Question about Dishwashers
My dishes are still dirty and it leaves a white film on them.I was wondering if it has a filter or something that needs cleaned out.
  • krissyandrus Oct 10, 2010
    yes, very helpful, Thanx.
  • 10,865 Answers
Hello Krissy. Toss two cups of white vinegar into the empty dishwasher. Run the hot water in the sink until it is as hot as it gets. Then turn on the dishwasher using the longest and hottest cycle you have. This will thoroughly cleanse the machine.
Repeat this procedure as needed or at least once a month. Make sure you always run the hot water into the sink until it is as hot as it gets. This will ensure that you are doing the dishes with the warmest possible water. Also, rinse your dishes and pans thoroughly before placing them in the dishwasher.
Regarding a filter, no there is no filter and nothing that needs cleaned out. The only exception would be the drain line if you find that the problem persists. THe drain line goes from the base of the dishwasher to the trap under the sink. Joe
Posted on Oct 10, 2010
Fixed problem after viewing 93 code but now dishes have brown film or white film. Dishes still dried on food. Have a Samsung DMT800RHS. One suggestion was to get phosphorus which is ******* for deterg
look at the arm that has the water nozzles on it to see if some of them are plugged. Also make sure the screen at the bottom of the machine isn't restricted.
Nov 06, 2014 | Samsung DMT800RHS Dishwasher
It is 6 mos old and it leaves the dishes dirty and with a white film on everything. I used jet dry, cascade with no results. what would cause this? it has done this since day one. thanks
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 23, 2011 | LG LDS4821BB 24 in Builtin Dishwasher
Our dishwasher doesn't seem to be getting the dishes clean anymore and leaves a residue. We have changed detergents and all that, but to no avail. Is there a filter or something that needs to be cleaned...
heatman101
Feb 11, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Ge Triton dishwasher GSD5500GOOWW was not cleaning like it used to- I cleaned screens at back bottom-very dirty- also-detergent cup stuck opne - took door apart and got it unstuck - it works fine now. - it...
heatman101
Jan 23, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
It' no longer cleaning my dishes
hello,
If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
thanks.
Oct 23, 2010 | Dishwashers
Dishes are still dirty at the end of the cycle
hello,
hope this help?
thanks.
Oct 23, 2010 | Kenmore Dishwashers
White residue left on dishes; Plastic ware being oxidized
heatman101
May 10, 2010 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Not cleaning dishes, leave a cloudy film on silverware
the problem is hard water. you need a dishwasher filter and your problems will be solved. you can get one at www.dishwasherfilter.com and it is guaranteed or your money back. you will love the way your dishes come out.
May 31, 2009 | GE Dishwashers
Dishes are not coming out fully clean
first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Poor/Uneven Wash Quality
there is a new product out that filters the water going into your dishwasher. it works great and my dishes look fantastic. they use to look dirty with a white film on them. after the first load when i hooked up the dishwasher filter my dishes looked brand new. it is affordable and works everytime. you can get it at www.dishwasherfilter.com.
Oct 11, 2007 | Kenmore 15529 Built-in Dishwasher
Dishwashers Logo
110 people viewed this question
Top Dishwashers Experts
