Question about Samsung DCS 12 Corded Phone
Have lost technician password for samsung dcs, have tried 4321 but does not work also 1234, any help
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
Hi, you will have to ask your installer or maintainer, sorry there is no easy way to do this
Posted on Jul 06, 2011
How to reset password for a samsung SDE-3004N DVR home security system. There is no remote for the system and have lost the password.
Samsung Security DVR Default Password
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
Samsung Security DVR Reset Procedure #2
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    Press and hold the following buttons
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
    When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6 Courtesy Sergio Ayala
To factory reset the SDR-B74301
  1. Reboot the DVR
  2. Once the DVR has rebooted, enter the following sequence on the remote:
  3. UP, RIGHT, 5, 3, 3
  4. You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below.
CCTV Networking Technical Support
Sep 18, 2017 | Samsung Home Security
Sumvision 8ch dvr forgot admin password and can only log in on admin. Tried codes 123456, 000000, 111111, 999999, 1234, 4321 the last two were tried when the battery was removed please help
Factory Reset Hidden Key :Mode Key + CH 2
The Password and all setting value will return to the initial default value.
Default Password is '4321'., Refer to 6-10p, 6-12p of User manual
I hope this helps.
Mar 28, 2015 | Computers & Internet
How to change the admin password if you don't have it
usuallly there is a few standard codes.
1234
4321
1111
0000
try those!
Feb 11, 2014 | Samsung Svmi-4 Voicemail
I have a Samsung DCS 100 system. What is the default Technician level password? How can I obtain the Technician level programming manual?
I can only give you the Customer level programming number, this is ;
TRANSFER -200- 1234 - 1
There are loads of technical help videos at http://www.abbeytelecom.com I've sent you an example
Dec 23, 2010 | Samsung PROSTAR816 PLUS PHONE SYSTEM Elec...
Passwor for samsung prostar816 4321 does not work
hi, customer password on the prostar816 is 1234, if this has been changed then I am afraid that you may need call out a Samsung engineer. I can't help you with this but any other problems on the prostar816 check out abbeytel on Youtube, where we have posted training videos, I have uploaded one for you to look at. Or visit www.abbeytelecom.com
http://www.youtube.com/user/abbeytel#p/u/20/N_gTQT8lJ8c
Sep 18, 2010 | Samsung Prostar 816 Display Phone
How do I change the date & time on our Samsung Prostar DCS-24B-LCD Corded Phone
Please follow the steps :-
1) Press transfer.
2) Dial 800.
3) Enter passcode = (try 4321 or 1234)
4) Press 1.
5) Press the speaker button.
6) Dial 505.
7) The display will show.
WMMDDYY:00:00
w=day of the week (1=Mon. - 7=Sun.)
mm=2 digit month
dd= 2 digit day
yy=2 digit year
time must be entered in military time when done press Transfer.
I hope I was able to help you.
Nov 03, 2009 | Samsung Prostar DCS-24B-LCD Corded Phone
Want the password to pair with Nokia N70
Try these codes
1234
4321
9876
6789
9999
1111
0000
one of these should work
hope this helped
please rate well.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Mar 06, 2009 | Nokia BH-600 Wireless Headset
Samsung KCds 24B LCD
1- Press transfer
2-Dial 800
3-Enter passcode = (try 4321 or 1234)
4-Press 1
5-Press the speaker btn
6-Dial 505
7-The display will show:
WMMDDYY:00:00
mm=2 digit month
dd= 2 digit day
yy=2 digit year
Nov 13, 2008 | Samsung Prostar DCS-24B-LCD Corded Phone
Need Tech. Prog. Passcode
Some one has changed the pass code from the default value, the kiss of death as far as I'm concerned. Try the ADMIN option by pressing TRNF 200 and use pass code 1234, The programs you can change in that section is limited but you may be able to get to Program 601(the one you need) by using the ADMIN access. If that won't do it. You will have to get a Samsung Tech to default your system and reprogram back with the default codes.
Good luck
Nov 07, 2008 | Samsung Prostar DCS Phone
Samsung prostar dcs compact pbx
default pw is 4321 (Technicians pw) 1234 (Customer Pw)
Feb 20, 2008 | Lands Phones
Samsung DCS 12 Corded Phone Logo
131 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
