Question about Amana DLG330RAW Gas Dryer
My Amana DLG330RAW gas dryer isn't heating up. The coil glows bright red for a while, but there is no flame. The coils seemed warm to me the last time I tried running it for a while, but I'd like to know how to test the components so I don't have to "throw parts" at it.
  • Amana Master
  • 3,051 Answers
Hello there:
Gas Dryers are very complex and there are several facttors involved here to make it heat Here is a list of possiable solutions for you to look at ok
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on Oct 10, 2010
  • Amana Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Whirlpool dryer heating sporadically?
Remove the lower front panel and turn dryer on. The ignitor should glow bright orange first. After Ignitor glows brightly the next thing will be the flame lighting as the gas valve opens with a click. All this should happen within about a minute or so.
If flame comes on but goes off quickly It's likely one of the Gas valve coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The coils are purchased as a kit.
If ignitor goes off and no flame comes on the coil kit is likely needed because one coil is fully broken inside its case. If flame goes on but shuts off shortly the problem is as described above and the kit is needed.
There is a flame safety assembly on the can above the burner. If the airflow is poor. the flame tip may activate that safety and turn the flame off. Or the flame switch may be open and not allow the flame to come on at all.
The Flame switch can be tested for continuity with an ohmeter but the valves may ONLY show bad with power applied and can not be tested with a meter as they will test good.. Good Luck
Nov 18, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
My Amana DLG330RAW igniter glows orange and a flame is produced initally when starting the dryer but after the flame goes out when the igniter glows orange again (shorter glow time) a flame never occurs...
could have bad gas coils? part 279834 they're located on the top of the gas valve unplug dryer,remove the two pillips screws,lift up the cover and change out the coils,watch out on the three prong coil there's a spacer that you want to stay on the post so when you slide the new coil on the coil it's tight,if the spacer isn't on the post after you remove the old coil look in the old coil and stick anything that will fit and push out the spacer then slide it back on post then install your new coils.also while you're in there get a shop vac and vac up all the lint you see,remove the lint filter and then remove the duct that the filter slides down into and clean that,then set the vac up to blow and blow all the lint from the back forwards and vac that up,make sure you blow the motor off and the gas tube and parts,you should do this at least once a year with gas so you don't have a fire,then go outside and make sure the duct is clear no cages or anything on it,go back inside and remove the vent line from the back of dryer,if it's a long run you can stick a leaf blower into the vent line and blow it out.if you need anymore help let me know.
Oct 12, 2011 | Amana DLG330RAW Gas Dryer
Gas maytag dryer not heating up
check the thermal fuse in the dryer vent duct to be open,then if not the flame eye" radiant sensor" or the high-limit thermostat both on the burner tube if the sensor doesn't see(sense) a flame the gas valve will stay shut,then check the gas valve coils,both the BOOST and SECONDARY coil valves on the gas valve body as these can open up and not gas into the burner
May 04, 2010 | Maytag Neptune MCG8000AW Gas Dryer
I have an Amana gas dryerDLG330RAW that doesn't
I have, for the 2nd time in 2 years, replaced the gas valve coils on my Amana dryer. Usually, intermittent (inconsistent) heat or no heat is caused by bad gas valve coils. They are one of the most common parts to fail and cost between 35 and 40 dollars for a valve coil kit and are easy to replace yourself. Remove the front of the dryer (or the bottom front panel, in some cases) and locate the gas valve. It is near the front, in most cases. There is a plate, held with 2 bolts, holding the coils on top of the gas valve. Remove the bolts and the plate, disconnect the coil wires from each coil and slide the coils off. Then place the new coils on top, hook up the wires, replace the retainer plate, and you should be back in business. Take note of which coil sits on which part of the gas valve. On my dryer, one coil has a 2 prong connector, and the other has 3 prongs. This should make it easy to determine which is which.
Dec 04, 2009 | Amana DLG330RAW Gas Dryer
I have an Amana gas(LP) dryer DLG330RAW that doesn't heat. When I turn on the dryer the ignitor glows red, and ignites a great flame for about 10 seconds, then I hear a click and the flame shuts down. A...
Replace the two small round black solenoids located on the gas valvle. I just did it last week. They come in a set and only cost me $26.50. Easiest fix I've done. I was all set to go out and buy a new dryer.
Sep 24, 2009 | Amana DLG330RAW Gas Dryer
No heat-gas dryer--Amana
There is a flame sensor on the side of the flame housing. Jump the 2 wires out and see if the ignitor glows then. If so you need a flame sensor.
Jul 25, 2008 | Amana ALG331RAW Gas Dryer
Amana LG4309w gas dryer
may be bad coils on gas valve
Jun 30, 2008 | Amana DLG330RAW Gas Dryer
I have heat when I start the cycle and a few minutes later I lose the heat in a Amana dryer Model# DLG330RAW
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
http://www.repairclinic.com/0088_8_1.asp#Level1_14
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 27, 2008 | Amana Dryers
Amana DLG330RAW gas dryer.
try cleaning or replacing the flame sensor ( optical unit mounted on the side of the burner tube. voltage flows though that optical eye that proves flame.
Mar 29, 2008 | Amana DLG330RAW Gas Dryer
Amana DLG330RAW Gas Dryer Logo
513 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
