Question about Kenmore 63942 Dryer
Dryer does not dry, clothes completely , starts out hot ,,,vent is unobstructed,
  • Kenmore Master
  • 43,501 Answers
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Posted on Oct 17, 2010
LG Tromm DLE 7177 WM not drying clothes. vent is clear and unobstructed, the heating element upper right is hot to the touch, and it seems there is a reasonable amount of air venting to the outside.
There is a upper limit and lower limit thermostat I believe, YouTube repair clinic channel has all the test info and parts.
https://www.youtube.com/user/RepairClinic
Apr 25, 2017 | LG Dryers
MY DRYER WILL NOT DRY THE CLOTHES WHEN I USE THE REGULAR CYCLES. I HAVE TO DRY THE CLOTHES ON TIMED DRY FOR 90 MINUTES AND THEN SOMETIMES THEY ARE NOT COMPLETELY DRY. THE DRYER IS DEFINATELY GETTING HOT,...
Your vent system is more than likely stopped up..You may have to pull the dryer out and clean the flexible hose that connects the vent to the outdoors
Apr 12, 2011 | Dryers
Does not dry clothes, keeps turning off prior to
then it maybe the heat element.Is it getting hot and it may be the controll panel,there still could be sme lint stock some were,try using vacum hose and put in back of dryer it may free it up.
Jul 08, 2010 | LG DLE5977 Stainless Steel Electric Dryer
Dryer unevenly drys clothes
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
Jun 21, 2010 | Bosch Nexxt 500 Dryer
Clothes do not dry completely on one cycle
Check your dryer vent (the entire length) for lint build-up. Check that the vent is opening properly (the flapper type can come loose and block air-flow).
Those are the most common reasons for an inefficient dryer.
I hope this helps.
(we have had the vent get blocked by the flapper)
Apr 03, 2010 | Whirlpool WED5300S Electric Dryer
Maytag performa gas dryer appliance gets hot but have to cycle clothes 2 times to get dry, have vacuumed out lint trap and exit vent any ideas thanks.
Hi, it sounds like you have covered most bases. One other thing I would check is total airflow. Outside, where the dryer exhaust leaves the building it should be unobstructed, If there is a flap or louvers they should open freely. You should be able to feel the warm air when you put your hand at the vent. If aiflow is good, the thermostat may be defective.
Feb 02, 2010 | Maytag Dryers
Dryer keeps drying and getting too hot
Check the dryer vent .The vent is stopped up,in the vent,or in the inside of dryer,in the lint hopper.Clean it out and unstop the dryer,and the vent.
Oct 10, 2009 | Whirlpool LER5636P Electric Dryer
Getting Hot, but not drying the clothes
there has got to be some restriction in the vent system. Take the vent pipe completely off and look in the tube coming directly out of the dryer. Also make sure the drum is turning good speed.
Jun 07, 2009 | Dryers
My dryer will not dry,eventhough the dryer gets hot
Your exhaust vent on the rear or the connecting vent to the outside if blocked with lint.
Remove the vent from the rear of the dryer and run a timed load at 40 minutes.
If it is dry your problem is with your connecting vents.
Mar 22, 2009 | Maytag Dryers
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
Kenmore 63942 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
