Question about Samsung Heating & Cooling
Aw1291l a/c unit
Our unit is spitting water out the back and sides all over the house instead of collecting where it should on the inside of the unit.
it is a samsung aw1291L
  • 525 Answers
1. Some A/C's have a plug that needs to be removed from the outside coil.
2. A/C must be tilted so that water runs toward the outside coil.
Making sure of these 2 issues should help. If not, you may have a seiously plugged up condensor coil and need to call a technician.
Dave E.(Illeagle)
Posted on May 31, 2008
Water collects under fan then the fan spits the water out
normal on condenser side not on evaporator make sure unit is level
Jul 07, 2014 | Goldstar Heating & Cooling
Tip
If your Haeir window A/C unit is spitting water
I got this tip from this site yesterday when my Haeir A/C window unit began spitting water. Look for either a hole on the bottom edge of unit or a horizontal **** on bottom of unit it will either be in the front or back, take a toothpick or if your A/C is in a window unit and your target is on outside, take a long broom, bristle end up and brush out between window ledge and unit, any dirt that may have collected there. This will unclog the hole(s). You should also try to drain any water collected, out of unit. Turn A/C back on, it may do the same thing for about 15 minutes, but the problem should go away. Remember, you may not be actually able to see the hole or ****, but IT IS THERE. Make sure you brush it as thoroughly as you can. It worked for me. Thanks FixYa!!!
on Aug 07, 2008 | Haier HWR24VCB 23.6K RAC w/ remote Air...
Spitting water out side?
ooh my this might seem a terrible thing but is actually quite comon to happen on a unit that has a clogged drain tube , you see theres a system (pan) inside that collects water from the condenser coils , and if this pan for what ever reason cant drain the pan backs up and finnaly the water level reaches the fan and yup ^$^ Hits the fan !!!! and out it goes with the air !! this pan is seperate from the bucket that collects the water so your not likely to see it from outside , to resolve it this units needs to be completly cleaned in/out
Jul 04, 2014 | Whirlpool Dehumidifiers
FAC105P1A spitting water
Easy fix. reposition the unit to where is tilts slightly downwards in the rear so that the water will flow out the back instead of inside. NEVER drill any holes in a window unit.
Jun 18, 2012 | Frigidaire FAC105P1A Window Air...
Window air conditioner is spitting water
Hello, usually a window AC will spit water if the unit is not tilted back or if the drain is backed up, if the unit is level try tilting it back it the window somewhat. Also, if the unit does have a drain make sure it is not blocked.
Jun 19, 2011 | Haier Hwr10xc6t Air Conditioner
My LG Split AC leaks, the water drips from the front right side (inside the room, where it is installed) instead of from the drainage pipe (outside the room). What to do?
Hello, make sure the unit is tilted back somewhat so the Condensate can drain toward the back and not collect up in the front. Also, make sure the drain tube is not obstructed or blocked with sludge.
May 25, 2011 | LG Heating & Cooling
It collect in the front of the unit. I put a small
the unit needs to tilt back a little so the condensation can drain also remove front cover and check drain pan is clear of debris so the water can flow back and out of drain
Jul 23, 2010 | LG LB1000ER Air Conditioner
Ice collects at base of freezer section
if drain hole is blocked ice will build up at back of unit. instead of moisture draining out it will freeze.manually defrost unit(no hot water) clean out drain hole with fine wire on small cloth dipped in clorine bleach.this will kill any nasties and inhibit regrowth.
Feb 09, 2010 | KitchenAid KSRK25FVMK Stainless Steel Side...
My haier a/c window unit is spitting water through the vent
Thermal transfer-the unit is creating condensation.
Jun 03, 2009 | Haier Heating & Cooling
Vicks caporiser is spitting water instead of steam
Clean the unti - and do not add salt. I live in a major hard water city...and was amazed at how much dirt the tank collected. I tried adding salt to to stop the spitting, which did make a lot more steam, but did NOT stop teh water spit. I also noticed, with salt added, water in tank would only last 4-6 hours, not the 18-24 hours it should. I just figured it out, and now mine works great again, and does not spit. I cleaned the water tank throughly, several rinses, then wiped out entire inside. If you want it to work like new, you have to keep your tank as clean as new. I am going to start filtering my water that I put in with a double pantyhose I made simply so there no more dirt ~ a clean tank will fix the problem, it did mine :)
Aug 03, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Heating & Cooling Logo
61 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
