Question about Dyson DC18 all floors Bagless Upright Cyclonic Vacuum
Foot pedal came apart.Trying to reconnect.Might be missing a part.Need a drawing on assembly for foot pedal that operates the shifting from the hose to the floor vac
  • 171 Answers
  • It took some searching but the site you need is called "dyson medic.com" This is the place that will have the repair manual you are looking for. You are not alone in the world of broken dyson's.
  • I hope that this has helped you and if so please remember to click on the yes box on your way out ....thanks again and good luck with your repair!
Posted on Oct 10, 2010
  • Anonymous Oct 10, 2010
    You need tyo get in touch with the "dyson medic" at dyson medic.com
    this is the place that will have the repair manual that you need to do this job.
    I hope this will help you and plese try to remember to click on the yes box on your way out if this was helpful to you. Good Luck and thanks !
I need a you tube showing me how to replace the handle release. when I pick up the vacuum by the handle the vacuum head flops down
If you remove three screws you can remove the assembly with the foot pedal. Look at how it is installed closely in the assembly, including the spring, shaft and pedal. Disassemble it and install a new foot pedal exactly the same way you took it apart.
Feb 15, 2016 | Riccar 8000, 8900 Series Metal Agitator...
Broken foot pedal riccar 8850
Remove the assembly that holds the foot pedal by removing the three screws after you've removed the bottom plate and brush roll. This allows you to get the nozzle housing out of the way so you can rotate the assembly holding the foot pedal from the metal pivot. Remove the e clips from the shaft and pull the shaft out of the foot pedal (be sure to look closely at the spring and how the shaft are positioned so you can be sure to install them exactly the same way you took them off. It is not a hard job but can be confusing the first time. It's not an expensive fix to have done by your Riccar dealer.
Apr 06, 2014 | Riccar 8850 Vacuum
The foot pedal to go from drive to nuetral on my G series fell off and i cant seem to get it back in
The pedal assembly must be replaced,( part # 558401S), as it has a gear pressed to it which has come loose. The handle, switch plate, and upper motor cover must be removed first. To remove the plastic switch plate, remove it's screws and insert a flat screwdriver into the rectangular slot in it to pop it off. Four screws hold the upper motor shell in place. Next the switch button must be removed. The Techdrive assembly can be removed by removing the three screws on the bottom. Drop the drive down, and unhook it's belt from the gear on the end of the armature shaft. The pedal assembly can be removed by removing the remaining screw from the bottom of the drive unit. The N/D pedal has two parts - the pedal itself, and the shift cam. Observe carefully how these units fit together. After installing the new pedal and replacing the screw and washer to secure it, re-install the drive unit. The shift must be in the Drive position to install it, and remember to replace the belt. Be sure to line up the arm on the drive unit so that it engages the slot at the base of the handle pivot and re-install the other items.
Mar 06, 2011 | Kirby Ultimate G Bagged Upright Vacuum
How do you replace the drive/neutral lever (foot pedal) if it falls off? (The yellow and gray lever that you step on to put it into drive or neutral.) Not sure what happened but it just fell off. Now I...
The pedal assembly must be replaced,( part # 558401S), as it has a gear pressed to it which has come loose. The handle, switch plate, and upper motor cover must be removed first. To remove the plastic switch plate, remove it's screws and insert a flat screwdriver into the rectangular slot in it to pop it of. Four screws hold the motor cover in place. Next the switch button must be removed. The Techdrive assembly can be removed by removing the three screws on the bottom. Drop the drive down, and unhook it's belt from the gear on the end of the armature shaft. The pedal assembly can be removed by removing the remaining screw from the bottom of the drive unit. The N/D pedal has two parts - the pedal itself, and the shift cam. Observe carefully how these units fit together. After installing the new pedal and replacing the screw and washer to secure it, re-install the drive unit. The shift must be in the Drive position to install it, and replace the belt. Be sure to line up the arm on the drive unit so that it engages the slot at the base of the handle pivot and re-install the other items
Feb 28, 2011 | Kirby G5 Bagged Upright Vacuum
How do I use the attachments?
The rug head must be replaced with the hose assembly. Raise the head to it's highest position with the foot pedal. Turn the belt lifter fully counterclockwise to disengage the belt, and unlatch the head to remove it. The hose then sits on the mounting bar, and can be latched in place.
Jan 17, 2011 | Kirby G5 Bagged Upright Vacuum
How do i remove the old hose assembly non my simplicity 7350 so i can install the new part? It seems to be locked in tight, do i break the tabs?
Are you just trying to put the hose into the cuff? If so, you just need to know that the cuff is threaded so the wire of the hose fits in the threads. If you're asking about the assembly at the top of the hose--I don't know. Probably you have to take the green shell apart and work from the inside. Good luck.
Sep 12, 2010 | Simplicity 7250 Deluxe Vacuum
My pump runs but won't pump
Refer to the discussion at the other thread: http://www.fixya.com/support/t3309646-pump_motor_sounds_like_running_but_not
You will need to remove the top domed lid to access the working parts. Refer to http://www.fixya.com/support/t3543424-two_top_sections_held_together
Examine the water lines to ensure they are attached to the pump. If you feel you can do so without shocking yourself on any exposed electrical connectors, try disconnecting the inlet hose. Buy a two-foot section of the same size hose from the hardware store and connect it to the pump inlet. Plug in the unit (be careful!!!) and use the pump switch to see if it draws water. Then try reconnecting the inlet and connect the outlet to the new hose to see if the pump pulls water from through its suction tube and will pump through the new hose.
Nov 16, 2008 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Dyson DC18 all floors Bagless Upright Cyclonic Vacuum Logo
413 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
