Question about Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis washer will not drain and spin unless you lift the lid
We have a Maytag Atlantis washer that will not drain and spin unless you lift the lid and put it back down. If you do not perform the "lift lid" ritual, it finishes the cycle with water and suds having never rinsed or spun.
  • lidjames Jun 08, 2008
    Replace the lid switch I had the same problem
  • Anonymous Mar 24, 2014
    doesn't spin or drain thinking lid lock is bad, have had washer little over 2 years, replaced it once.
  • 246 Answers
The cheaper thing to check first is is your lid bent? The lid switch is in the center of the lid. If it "droops" or has been bent, it shaft on the back of the lid cant hit the switch. Open the lid and apply pressure in the bottom, center of the lid. This usually corrects the problem without replacing the switch.
Posted on Jun 16, 2008
My mvwc300vw1 won't spin unless you lift the lid up to activate it
I'm not sure what you mean by "activate it." Are you are manually pressing down on the lid switch or are you saying that lifting the lid starts the spin cycle? You may just need to adjust it. For whatever reason the actuator on the lid isn't pushing the switch far enough to activate it. It is possible that the actuator broke in some weird way that makes it contact the switch when the lid is opened. Regardless the spin cycle should cease when the lid is opened. The actuator is the wire hinge on the left side of of the lid. They always break where the screws connect them to the lid so you should be able to see it by lifting the lid. You can go here for manuals and exploded views of your machine. The hidden lid switch and actuator are clearly visible if you click the "Top and Cabinet" diagram.
Now i want to say something about your machine. First to be fair i don't know what the reviews of this machine might have been and I've never owned one, but if it serves you well hold on to it. Maytag doesn't make them like that anymore. In fact Maytag doesn't really make them anymore. That repairman died years ago and was never replaced. I'd take a machine like yours (with manual controls and no brain) over every smart h.e. machine i've ever had the misfortune to work on or operate. Sure they save water and they are quiet now but the drain pumps are junk fixing to bust and in my opinion the reason people experience mold and odor problems. They oversuds chronically and then have to sit while the machine decides when and how you can proceed. Doors lock shut at the most inopportune times. Control boards cost hundreds of dollars to replace and diagnosing problems on a "smart machine" can sometimes be more than a little baffling. So treasure it. Just sayin.
Jan 01, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Washer will not aggitate
LOOK AT THE LIDE SWITCH FIRST WILL IT FILL WITH WATER WILL IT DRAIN WILL IT SPIN IF THE ANSER IS NO TO ALL LID SWITCH IF ONLEY TO AGGITATE MAY BE A TIMER OR AGITATOR IT SELF
Apr 03, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Need to replace Lid Switch for Maytag Atlantis 2002 Washer
Hello, I can help you.
Let me explain to you how the Maytag washer lid switch works.
The lid switch is located on the controls panel, and is activated by opening and closing the washer door. The purpose of the lid switch is to prevent the washer from working with the door open.
It is a safety device to prevent the user from sticking their hands inside of the washer while the washer is agitating or spinning.
When the washer lid switch stops working, the result could be that the washer won't wash, drain, spin and in some cases the washer will not work at all.
You will need a multimeter to check the internal contacts on the washer lid switch.
You will also need to use the wiring schematic to see what contact should be close when the lid switch supposed to be on.
You will need to remember that the Maytag washer lid switch is one of the first parts that you will need to check, when the washer don't want to start filling, agitating, draining or spinning.
Jun 13, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water will not drain, will not do anything.
I would check the lid switch. That is most likely the problem.
Apr 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Our maytag will not drain or spin
Check if the lid switch is working. If not see the solution proposed on this blog.
Aug 16, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Quit Working
it would be the switch get a knife and swip at both ends off ware the top lid section meets front side[join at front]this will allow top section to lift up switch may be broken or to short to turn on if to stort drill hole & pot screw in to adjust lenght of swich leaver
Dec 12, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
606 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
