Question about Envision 19" Widescreen Flat Panel TFT LCD Monitor
I recently dropped my keyboard and when I grabbed it to keep from falling on the floor, I must have hit a combination of keys that turned my monitor "sideways" in other words, I cannot get it back to "normal" it is reading left to right instead of top to bottom. When I go into my control panel, it will not let me select the correct monitor for viewing. I cannot keep turning my head all the way to the right to view my desktop correctly. Any suggestions?
4 Suggested Answers
  • 13433 Answers
SOURCE: Monitor viewing position
You need to flip the screen 90' depends on your video card. Its in screen properties -> advanced properties.
Posted on May 18, 2008
  • 125 Answers
SOURCE: screen shift
Try setting the refresh rate to 60 Hz. (Maybe 75).
Is it xp?
Right click an empty part of the screen, properties, under monitor (I think; I'm on Vista) you can choose the refresh rate.
Most LCD's should be at 60 Hz.
Posted on Jul 04, 2008
  • 814 Answers
SOURCE: All pictures appear wider than they really are
You may have to match up the video card settings with the monitor settings to get the correct resolution setting. Try adjusting the resolution of the graphics card to match the setting for the monitor. If this does not work you can call, Envision customer support at this telephone number : 1-888-838-6388. They should be able to help you get the correct setting for you set-up. I hope this information helps you with your problem.
Posted on May 22, 2009
I hit something on the keyboard that made my monitor go blank
The specially colored "Fn" key is intended to work for extra functionality. Try combining the Fn + Function keys where key symbols vary from system manufacturer so I can't tell how which key will work to re-enable your screen back (try Fn + F7).
Jul 22, 2014 | Logitech Computers & Internet
Third function keyboard
The purpose of a laptop's function key is to activate the secondary function of any dual-purpose key.
The function key can accidentally be locked into place if you hit the wrong combination of keys so that all of the keys only perform their secondary function.
The exact process for unlocking the function key will vary depending on the make and model of your laptop and whether you have recently used an external keyboard.
Check the manual that came with your laptop and locate the section on the function of each keyboard key.
Open a Web browser and navigate to the support section of the laptop manufacturer's website if you do not have the manual that originally came with your laptop.
Use the drop-down menus on the support page to choose the specific product line and then model of your laptop.
Click on the "Product Support" link and then navigate to the "Manuals" section of the page. Click on the link to open a PDF version of the manual for your laptop.
Browse down to the section about the functions of the keyboard keys.
Find the sequence of keys you need to press to unlock the function key on your laptop.
Press and hold the function key on the keyboard and then press the other keys required to unlock it.
Try using the most standard keyboard combinations if you don't have the manual or it does not give any information about the function key.
Press the function key and then the shift key and see if it successfully unlocks the function key. Attempt using the other standard keys in conjunction with the function key, such as the "F11," "F12" and "Ctrl" keys.
5
Plug a USB keyboard into the USB port on your laptop if you have recently used an external keyboard with the laptop.
Check the light above the "Numlock" key on the external keyboard and see if it is turned on. Press the key and make sure the light is turned off and then remove the keyboard to unlock the function key.
http://us.acer.com/ac/en/US/content/support
Acer Support
Nov 26, 2013 | Acer Computers & Internet
I touched a button on the keyboard that turned the page sideways.. it turned it to the left. how do I turn the page right side up?
Actually you hit a combination of keys. Most likely you hit Ctrl+Alt and an arrow key. Try Ctrl+Alt+the up arrow. If that rotates the screen to upside down, repeat the combination twice more (or use Ctrl+Alt+the down arrow twice).
If that doesn't work, if you have a Windows OS, try the Screen Resolution or Graphics Display settings. Right click on the desktop anyplace with no running programs or icons, select Screen Resolution and then change the drop down for Orientation. This works on my desktops. For my laptop, it's the Graphic Display and then a similar orientation label.
I hope this helps.
Sep 10, 2013 | Logitech Y-RAZ71 Wireless Multimedia...
