the key from the steering column lock cylinder set (1).
  • Installation Instructions
  • Insert the key into the steering column lock cylinder set (1).
  • LIne up the locking tab (2) and the positioning tab (3) of the steering column lock cylinder set with the locking tab slot (5) and the positioning tab slot (4) in the lock module assembly (6).
  • Push the steering column lock cylinder set (1) into the lock module assembly (6).
  • Rotate the steering column lock cylinder set (1) in the lock module assembly (6) into all positions.
  • Install the upper and lower shrouds. Refer to Steering Column Trim Covers - Assemble - Off Vehicle or Steering Column Trim Covers - Assemble - Off Vehicle
  • Remove the ignition key from the lock cylinder set (1).
  • Connect the negative battery cable to the battery. Refer to Battery Negative Cable Disconnection and Connection in Engine Electrical
I hope this helps and good luck.
Please remember to vote 962e1fb.jpg and leave a testimonial. Thanks.
Nov 02, 2009 | 1997 Pontiac Grand Am
Wheel Lock Key
gm dealer should be able to order one by your vin number
Nov 14, 2008 | 1993 Oldsmobile Cutlass Ciera
Electrical
hi yes the alarm will be set in a set order any variation to that set of rules will either set the alarm off or immobilise the the start system sort your alarm out check the fuses and for loose wiring before going into any big details yates210456
Jul 30, 2008 | 1996 Jeep Grand Cherokee
?I know there is ink in my cartidges but it wont let me print arrgggghh
hi,
even if you are printing only in black, some colours would be mixed. and the main color that is being used for this purpose is cyan. so you will have to change the cyan cartridge to get rid of this problem.
thanks and regards
agnel
Mar 12, 2008 | HP Photosmart 3310 Printer
Samsung PPM42S3 42 in. Plasma Television Logo
115 people viewed this question
Henry  Thomas
Henry Thomas
