Question about Iomega 1TB Desktop USB 2.0 Hard Drive
My hard disk is not detected in the system . but power source is connected .and the led in the hard disk is glowing so please help me about the solution more over the data in that hard disk is critical so please help me
    Sergeant:
  • 298 Answers
The problem could be from one of 3 places, one being the drive. this is very unlikely except if it has not fallen or dropped then it should be fine.
second could be your usb cord, since it is glowing then there is power going in but maybe not enough. so try a different cable
lastly it could be from your usb port, it might be a hardware fault or maybe it has being deactivated. try using it on another pc
Posted on Oct 10, 2010
Hi, I'm facing following problem, can any one help me please? Seagte external hard disk GoFlex Desk 1TB (STAC1000300) with USB 3 adapter STAE 106 is not working. When the USB 3 cable is connected to...
just install seagate free agent using this link
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=goflex-software&vgnextoid=11c1fab114b48210VgnVCM1000001a48090aRCRD
then try again if problem not solved, mail me to tsnp@ymail.com
Apr 19, 2011 | Seagate FreeAgent GoFlex Desk Desktop...
My motherboard cant detect hard disk ,disk driver and when i start my computer it dint show HDD LED light (red light) and it show "No Hard Disk detected, Please insert Hard Disk and Press Enter. i...
THere maybe a problem with the SATA/IDE connection.Check the connection first using another cable or try to another port. If it doesn't work, try the drive on another PC. Check for the power connection cable as well.
Let me know if this works,
levibit
Dec 17, 2010 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
3 beep sound
If a PC suddenly fails to boot properly, you should perform a hard reset as the first action. Performing the hard reset will correct many problems. If the computer still does not start properly, select your symptom from the list below to guide you to the recommended corrective actions.
  1. Disconnect all peripheral devices and remove all USB devices and SD media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain all residual power and restore default startup settings.
  3. Reconnect the AC power adapter (but do not insert the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a fan or other moving parts turning.
  4. If the computer does not start, the LED lights do not glow, and the display is black, you can perform one or more of the following actions to resolve the no power issue.
    • Verify the computer is receiving power from the AC adapter . Verify that the AC adapter is not damaged and is connected correctly to a working wall outlet plug. Verify AC power is connected to the system board by examining the AC adapter, wiring, and pin connection for damage. The keyboard LEDs will glow when AC power is connected to the system board. Damaged components, like the AC adapter or the pin in the power connector, may require an HP-certified repair.
    • Use a different AC power adapter . If you have access to a different AC adapter or power pack that is designed for the computer, connect it to the notebook and try to start the computer. If you own or have access to more than one notebook, verify that you are using the adapter which belongs to the notebook. CAUTION: Using a power adapter that does not meet the power requirements or has the wrong type of connector may damage the computer. On newer notebook models, connecting the wrong adapter to the notebook may cause the power LED lights to blink but not power the computer.
    • Remove the battery and boot on AC power only . A discharged or defective battery may prevent the AC adapter from supplying enough power to start the computer. To verify that power from the AC adapter is available for PC; remove the battery, connect AC power adapter, and press power button. If available, try using a different AC adapter, that is rated for the PC, and repeat this test.
    • Remove the AC adapter and boot on battery power only . A defective AC adapter may not charge the battery and prevent the computer from booting on battery power only. To verify battery power available for the PC; connect AC power adapter, allow battery to charge for 30 minutes or more, disconnect the power adapter and press power button. If available, try using a fully charged battery, of the same type, from another computer and repeat this test.
      • If LEDS do not glow and the fan or hard drive do not spin, battery may need to be replaced.
      • If tests of both the battery and the AC adapter fail, there may be a problem with system board requiring service by HP.
      • If LEDs glow and PC boots, the AC adapter may need to be replaced.
      • If LEDs glow, but PC does not boot go to LEDs glow, fan is heard, but display is black or blank section.
Nov 21, 2010 | HP Compaq d530c PC Desktop
I have a hp a350 cpu.the problem is that the light of led has gone red,as before in working condition it was green. It can't start.the power to hardisk is also not coming.please tell a sollution.
As you say has become red and no power to the hard disk.
First check the power cable for any loose connections and check if it give power to the cpu and the fan placed on processor starts working as you start the power. If fan it starts and with in few seconds stops then your power supply/SMPS is weak or damage. So replace it for proper working of your computer. And if after power on all fines but red led on monitor and no power to hard disk Try to replace the hard disk power cables because they are not working because of it no operating system is detected and led of monitor is red. After replacing hard disk cables hard disk starts working and still no display or red led on monitor check the vga cable for loose connection or replace it.If you are using vga display from graphic card try to get display first from onboard vga slot.After it your problem will disappear and your pc run smooth and fine.
Aug 27, 2010 | HP Compaq d530 SFF PC Desktop
When I connect 2nd and 3rd hard disk my system wont starts......
Just because it has a CPU, it is not a brain
It is ok to set up 2 or 3 harddrives BUT... make sure one is a master, (C:)the others are slaves D-Z
Look at all drives, most now have jumpers and they are master,slave,cselect.
To make it easy, slaves/masters
Jul 24, 2010 | Intel D915GAV Motherboard
We have a Power edge 840 that can't not detect any HDD in starting process, although power and data led are on. Can you help me to solve this problem? Thank you very much! Best regard!
Check both the POWER and the DATA cables between the motherboard and the HDD (Hard Disk Drive).
Remove them, and then re-insert them.
Try connecting the DATA cable to an alternate connector on the motherboard.
Remove the HDD, and connect it to another computer,
to see if the HDD can be detected on that computer.
If not, the HDD is the problem.
Oct 27, 2009 | Dell PowerEdge 840 (becwmk1_2) Server
Not hard drive but cd boot
Hello my friend, regarding on your problem please turn off you computer then unplug all the power cord connected in your computer to the power source then open your computer kindly check the bus or IDE or Sata cable connected to your hard disk and make it sure that th cable is properly plug and then connect the power cord to the power source then turn on the computer then go to the CMOS setting then check if the hard disk is detected to ensure that you hard disk is functioning. Then check also the priority boot up manager of your computer make it sure that your hard disk is assign to boot up. But if the hard disk is not detected then try to find another hard disk then try that hard disk if it is detected in your system. What ever the result of the test kidly seek any technician in computer in your place to have a second opinion and to ensure that your diagnostic finding is correct.
Hope this solution ables you to solve the problem. If you need more assistance please reply to this post.
Thank you
geo_jonas
Jul 17, 2009 | Computers & Internet
Starting problem after hibernation
Do you hear a beep (POST Beep) within 2 sec when you power on the computer?
Apr 27, 2009 | Computers & Internet
System not detecting my external hard disk
try going onto computer and see if it has removable disk right click and open or try putting usb in another port or if a disk came with it put that in .
Dec 28, 2008 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Iomega 1TB Desktop USB 2.0 Hard Drive Logo
210 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
