Question about Whirlpool Dishwashers
I own a whirlpool quietpartner II dishwasher model DU600PWKQO serial no. FP0408764. I've had it for 7 years now. I would like to know the best way to clean it. I think their might be a bit of calcium deposit from the water. Can i use white vinigar to clean it? Let it soak for a while? What's be best way to clean it. I don't have the manuel anymore. Thanks, Liliane
SOURCE: dishwasher doesn't clean the top rack whwn we riun it.
sounds like the jets are cloged you can try a small wire to try and unglog the jets that or you water does not have enoph pressuer hope this helps
Posted on Feb 12, 2009
ginko
  • 19396 Answers
SOURCE: need to clean lime and calcium deposit from bottom
The cheapest way is using homemade vinegar and lemon solution. If the deposit is big use a commercial cleaner. See the links below:
cleaning calcium deposits from dishwasher
How do I clean my dishwasher
How can we prevent dishwasher detergent residue?
Buy Dishwasher magic Cleaning Supplies
Removing lime from your dishwasher
Lime Away To Clean A Hot Water Heater
Automatic Dishwasher Cleaning Tips
How to Clean Your Dishwasher
Posted on Apr 13, 2009
  • 11 Answers
SOURCE: how do I clean off calcium deposit from dishwasher
I suggest you descale your machine with a cleaner such as C.L.R. Any cleaner with Phosphoric Acid will do a good job. The best way to clean your dishwasher is to pour a litre of this cleaner into your machine, and run a complete cycle. (without dishes in the machine) You may need to repeat this process every month depending on the hardness of your water.
Regards
Posted on Jan 18, 2010
  • 10 Answers
SOURCE: how do I dissolve dishwasher calcium deposits w/o causing leaks
White vinnegar
Posted on Feb 24, 2010
  • 901 Answers
SOURCE: calcium like deposits on plastic and glassware after cyc
Check the quality of water used in the machine. If water has hardness this may happen. Use water softener attached on line to the dish washer.
Posted on May 20, 2010
Need to know what year is my washer set
The date of manufacture is determined by the SERIAL NUMBER, not the model number. The serial number will be located on a nameplate (with the model number) along the wash tub rim under the lid.
The following link explains how to read the serial number to determine the age:
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
The 2nd digit in the serial number will identify the YEAR is was manufactured. The first two numbers, following that digit, will determine the WEEK (52 weeks in a year). This same information applies to all your other Whirlpool appliances.
If you have any questions, please post back and let me know. I hope this helps you.
Dec 18, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
What year is this Kenmore dishwasher Model # 665.15831791 made?
The date of manufacture is determined by the SERIAL NUMBER on the appliance. This dishwasher was manufactured by Whirlpool. The following link explains how to determine when it was manufactured:
The serial number is usually located somewhere around the door opening. The first two numbers in the serial number identify the WEEK it was manufactured (52 weeks in a year). The second DIGIT in the serial represents the YEAR it was manufactured.
If you have difficulty determining the manufacture date, please post back with your serial number and I will assist you. I hope you find this information helpful.
Mar 29, 2010 | Dishwashers
I require a manual for a Maytag jet clean dishwasher, super capacity - Quiet Plus II, model number MDB6000AWW, serial number 13585595SY. Best quess is that the machine is 11 years old. It came with the...
Your dishwasher was manufactured in November of 1986. Uh...its actually 23 years old, which could be why I had a hard time locating a manual for you. I was able to find a manual at the following link:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MDB6000AWW&siteCd=MT_EN_US#owners_manuals
There's an Owner's Manual and Installation guide listed.
If you need further assistance, please let me know. I hope this helps you.
Oct 15, 2009 | Dishwashers
Dishwasher acts up
sounds like you have a bad chopper. put a cup upright on the top rack. turn the dishwasher on let it wash for about 2 minutes. open the door and see if the cup has water in it. let me know. what brand is this?
Jun 15, 2009 | Dishwashers
Makes growling noise during the wash cycle. some vibration. unit is 6 or 7 years old. it is a maytag jet II EQ. cannot locate the model number as it is a built in unit. would appreciate any help. thank you
Hi Spacepaint, No manufacturer hides the model/serial number behind the enclosure. Look closely on the side of the door panel edge and on the inside edge of the door jam. You will find the model number there.
Growling that happens on every cycle normaly indicates either debris in the sump area / filter or a failing pump motor. Remove screws and inspect the well area for debris.
Recommend a service call if problem is not resolved by the cleaning.
Mar 29, 2009 | Maytag MDB9600A Jetclean II Built-in...
Dishwasher doesn't clean the top rack whwn we riun it.
Feb 12, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Slow water in whirlpool dishwasher
take the hose off the dishwasher and see if the pressure is good,if so the valve is faulty,most of the valves on whirlpool are at the back but you can get to them by taking the base pan off,but check first.hope this helps.
Mar 12, 2008 | Dishwashers
Whirlpool dishwasher quietpartner 2-soap residue
check that the sump screens are clear in the tank,also check that the wash arm holes arent obstructed.
Dec 30, 2007 | Dishwashers
Dishwashers Logo
80 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
