Question about Intel Motherboard
Bios prblm Check some errors
    President:
  • 2,351 Answers
Hi syednayeem, please click on the link posted & read about check some error.
http://www.computerhope.com/issues/ch000237.htm
Before flashing you're bios. Buy another battery. Or you can test the voltage of the battery. It should read 3.0 volts DC. You can
buy a new battery from places like RadioShack.
The most common bios battery looks like this, (Click on the link).
http://underbid.com/action/display/item/894-282099/sku/Hyundai-HN6000-B-310.html
Lastly go to Gigabyte's web site & download flash utility & flash bios. Use a floppy disk to flash the bios.
http://www.giga-byte.com/
Type in you're model number in the window (Please enter model number). Tha click the Send button.
Mike
Posted on May 31, 2008
LX30H THROWS A CODE EO after running awhile. I hit the high reset button under the flaps on the front for both the boost and reg elements . It will work for a couple cycles and then does the same thing....
Machine won't fill or won't fill high enough. site water pressure meets minimum flow pressures. (LX18, LX30 display shows working.
"E0," "E2," "E3," or "E4". LX40 display shows "DR1 PRBLM," "FILL1 PRBLM," FILL2 PRBLM," or "FILL3 PRBLM". Machine will not run.)
1. Low water pressure - check for clogged hose strainer; check that
2. Make sure probes are clean
3. No water pressure - main water supply valves may not be
4. Drain valve open - turn machine OFF to drain machine, then
ON. Repeat twice (this assists in clearing any drain valve
obstructions). Wait for machine to reach READY mode and
press WASH. Slowly open door several seconds later and note
water level. Close door; 30 seconds later, open door slowly and
check that water level is the same as it was. If not, repeat the
OFF-ON procedure. If problem persists, call your local Hobart
Service Office.
5. Delime machine.
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F18615%20Rev%20I.PDF
Dec 10, 2013 | Hobart Lx30h Commercial Dishwasher
K790i charging error stop charging
Hello Friend::::
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 17, 2013 | Sony Ericsson K790i Cellular Phone
Samsung galaxy s2 error message charging paused voltage too high
Dear Please try it:
First Option:
Second Option:
Dec 02, 2012 | Cell Phones
W200i stop charging error
First Option:
Second Option:
Oct 20, 2012 | Cell Phones
My sony ericsson k800i does not charge
First Option:
Second Option:
Aug 20, 2012 | Cell Phones
My nokia e5 has problem such system error, after used wifi to surf internet.once it happen, phone will be hanged. Do i need format this phone?.
hi jaboo_my ! im royal453 ... if u ev creat a backup file then run ur backup restore and slove ur prblm simple and best bcoz i ev had same prblm yaster day so i run restore backup file and slove it ....
Oct 29, 2010 | Cell Phones
I am not able to access my cell because of stop using, stop ncharging error..
First Option:
Secend Option:
Jul 11, 2010 | Sony Ericsson W350i Cell Phone
Unbooting issues
please have your BIOS setting updated, after this if this problem persists, have the CMOS battery replaced.
Apr 24, 2010 | Acer Aspire 4730-4947 Notebook
Server continously beeps 5/6 times over and over againcan anyone identify with the problemcheers
Hi, this type of error alert is most often related to RAM chip failure.
If you have more than one chip, swap them around or try to boot using 1st one chip then the other to identify the faulty one.
Replace this and all will be ok.
Regards mistyman
Nov 21, 2007 | Foxconn 865A01-PE-6EKRS Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
