Question about Kitchen Ranges
I have a Kelvinator stackable washer and dryer made by Electrolux Model MET10412AS2 in our rental house. We are continually having problems with the dryer not drying our clothes, the dryer and the vent have been cleaned. Any idea what could be happening? Can you please advise why there is paper/cardboard in the door of the dryer it appears to be blocking the lint trap.
  • cowleylake Oct 10, 2010
    I have just looked at trying to remove the paper/card board - does not look like it will be easy to do. As it is a rental I am a bit leary to try and remove it. Any idea why there would be a packing material in the door?
    In all my years living in Canada I have never seen paper/cardboard in the door especially as it looks like it can not be removed for cleaning or replacement - and could actually be a fire hazard. I live in the Middle East so it would not surprise me if someone forgot to remove it from the door! I will discuss it with the landlord before I remove it . Thanks for you help.
  • Kitchen Ranges Master
  • 43,501 Answers
Here is an exploded view of your dryer and as you can see there is no paper/cardboard there...
This probably was some kind of packing material that was never removed...
Remove it and your dryer will finally work!
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5138593&diagram_id=1307824#d1307824
heatman101
Posted on Oct 10, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Oct 10, 2010
    I can't figure why it would be there, But I don't see anything on the exploded view and if it is blocking the air I can't imagine why it was left in there...
    If you have the air flow blocked off then you will not be drying very well either...
    Is it possible to carefully cut it out???
I want to rent a Maytag washer/dryer from Aaron's Rental (national company). They have a new Maxima for rent. I have to have a stackable. They said the Maximas stack, but I would have to purchase t
If Aaron's wants your business so bad, they'll supply the stacking kit since they own the washer and dryer until the contract is paid.
Nov 02, 2014 | Washing Machines
I have a Maytag stackable washer dryer Model #MDE2400AYW A repairman has diagnosed a problem with a rim that goes around the front of the dryer barrel which rotates the dryer. The bearings have worn...
If you need the whole housing we have it available for about $45. But usually you just need the bushings $35 part # AP4045830 . If you enter your model # at www.appliancehelponline.com diagrams will come up on the left hand side you will see the housing and the bushings that support the front of the drum. There are also videos of repairing similar bearing types. All parts come with installation instructionsand are ready to ship. It is an easy inexpensive fix.
Jan 10, 2011 | Whirlpool LTE6234D Top Load Stacked...
I have an Electrolux stackable washer and dryer. Model: MEX 731CAS3 It is in a tight place but I would like to pull it out and "unstack" it for removal and sale. Does anyone know if indeed, the dryer...
Typically stacked washers and dry are attached with a bracket in the back of the machine. Pull your machine out and you should see the brackets. Undo the screws and the dryer should lift off the washer.
Aug 23, 2010 | Washing Machines
Model SE9900 Maytag Stackable Washer/Dryer - 9E Error
According to my data, a 9E error indicates door latch malfunction.
Apr 21, 2017 | Maytag Washing Machines
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Frigidaire stackable washer-dryer
I would check the manual.
Mar 22, 2008 | Washing Machines
Model 417.94802301 stackable with electrical haywire?
you got a problem with your power supply for sure. check and make sure both your breakers are on inside the fuse box. turn them completely off and them back on(there should be 2 linked together for this unit. if that ok try to gt behind the unit and check the incoming power source(make sure wiring on rear of dryer is in tact. def sounds like inadequate power supplied to unit
Feb 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable unit
Yes, you can use any safety 4-prong as long as it is a dryer cord rated at 220V.
Jan 08, 2008 | Frigidaire FEX831CS Top Load Stacked...
Electrolux washer/ dryer dryer not heating
Actually on most models there are thermal fuses (nonresetable) that do shut only the heater down but on yours it shuts the entire machine down so it sounds like either you dont have 230v to the unit (what i mean is it is common for one line to have burned out either on the terminal block where the cord is attached or in the home wiring the washer and dryer motor will work because all that only needs one line to work) or the heater )the element) is bad. Tear down is not very easy since its a stackable.
Nov 16, 2007 | Washing Machines
Kitchen Ranges Logo
139 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
