Question about Frigidaire FGQ1442ES Gas Dryer
Doesnt heat up - Frigidaire FGQ1442ES Gas Dryer
  • Frigidaire Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101..
Posted on Oct 17, 2010
Why is my lay z spa not heating?
if the heat light comes on but doesnt heat bad heater element if red heat light doesnt come on need new temp sensor
Aug 31, 2014 | Pool & Spa
Amana heat pump doesnt come on.
sooo many possibilitys. turn it to heat NOT EM HEAT. usually a low voltage issue. unless experianced i say leave this one to the pro's
Feb 19, 2014 | Amana Heating & Cooling
Doesn't overheat, but losses coolant. also has oil in resivior. heater doesnt blow hot air
sounds like bad head gasket or intake manifold need compression test thing that scares me is oil in water resivoir
Jan 10, 2014 | 1992 Cadillac DeVille
Doesnt heat thermostat was replaced and fuse replaced still doesnt heat
What is the model number of the dryer? I did not see where you checked the "heating element" on the dryer. Check the element for continuity.
Dec 30, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Doesnt heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hfjjf
May 13, 2010 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Our microwave has power, turns on correctly but doesnt heat
our microwave has power, turns on correctly but doesnt heat. It sounds like it is heating but it don't.
Oct 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore dryer doesnt heat
You may also need to change your thermal fuse and the thermostat. On some models the thermal fuse operates the heating element only and others the whole dryer
Mar 19, 2009 | Dryers
MMV4205 doesnt heat up
If not a separate fuse, then the hi-voltage inverter or magnatron have likely failed. The first can be $130. The second $45.
Jan 30, 2008 | Maytag MMV4205 Microwave Oven
Frigidaire FGQ1442ES Gas Dryer Logo
109 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
