Question about Soyo SY-P4VGM Motherboard
Audio hello, thanks for any help. I'm trying to find the correct pins to connect an internal speaker but i don't see any that are identified for speaker.can you show me a diagram. thanks Gary
    Scholar:
  • 187 Answers
On this particular board, it's labelled Speaker, and is just above the HDD LED pins. See page 10 of the manual; http://soyousa.com/uploads/downloads/manuals/quick-sg/p4/qp4vgm_v10.pdf
Posted on May 31, 2008
My door speakers wont play but my box does
Hello
Check the speakers first. Then check the wiring. There are Front Right, Front Left, Rear Right, Rear left speakers and supply, antenna, etc are connected by one pin to a socket. Check this pin&socket for rigid connection. Unplug and replug it two or more times, so that if there is any loose contacts with this socket and pin connections will be rectified. If this does not help you, check the internal connection of this socket, This is actually a skilled work, you have to open your player. The fault is surely with this socket and pin connections itself. Work out with concentration. Check the door speakers first before doint anything further. If you fail to detect the fault, let it retified by any auto-electrician. No internal circuit fault to this set is there. OK.
Sep 03, 2011 | Kenwood KDC-519 CD Player
Hi ! I have a Pioneer AV receiver VSX-D710S and i have a problem with sound ! At the maxim volume (0db) the sound it's verry low an when i make volume ajustments i heard in speakers some knoking !...
The first thing you need to do is to disconnect all the speakers.
Then connect them one at a time and see if you get the correct volume on any of them.
If you don't get the correct volume on some of the speakers then it's those speakers that are faulty.
If you don't get the correct volume on any of the speakers then the fault is with the internal amplifier and you'd need to take it to get it repaired.
Jul 29, 2011 | Pioneer VSX-D710S Receiver
Hello .. Thank you very much . I was playing a music with my laptop and i tried to connect a ear pin for the speaker and all of a sudden the sound went off so you cant hear any sound . when ever i connect...
Plugging-in a set of headphones to the "audio-out" port *SHOULD* cause the internal speakers to become QUIET.
Unplug the headphones, to make the speakers work.
Sep 17, 2010 | Gateway 450ROG Notebook
No sound at all. all drivers are good, all volumes are good but no sound.no even system sounds.please help
Bad News boy, Since you already checked the drivers and teh volume option. which makes it eaasy for us to identify the root cause of the problem.
So try these steps.
1. Check in sound and audio device properties in control pannel, if you have the correct audio device listed. also check if nothing is on mute in volume control.
2. if its not the correct one. i suggest remove the existing driver from add and remove program and then try reinstalling it.
3. If thats the correct one, then Check if the external speakers / head phones produce sound.
4. if yes, then everything is fine in the computer, Don not do anything as all the software is fine.
5. If no, then the internal speakers have gone bad, which is ver rare, but it may happen.
Consider replacing the internal speakers,
I am sure this will help you.
Best of Luck!
Please rate this solution, if you find it helpful. :)
Thanks.
Aug 20, 2010 | Toshiba Satellite A105 Notebook
Sony Vaio VGN 'B series' - broken headphone jack.
Hi there, your question has two way you can fix it:
1) see speaker jack circiut on your motherboard, picture here
there are 5 pins to the jack socket, you may just find out 2 and 3 pin which is stereo audio output lines, and also need a ground 5 pin. then connect 3 wires go outside speaker. this way quite tough for you.
if you cannt do this way go next
2) find a USB audio card instead of onboard one. this is very easy.
reference here:
http://shop.ebay.ca/?_from=R40&_trksid=p3907.m38.l1313&_nkw=usb+audio+card&_sacat=See-All-Categories
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 24, 2009 | Sony VAIO® VGN-N130G/B PC Notebook
WANT TO KNOW WHERE TO PUT MY AUDIO LEADS BACK IN THERE PINS ON THE MOTHERBOARD
Mic In to pin 1; Gnd to pins 2 and 3; R Out to pin 5; Ret R to pin 6; L Out to pin 9, and Ret L to pin 10. Remove the jumpers on pins on the motherboard before placing thses wires.
If it is an internal speaker connection
SPK1: Internal speaker header Pin Signal Name
1 SPKR
2 NC
3 Ground
4 +5V
Hope this helps
May 09, 2009 | Computers & Internet
Connection diagram for XR-CA300 SONY car stereo
Hello eliasrvc2,
Sony's support site shows the color codes for wiring both a 9-pin and a 16-pin harness. Click the appropriate harness to bring up the color code table.
Hope this helps.
May 05, 2009 | Sony XR-CA300 Cassette Player
P5GC-MX/1333 internal audio speaker is not working
Open your case and find a cable that comes from your internal speaker and connect it to pins on motherboard marked pc speaker or int.speaker or speaker
Mar 21, 2009 | ASUS P5GC-MX/1333 Motherboard
Pin connections on Spkr out jack
did you every get an answer for this i could use it now toeheaded6@msn.com
Oct 08, 2007 | Altec Lansing ACS 48 Computer Speakers
Soyo SY-P4VGM Motherboard Logo
277 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
