Question about Arris SURFboard SBG900 (49402201900) Modem
Need modem reset - unable to access using original user ID and password.
  • 4,281 Answers
Press RESET button for 10 seconds it is in back side of router then all settings defaults.Then you can configure it with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Posted on Oct 10, 2010
Reset pk5000 actiontec forgot admin password
Using a paper clip or similar object press and hold the reset button which is accessed via the hole inside the red circle on the back of the modem. Make sure you hold the button in for 30 seconds or more. You will then have reset you login id and password and reconfigure all the wireless and security features you had in there before.
Mar 25, 2012 | Actiontec Computers & Internet
Why can't I connect to the internet?' I have tried to reset the modem, but has not worked
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
don
Feb 16, 2011 | Computers & Internet
WHEN I HHOK UP MY ROUTER I LOSE CONNECTIVITY TO MY DEKTOP. ALL WIRES SRE CONNECTED PROPERLY
also
make sure your routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
hope this helps
Jan 12, 2011 | NetGear WGT624 Wireless Router
Where do I find the hex id?
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Dec 11, 2010 | Arris SURFboard SB4100 Modem
A user name and password
You need to hard reset the modem first. By doing that, look at the back of the modem then look for red button. Get a pen or something pointed that will fit on the red button. Press the reset button of 30 seconds then you will see that the power light will change to orange light. If every light is already disable. You can access the firmware of your modem. username: admin
password: password
the you can configure your modem now.
May 23, 2010 | Westell Wirespeed LiteLine 6100...
I have lost my router User Id and Password. So is there any way to fix it or i need to get a new router...
In the back of the unit there is a reset button, you need to hold it in for 30 seconds, this will set everything back to the default setting.
Your default settings are
user--admin
password- motorola
You will have to run through the settings to set up the router again.
Feb 06, 2010 | Arris SURFboard SBG900 802.11g/b...
Dont know username and password to access the modem
First connect your router to computer with ethernet cable.
then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then you can see configuration page.
Let me know if you need more assistanse.
Thanks.
Sep 24, 2009 | D-Link AirPlus DI-524 Wireless Router
Modem working, Linksey set but can not get interenal on PC
You MUST configure router with instruction supplied by your ISP: PPOE? PPOA? User ID. Password etc...
Connect to router with LAN cable and check configuration with your ISP,
Then follow a check list with this tip to activate your WLAN
Jan 24, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
I have a DNA-A211-I ADSL2+ Modem. It went fo repair by BSNL and they exchanged it for another. Now I cannot access the user settings (http://192.168.1.1) as the default user name and password were...
hey buddy u need to press the reset button only for 3-5 sec( it look like a hole u have to use a pin to reset it. it is located at the bottom of the modem.) don't press the button more then that otherwise it won't get reset. once it get reset go back to the modem page this try admin as user name & leave the password blank. if case if it doesn't work with that try admin as user name & admin password or admin as user name & password as password.
Jan 15, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I hv 2 wire modem bought from my friend, I don't know how to reset user ID and password in this modem
you can try resetting the modem by picking a small pin and pocking in behund the modem which states "reset"
Or if you can access the gateway you can reset it from there.
to access gateway in case type in your browser -- > http://gateway.2wire.net/mdc - <-- you will be prompted to enter password . The default password is 2wire . Once you entered in , scroll down to Troubleshooting which will be on your left
, search for resets <--- Click on it, it will direct you to a page where you can reboot system and stuffs.. Click on the button RESET beside factory defaults. Your modem will be reset to factory default, your power light will change orange and be normal back for about 10 secs ... When everything has come back to normal, you can then continue to enter your user id and password to log in internet.Or alternatively u can Go to http://gateway.2wire.net/setup <--- and configure your modem from there with a step by step guide :)
THANKS
Dec 02, 2008 | 2wire (1000-000057-000) Modem
Arris SURFboard SBG900 (49402201900) Modem Logo
868 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
