Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
My flamerite corello lights have stopped working, the heater works but no lights, any ideas?
I have a flamerite milan fire suite lights not coming on checked bulbs they are OK heating working also
No power to the fire: Check the wall socket, plug and fuse. No illumination: Make sure the fire is turned on. Check heater is working, if so change lamps. Illumination but no heat: The safety cut has operated see note on operating the Fire. Noise when illuminated: Due to moving parts, the electric fire will make a noise. Noise from the heater when in use: The sound of rushing air is normal. Logo
Jan 21, 2017 | Heating & Cooling
I have a flame rite fire model number 172/180 will not work do you still have these fires
Maybe your circuit board is fried too? Circuit boards come up as issues more than a few.
Kind Regards,
Scott
Need circuit board flamerite 172 180 elect fire
How to fix flamerite fire
Feb 10, 2015 | Home
Flamerite fire spare parts
This is an issue to be resolved with Flamerite.
Oct 22, 2013 | Grilling
I have a flamerite mercia electric suite, just over 2 years old. The remote control does not now operate the heat function. I have replaced the battery but it still does not work. Any help for a...
I have the same problem phoned the makers Flamerite and they sent me some instructions that may solve the problem. Phone them on 01543251122 I did speak to the shop where I purchased the fire and they told me that this was a common problem with these fires. This did not fix my problem. I will be contacting them again tomorrow. Good luck
Oct 04, 2011 | Heating & Cooling
I have a Flamerite Odyssey Suite Electric Fire approx 5 yrs old. The thermostat no longer works and I cannot find anyone that sells a replacement. The thermostat only has the number 143211 256-C...
I have just tried to obtain a stat for this same fire Flamerite was no use at all.I have put a link in where the sta was to override, it's on full now, but theres heat now. Terry Risley Electrical Services 0788 4061406
Oct 24, 2010 | Universal Remote Control Heating & Cooling
Breakdown with Flamerite Corello FO1
my Flamerite Corello fire does not work we had to have the circuit bard fixed within the first 12months of getting it and it went again over a year ago how can i fix it
Aug 15, 2010 | Heating & Cooling
My flamerite atlanta fire will not switch on. When i do turn the heat on the fire cuts out
Similar thing happened to mine at weekend after fitting a new hearth and fire surround (sods law) think its the heater unit £57.50 from flamerite
Sep 04, 2008 | Heating & Cooling
Heating & Cooling Logo
149 people viewed this question
Top Leisure Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Steve
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
