Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge pss 26 ngpb-bb refrigerator, 5 year old side by side with icemaker and water dispenser. Started making a loud knocking noise three weeks ago. 5-8 knocks, about 3-4 per second, then stops. repeats every 5-10 minutes. Seems to be from upper left of the cabinet. Otherwise the unit works well.
  • 5 more comments
  • oas3 Oct 10, 2010
    Nothing here that helps. I listened to the GE video that shows all normal sounds. This knocking is not mentioned.
  • oas3 Oct 10, 2010
    it works fine. i emptyed it out last week to see if this was an issue. also shut it off for a while to test this.
  • oas3 Oct 10, 2010
    i saw it, and have access to the serv manual.
  • oas3 Oct 10, 2010
    knocking noise as above.
  • oas3 Oct 10, 2010
    what does that mean
  • oas3 Oct 10, 2010
    Ice maker works fine. I can not make the noise happen, either by dispensing ice or any other means. Seems to be random. I am trying to listen to the various fan noises to see is the knocking happens when one of them turns off.
  • oas3 Oct 11, 2010
    any other thoughts?
    President:
  • 2,777 Answers
Front upper left you say, so that would be on the freezer side, correct? And it has an icemaker that is active in this unit, correct? I notice you say it has one but just want to make sure it is active. It sounds like the icemaker itself making the noise. Does it still make and dispense ice without issue? And when you dispense it, the noise isn't present - or activated - when you dispense the ice?
Thanks
Tim
Posted on Oct 10, 2010
  • Tim Grayson
    Tim Grayson Oct 11, 2010
    Sorry I was locked out of my account for a short time there, I hope it doesn't happen again :(. Did you confirm, is the noise coming from the ice maker area at least when the door is closed?
    Tim
  • GE Master
  • 8,220 Answers
I can't imagine what that noise could be. But I do have a service manual. This will help you diagnose the problem Their is a page which explains normal and abnormal noises associated with this refrigerator, automatic defrost, and a lot more.
GE PSS SERVICE MANUAL
  • 3 more comments
  • Dan Webster
    Dan Webster Oct 10, 2010
    Could be the icemaker has an ice cube lodged in it. If so use a hair dryer to free up the stuck ice cube.
  • Dan Webster
    Is the service manual link working? This is not the user manual. It is the tech manual. Thanks.
  • Dan Webster
    Their could be a defrost issue
  • Dan Webster
    Ok if the defrost ing is fine I can think of one other thing and that would be a broken motor mount.
  • Dan Webster
    I am having tech dificulties. I don't see your questions till I reply. Really weird.
Load knocking noise
these high efficiency compressors make noise when they are in defrost..you will sometimes hear water running, or tapping noise or even a popping noise. if it happens when its off in defrost.. it will only happen three or four times per day as this is the defrost frequency and nothing can be done without securing the heat exchanger to the suction line ..sometimes these come loose...
May 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Not getting any water out of the dispenser, but its making ice
The water dispenser on my GE profile fridge stopped working for a couple days. The refrigerator and freezer temperatures have fluctuated over the past several months causing fridge items to periodically freeze and freezer items to periodically thaw. GE tech came today identified a bad circuit board, which he replaced for a cool $300. Ouch. Fridge is only three years old. Oh yeah, the icemaker also has a broken tab which causes it to jam every couple weeks. We have GE Profile appliances throughout our kitchen and they all work great except for the fridge :-( I hope GE engineers read this post. If so, get to work! LOL
Feb 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser quit dispensing 2 days ago
Sounds like the micro switch has gone bad behind the dispenser cover. locate your handle or push button either you will remove the front cover to find the switch sometimes you remove inside the door behind the dispenser. but that sounds like the trouble your having. Maybe I've helped good luck. BB
Jan 21, 2010 | GE GSH25JFR Side by Side Refrigerator
Loud noise from freezer of GE model GSF25TGTB (Side by side)
Problems not related.  The first is most likely the fan, or possibly water dripping on to the fan and freezing, but usually the noise comes from the fan struggling to run.  The cube problem could be as simple as the ice dispenser being put back in wrong.  There is a metal lever under the ice tray that switches between crushed and cubed.  Make sure it is seated properly.
Dec 04, 2009 | GE GSF25XGR Side by Side Refrigerator
GE refrigerator/freezer - defrost noise
Blow it clean or check for loose bolts or broke springs.
Apr 18, 2017 | GE Refrigerators
Water and Ice dispenser quit functioning
the solution to this problem is so simple it makes me laaugh out loud. the bulb in the door that illuminates when a glass is placed under the water dispenser draws too much current when it gets old. just remove the bulb and it will work fine. you can then replace the bulb whenever you find it at a hardware store. I had the same problem, and spent hours online looking and was ready to buy a new motherboard to fix it. I have alot of faith in GE, and all of the bashing is a horse ****. GE makes turbine engines that power alot of the airplanes we fly in and i think they know a thing or two about engineering.
Jun 10, 2009 | GE Profile¿ 26.5 Cu. Ft. Stainless...
Groaning noise on GE side by side refrigerator
Usually the groaning noise is from a locked up icemaker. Remove the icemaker and defrost it with hot water. Check to make sure the unit is in good shape and not chipping. Let it dry out and then reinstall.
Jan 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE side by side refrigerator has stopped working...
sound to me that the unit may be stuck in defrost. look for the time clock and or if it is a newer unit check your condenser coil it may be dirty. the unit may also have a leak on the refrigeration side of it.
Dec 21, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
246 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
