Question about Bertazzoni Pro Series X304GGV Kitchen Range
I bought my wife a Bertazzoni dual fuel stove over a year ago. The local seller wanted $150 to put the orafaces in for LPG so I did it myself. That was no challenge but since I did that, they have no interest in helping me with a problem we have had from the start. All other functions are great. However, the oven heat is uneven and often spikes. We get odd burned spots (usually back left side) on otherwise perfectly cooked backed goods. I assume this is a thermostat issue but do not know where to start. Any ideas would be greatly appreciated. Jay
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: have trouble starting the oven to preheat
Don't open the door(heat escapes) Turn stove wide open. There should be aboslutly no upsetting small explosions goin on at all. My first thought is the generator is weak. These systems use a pilot generator to operate the flame. If that is not it then the flame sensor itselve is wired into the mix and that is intermittant. I have no way of knowing what type of system your range uses but i can only imagine with your description. cgange the generator. that is my first thought ,it is less than the oven thermostat. the oven thermostat would be the next faulty part in the line.
Posted on Jul 02, 2009
I have 48 " 6 burner stove natural gas.Stove is
the glass in the ovens should not crack when self clean is used. it could be that there was a minut crack in the glass or a build up of moisture in between to door windows that expanded at the extra heat but this should be brought up with the manufacturer for replacement.
I hope this was useful.
Jan 05, 2011 | Viking 48" 6 Burner, Griddle Professional...
I have a newhome1000df. can it run on lpg?
If it's designed to run on natural gas then usally the answer is yes but it will need to be converted the orifices for LPG are a different size than for natural gas. Trying to run it without converting is dangerous!
Jun 26, 2010 | Stoves 1000DFDL Dual Fuel (Electric and...
Can you convert any natural gas hobs to LPG?
They are convertible. Most come with converting parts attached to the interior of the range.
Feb 21, 2009 | Stoves 1200DFa Dual Fuel (Electric and...
I have a monessen LPG fireplace and the blower motor has seemed to stop working. it has a variable rotating switch on it. dont know if anyone knows where this problem is on most models like this?
The problem is likely the fan motor for the forced air blower, which means the entire blower needs replaced. The description of the problem is the same problem we had approximately two years ago when our motor was still under warranty (less than a year old). In our case the motor was replaced without charge. However, the same problem has happened this year which is extremely disappointing since we only run the fireplace from December to April intermittently because it is only a supplimental heat source for the house. You can either look up the model number and part number and order a replacement over the web (less expensive if you are DIY and know what you're doing) or see if the local LPG supplier can repair the part or replace. Good luck.
Dec 06, 2008 | Stoves Monessen Variable Thermostat...
Gas convertion
stoves have a pressure regulator as the flex line from the house connects to the stove, it's about 2 inches by 3 inches in dimension and it has a knot in the middle and one to the side of it that is to the front of it that second one you can unscrew and put that knot the other way or upside down, that's the position for natural gas, now some regulators do not have it, in that case get one that can do that,or that is for lp and natural gas. then you must close the air a little bit on all the burners the vent is located as the burner meets the valve that supplies gas to the burners. and that vent is part of the burner.
May 18, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Conversion from Natural Gas to LPG
only source will be stoves or their service agents. if uk, stoves is same group as belling and parent company is morphy richards
Apr 27, 2007 | Stoves 1200DFa Dual Fuel (Electric and...
Bertazzoni Pro Series X304GGV Kitchen Range Logo
Top Bertazzoni Kitchen Ranges Experts
Dan Webster
Dan Webster
 Gary Gemmell
Gary Gemmell
Anthony Kelly
Anthony Kelly
Are you a Bertazzoni Kitchen Range Expert? Answer questions, earn points and help others