How to function Fn
Step 1:
The purpose of a laptop's function key is to activate the secondary function of any dual-purpose key. The function key can accidentally be locked into place if you hit the wrong combination of keys so that all of the keys only perform their secondary function. The exact process for unlocking the function key will vary depending on the make and model of your laptop and whether you have recently used an external keyboard.
Check the manual that came with your laptop and locate the section on the function of each keyboard key. Open a Web browser and navigate to the support section of the laptop manufacturer's website if you do not have the manual that originally came with your laptop. Use the drop-down menus on the support page to choose the specific product line and then model of your laptop. Click on the "Product Support" link and then navigate to the "Manuals" section of the page. Click on the link to open a PDF version of the manual for your laptop. Browse down to the section about the functions of the keyboard keys. Find the sequence of keys you need to press to unlock the function key on your laptop. Press and hold the function key on the keyboard and then press the other keys required to unlock it. Try using the most standard keyboard combinations if you don't have the manual or it does not give any information about the function key. Press the function key and then the shift key and see if it successfully unlocks the function key. Attempt using the other standard keys in conjunction with the function key, such as the "F11," "F12" and "Ctrl" keys. Plug a USB keyboard into the USB port on your laptop if you have recently used an external keyboard with the laptop. Check the light above the "Numlock" key on the external keyboard and see if it is turned on. Press the key and make sure the light is turned off and then remove the keyboard to unlock the function key.
b>
Feb 15, 2013 | Gateway NV52L06u Laptop PC
French
adjust in control panel ;
Apr 30, 2010 | Gateway 2520915 Keyboard
Menu keeps popping up; Stuck buttons perhaps?
Yes, a stuck key would be a likely culprit. Sometimes a key will get stuck out of just plain useage/wear, or, pop or other liquid spill or splatter will result in a sticky key. Press on the suspect key-compare to another key- different feel will tell you a problem exists.
Low cost keyboards don't generally have the life expectancy as older higher quality ones. Laptop keyboards are also more fragile, and subject to problems.
Dec 23, 2008 | Dell E153FP 15" LCD Monitor
XEROX LCD flat screen monitor
Hold down the combination of keys "CTRL"+"Alt"+ "arrow keys" to change picture orientation on Windows, this will sort out the problem.
Oct 18, 2008 | Xerox XA7-172i 17" LCD Monitor
Need to disable a key on my keyboard
check your keyboard in
Start/settings/control panel/keyboard right click open check what options available you may be able to stop key working
Jul 24, 2008 | Computers & Internet
Missing key
Once back inside the temple, the first three floors will be basically the same,
with a few minor exceptions. When you get to B1, head up to the switch you
went to the first time, but instead of hitting it, bomb the rocks to the left
for a shortcut to the key. Grab it and run to the door, saving you a lot of
time.
For the second floor of the temple, you will still need to hit the two switches
to drop the key down, but instead of pulling the lever behind the Phantom, you
can bomb the wall directly south of the entrance for another shortcut. Grab
the key, then proceed the same way as the first time, through the blue and red
blocks. Head for the locked door, but this time stop at the safe zone for a
bit, and head just west of there and bomb the wall, revealing a 30 second bonus
to your Hourglass. Then you may proceed downstairs.
The third floor follows an almost identical procedure as the previous run.
First, grab the Force Shard in the northwest corner and take it to the
pedastal. Once that's taken care of, head east and bomb the rocks for an
additional 30 seconds. Then, head just south and use the Boomerang to hit the
switch, stopping the nearby spikes. Then, head to the southeast corner, grab
the second Force Shard and return to the pedastal. Now, instead of going to
hit the switch to lower the fires, you can use the shovel to reveal a rising
wind that will carry you to the top platform so that you can get the key.
Kill the Phantom, grab the key, and head to the locked door. Grab the last
Force Shard and return it to its pedastal, then proceed through to the next
room. Run to the far left side of the room, grab the 30 seconds, then head
back to the Door of Wisdom and proceed through and down the stairs.
Jan 23, 2008 | Nintendo DS Lite Console
Envision 19" Widescreen Flat Panel TFT LCD Monitor Logo
37 people viewed this question
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
