Question about MagLite 4 Cell C Flashlight Black
Cannot get the end cap off a maglite 4 d cell flashlight. Does it screw on or push in ?
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. The end cap unscrews.
Posted on Oct 10, 2010
Replace batteries
Marcia Boal... hello,
If our battery has corroded it may be impossible to get the end (opposite the light) cap to come off. The light is designed to be moisture resistant... Likewise even penetrating oil cannot get in...
To guarantee long reliable service it is best to put a tiny dot of grease on the threads on assembly.
Maglite Solitaire makes a wonderful little flashlight...
(all metal construction... single AAA battery)...
((Mini = 2 AAA batteries... opens the same)).
Basic colors included black, red, silver & blue
but this particular light was also quite popular for commercialization... often displaying many BIG NAME
COMPANY LOGOs.
The initial closure of the end cap can be quite loose to be effective because of it's O-ring design... however some folks put the end cap on too tight...
The
It might take some serious force to get it open again.
Consider using a piece of leather in a pair of pliers to avoid marring the case. Reassemble without over-tightening.
Hope this helps!
Maglite Solitaire Incandescent 1 Cell AAA Flashlight Black Basic Handheld...
Amazon com Maglite Solitaire Incandescent 1 Cell AAA Flashlight Blue Home...
Maglite Solitaire LED 1 Cell AAA Flashlight Red Basic Handheld Flashlights...
Maglite Solitaire LED 1 Cell AAA Flashlight Silver Basic Handheld...
Aug 19, 2016 | Camping, Backpacking & Hiking
Maglite 2aa back cap won't come off
SOUNDS LIKE IT IS CORRODED. PUT A FEW DROPS OF RAPID TAP TAPPING FLUID OR A FEW DROPS OF THIN MACHINE OIL AROUND THE CAP. LET IT SIT FOR A FEW DAYS AND TRY IT AGAIN.
Feb 03, 2012 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
What is the alignment of the batteries in a 3d cell?
put the first one in positive side toward the light,, and the rest go in the same way, make sure the spring is attached to the base and screw it on, the positive side of the battery is the side with the bump on the end,, if it doesn't work after that ,, in the end cap of the flashlight you should have a extra bulb,, replace that and try it ,, be sure to put the spring back on the end cap
Aug 26, 2011 | MagLite Mag Instrument Mag Lite 2 "D"...
I have a 6 d cell maglite. when i removed the end cap 3 batteries came out number four is stuck in the maglite. how can i get it out?
Not sounding good. I have had the problem in the past with Mag lights and though they are good, I always seem to have battery corrosion problems. What I have done is to get a non-metalic rod, wooden doweling has worked for me, carve a bit of a blade at the end, sort of like a long screw driver and work it into and between the batter and flashlight case. Not so hard as to deform the flashlight, but to try and break the seal between the corroded (I assume) battery and the case. Spray in some WD40 and work the dowel in and around the battery. Stop on occasion and tap the open end of the flashlight on a heavy rag laid atop a piece of wood to try and jar the battery loose. By repeating this process I have been able to remove corroded batteries, but not necessarily save the flashlight, as some times the on/off switch is corroded as well. Once you get the batteries out you may be able to clean the inside with some abrasive (steel wool?) to clean out the corrosion, but as I said, you may not be able to save the light. Best of luck!
Aug 29, 2010 | MagLite Mag-Lite& Flashlight
Battery case does not open
make sures its being turned to the left, and if it will not come off, wrap duct tape around it to protect it and use large vice grips or pliers to get it off. Vice grips would be better as the lock but dont' lock them down too tight as you can dent the cap.
Jun 30, 2010 | MagLite Mag-Lite& Flashlight
Is there a rear cap on a mini maglite. I am
Yes there is a cap. I had the same problem most likely the battery inside has corroded and leaked fusing the cap shut, contact MagLite at www.maglite.com if there were either Duracell, Eveready or Ray-O-Vac batteries in there they will replace it for free under warranty.
May 26, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
We changed the battery pack and the bulb and it wont come on so the switch is prolly defective where do we find how to repair the flash light
Alot of maglites are problematic with symptoms like this... I have found that the culprit many times is the screw cap on the bottom of the flashlight.
The elecrtrical connection needed between the spring in the end cap, the threads on the cap and the threads in the barrel of the flashlight...
Make sure you twist your spring a bit..the dissimilar metals can actually corrode between the spring and the cap... Then spin the threads a little... Then try the flashlight again...
This procedure may save yourself replacing a switch..
Apr 29, 2010 | MagLite Rechargeable Flashlight System
Flashlight only works when end cap is partially on. Will not work when cap is fully screwed in. New batteries installed.
Some models of the famous MagLite use this 'feature' as the on-off switch. I have several such myself.
Thanks foryour interest in FixYa.com
please remember to vote
thanks
a
Dec 05, 2009 | MagLite 3 Cell D Blue Flashlight S3D116
Keeps turning itself off when adjusting beam
It sounds like the spring in the tail cap may be depressed which would cause intermittent contact with the negative end of the Batt. Shake the flashlight vigorously, you should NOT hear ANY noise. If you DO, take the end cap off and pull on the spring, you are trying to stretch it out a bit, replace the cap and shake it again. Go through these steps until it is QUIET when you shake it.
Also make sure there's NO CORROSION at the Positive and Negative ends of the contacts.
Maglites are pretty user friendly and the best light money can buy. I have the rechargeable model which I carried for 21 years during my tour in law enforcement.
Anyway, if it still refuses to work properly, go to; www.maglite.com they are based in California. They will help you get it going. Good luck. :)
Apr 12, 2009 | MagLite 3 Cell D Blue Flashlight S3D116
MagLite 4 Cell C Flashlight Black Logo
147 people viewed this question
Top MagLite Camping, Backpacking & Hiking Experts
John Egan
John Egan
David Black
David Black
Level 1 Expert
 steve
steve
Are you a MagLite Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
