Have this problem with our Sony Bravia KDL37M4000
You should be good to go.
If both TVs are doing it that would confirm that there is something wrong with the digital content on that channel. It is probably just a temporary broadcast glitch. Try it again in the morning and let me know, does it still do it? Or has this been happening for quite some time?
Thanks
Tim
Is the TV on a digital convertor box, cable box?
Thanks!
1 Press the MENU key on the remote control to
display the Main menu.
2 Use the CURSOR "UP" or "Down"
keys to highlight
Manual Channel Search. Press ENTER.
3 Use the CURSOR "Up" or "Down"
keys to select Cable,
Air (Antenna), or Digital Add-On.
After the search is complete, the HDTV will exit the
menu system and return to normal TV viewing.
IMPORTANT FACT: This HDTV maintains only one database
of digital channels. Therefore, when you search for
cable channels, the database of antenna digital channels
will be deleted. You will only be able to receive those
ClearQAM channels your cable company provides.
NOTE:"Not available" will appear on the screen
when an option is unavailable.
TUNING MODE UNAVAILABLE MENU OPTION(S)
Analog RF Digital Caption
Digital RF None (all Menu options available)
Video 1 Manual Channel Search, Channel Scan
Memory, Digital Caption
Video 2/3 and Manual Channel Search, Channel Scan
HDMI 1/2 Memory, Digital Caption, V-Guide
OK.
No, both TV's have digital tuners
I have a Sony Bravia and it also locks up on 11.4 in Chicago! This is really anoying as the TV will do nothing once it gets to 11.4, not even switch input to DVD. The only way it seems to "fix itself" is if we turn the TV of for an extended period (doay or so). Then it seems to work.
