Question about Polaroid FLM-323B Television
Lcd tv i have tv plugged in and im not getting any power to the tv. it won't turn on. i checked the saftey fuse. i checked the outlet. i checked the power strip its on. everthing else is normal. it just turned off byitself and wont turn back on
  • Anonymous Jun 06, 2008
    I think Polaroid pulled a fast one on us all. In my opinion, The tv was designed to fail in approximately 18 months. My RCA console from 18 years ago is still alive and kicking. Next time I will spend the extra buck for the quality.They won't pull the wool over my eyes again.
  • kittykat197 May 11, 2010
    I have a TV plugged in and I'm not getting any power to the TV. it won't
    turn on. i checked the safety fuse. i checked the outlet. i checked the
    power strip its on. everything else is normal. it just turned off
    by itself and wont turn back on and the LCD light is flashing red instead of it's usual not blinking blue. It's a Polaroid TDA-02610c can anyone help me.
    Problem Solver:
  • 16 Answers
Dos the porew light stay red or turn blue or not at all?
Posted on Aug 24, 2008
Tv won't turn on
Check for input power in outlet. Try connecting the TV to a different power outlet you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | RCA L22HD31 22 in. LCD HDTV
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
The TV won't turn on. No power at the unit. Tried different outlets with no change
ensure that there is power in the mains, then if power is present then unplug the cable and check the cable plug if the fuse is burnt and replace. if this still does not solve your problem then you can open the tv cover carefully and be cautious as the tv may have not discharged fully. check the ``power in`` fuse and measure its continuity, measure the rectifying diodes and ensure all are healthy also check the power ic which should be STR series for that matter. by doing this your problem will have been solved
Sep 21, 2011 | LG 47LH50 47 in. HDTV LCD
Daughter's TV was on during bad electrical storm. Screen went black and made high pitched sound. cable, internet and telephones all digital through Time Warner Cable. Now TV will not even turn on;...
Ur Main Fuses in the circuits breaker box must be to be restart it back.Turn off/on all the fuses on the main circuits breaker box to all the fuses in the box of the box to restart.All ur electical power outlets should work again.If not those power plug in outlets are shorted and dead must have to be replaced.
Aug 22, 2011 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
We came home from a weekend vacation and the TV won't turn on at all. there are no lights, no response from the remote, nothing. It worked fine on Friday and now Sunday, it is shot. I thought possibly...
Hi, Check that the plug has power. Use a light to do this. Also check the TV cord maybe bad.
Check breaker pannel. Make absolute sure that you have power getting to the TV. If all is good you need a repairman. Good luck
Jun 20, 2011 | Westinghouse 32" Flat Panel LCD HDTV
My tv won t turn on i just purchased it today i plugged it in and it won t turn on
Check the electrical outlet which the tv is plugged into. Make sure nothing is loose at the outlet as well as on the back of the tv where the power cable plugs in. Another thing to try is plug a different device into that same electrical outlet and see if it turns on. If it doesn't turn on, it could be a faulty electrical outlet. If you've tried both the remote & the power button on the tv, a shot in the dark would be to change the batteries in the remote.
You could always try calling their tech support at 1-800-256-2487. A last resort would be to return the tv from where you purchased it.
Mar 09, 2011 | Emerson Televison & Video
Electrical surge can we fix the tv?
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 28, 2010 | Olevia LT42HVi 42 in. LCD Television
When we turned off the tv last night it was fine this morning it would not turn on it is as if it has no power . nothilng happens.
Plug something else into the outlet where the tv is plugged in to be sure that you still have power at that outlet. I like to use a hair blow dryer or a radio. If there is no power there check your electrical panel for the breaker or the fuse. Reset the breaker, or change the fuse.
Aug 07, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Sony Bravia LCD TV is tripping the fuse in the house
These things draw a huge surge current when turned on. What size fuse are you blowing? These things can surge 10-12 amps on turn-on. What about a fuse with a reset button. They will take alittle more surge before they go. Don't matter about the insignia working before because the cheaper sets tend to stay powered up more when off....thus not surging on from a dead start. Could you try a different plug on a different circuit/fuse? and see if that makes a difference. If you have a 15 amp fuse, then your pretty close with other stuff plugged in. What size is your service? Do you still have an original 60 amp box with screw in fuses? Is it an old house?
Sep 08, 2008 | Sony Bravia KDL-40S4100 40 in. LCD TV
Polaroid FLM-323B Television Logo
139 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
