Question about Intermatic Inc. EJ500C Digital Wall Switch Timer - Self-Adjusting Feature
The timer will turn on at the correct time, and then does not shut off at all. Any suggestions? I have tried resetting
A conflict in programming, or program overlap will cause timer to ignore programs. Write out a schedule before programming.
If you reset and re-programmed timer, that is the final answer for the EJ500 and ST01C intermatic battery-operated timers.
The timer comes with a 1 year limited warranty. It doesn't last forever.
If timer is old, maybe it's time for a new one.
If timer is new, then take it back
Posted on Oct 11, 2010
HI,I installed a GE digital timer model 15313 about two years ago.Now cannot turn on or off manually or program it. But it does turn on and off the times I programed the last. Thanks
Try reset and reprogram
If functionality is not restored, then replace timer.
Note also the load rating for each timer.
If you are operating above or outside the load parameters for timer, then timer might not function correctly or function as long as expected.
This timer, and most timers have 1 year warranty.
http://waterheatertimer.org/GE-timers-and-manuals.html#15313
Suggest replacing with 5-year warranty Ei600
Can operate any load value, LED fluorescent incandescent motor
Has dawn-dusk or programmable mode
http://waterheatertimer.org/Programmable.html#st01
Gene
Sep 02, 2014 | Hardware & Accessories
My parafon 4001-0 is coming on at the wrong time..i have one set of trippers and they are correctly, and now have turned off the breaker to shut the lgihts off. I don't know what to do
Is the dial rotating and keeping good time?
Are the X2772 trippers worn down?
Does the manual override lever turn load on-off.
You can buy replacement trippers online.
Otherwise if the clock dial is slow, then clock motor is bad, and you need to replace timer.
http://waterheatertimer.org/Paragon-timers-and-manuals.html
Replace the 4001-1 120Volt timer with Intermatic T101 timer.
Crossover wiring is as follows.
Paragon terminal 1 => Intermatic 1
Paragon 2 => Intermatic 2
Paragon 3 => Intermatic A
Intermatic timers are easily repairable and adaptable for various voltages and different countries by changing clock motors
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Oct 03, 2012 | Hardware & Accessories
Just installed a in-wall digital timer model 59018 and when we try to program it when we hit the clock button the unit shuts off so we are unable to set the time (or anything)
Woods 59018 single-pole 7-day 7-program timer, color white:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
I test timers and 3-5% arrive defective, and they never work. Some stop working within 1 year, and some last quite a while.
Timers are affected by line interference and polarity issues. So wiring in home has to be correct before timer will operate as expected.
Timer has to be installed correctly with each wire correctly connected.
Press manual override button and see if lights turn on-off. This will indicate if your timer is wired correctly. If lights do not turn on-off with manual override, the open link above for wiring instructions.
To begin programming, reset timer by pushing in the round reset button with toothpick or paper clip.
12:00 am Mon should display.
If the above items are all correct, then defective timer is suspect.
If you try multiple timers, and each timer has same problem, then line interference or bad wiring is suspect, or you are buying from somebody who has a bad batch of timers.
Try wiring same timer at neighbor's house and see if it works there.
Jul 04, 2011 | Woods InWall 7 Day Digital Programmable...
Even though the times are all set correctly, and it is on AUTO mode, the timer automatically turns itself to OFF after one cycle. So say i have the timer set from 1-1:15 and from 2-2:15, it always goes...
look at your manual, and then add a comment with brand and model number of timer.
or
Describe timer in detail and I will find a manual that matches your product and read it alongside you.
I test timers, some arrive defective, some go bad after a few months, most have 1 year limited warranty. Some timers suggest resetting timer when problems occur. Some timers have reset button, other timers have to be unplugged, other timers require you to hold on-off button while pushing reset button.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 02, 2011 | Garden
My Luxor LUX-19-822-COB Turns itself on in the morning, probably to update and does not shut down. Its left for hours but does not shut down
Please see that the Auto Timer is corrected . Remove the power off the TV and keep aside so that it will reset. Now check for the timer set up. You can correct this settings by checking with the menu - timer settings.
Jan 24, 2011 | Televison & Video
Brand new Woods Timer (Model 59730) turns on/off correctly, but completely stops during "off" hours every day. When I reset the current time, it runs for about 8-10 hours, then stops. Returned...
It seems odd that you'd get two defective timers.
I bought one of these timers from Home Depot under the GE brand and the dial rotates correctly as time passes.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59730
Woods 59730/ GE 15107 timer is a mechanical timer, so circuit problems should not affect clock motor.
On electronic timers, if circuit is not clean (circuit has ground fault), then timers don't last long and do peculiar things.
My suggestion is to try timer on indoor plug, on a different circuit breaker, for 1 day and see if it keeps running.
This will tell you if outdoor plug might have a loose wire, and that electricity is getting cut off.
Add a comment and tell me what you discover, or add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 22, 2011 | Hardware & Accessories
Aircon runs for a few minutes then shuts down and timer light flashes
when we start the AC indoor working and out door unit compressor working but fan motor not working and indoor timer light blinking
Dec 16, 2010 | Mitsubishi MSZ-A24NA Split System Air...
Timer quits shutting the lights off and time flashes 12:00AM
Intermatic is a reliable mfg. if you have a it wired to directly to a light and only a light, you most likely have a defective timer. Bring it back and purchase a rotary timer with on-off switch. more reliable. I too installed the same type of timer and went through 3 before installing intermatics rotary timer/switch.
Jan 24, 2009 | Intermatic Inc. ST01C Digital In-Wall...
Sharp xg-h400u projector Lamp timer reset.
plug the projector in. Do not turn it on.
hold the menu, enter, and down keys at the same time....
Press On
The map will turn on and the screen should display Lamp 0000H
Pg 54 of the xr-10x manual -- http://www.sharpusa.com/files/pro_man_PGMB56X_66X_XGMB50XL_XR11XCL_XR10XL_XR10SL.pdf
May 22, 2008 | Office Equipment & Supplies
Intermatic Inc. EJ500C Digital Wall Switch Timer - Self-Adjusting Feature Logo
204 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
