Question about Whirlpool LER4634J Electric Dryer
The dryer stopped heating, The fluff air cycle still works but the heating cycles have stopped working. Is there an easy fix, or do I send it to the scrap metal yard?
  • Whirlpool Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 17, 2010
Dryer won't dry clothes in one cycle
Make sure a heating cycle is selected. Air and Fluff cycles do not use heat.
Make sure that both phases of 120 volt power are energized (total of 240 volts between the 2 phases).
Most likely the heating element is damaged, which usually means there is no heat at all. A dryer with 2 heating elements will have some heat, but not have enough, when 1 heating element stops working. A dryer with 1 heating element can partially fail and have partial heat, too.
Apr 03, 2017 | Dryers
How does the air dry cycle work?
Are you asking about the fluff or no heat cycle?? It just blows room temp air through your clothes. It would be similar to hanging them outside but with the drum tumbling them. This will of course take much longer to dry than with heat.
May 10, 2015 | Dryers
Ge front loader dcvh515efoww - dryer shuts off when put on heating cycle
Did you pull the dryer out or forward sounds like you may have pinched the exhaust which restricts air flow exiting the unit this will cause it to heat briefly shut down heat shut down and continue this cycle the fact that it worked before makes me think it something simple it will not tumble in any cycle if door switch not installed correctly.
Mar 21, 2014 | GE Dryers
Kenmore elite dryer runs for about 3 min. then trips the breakers
The circuit breaker may be tripping because of a fault with the dryer or it may be a fault with the circuit breaker being weak.
From the description you give the circuit breakers trip frequently.
I'd suggest you first try selecting the no heat air fluff cycle and run it to see if the breaker trips. If the circuit breaker doesn't trip in air fluff then there is likely a short in the heating element.
With a clamp-on amp meter you can read the amp draw of the dryer when it is heating. With the motor and element both working you would see approximately 25-26 amperes being drawn. The breaker is rated at 30 amps. If the breaker trips and only 26 amps are being drawn then the breaker is the problem.
Try the air fluff cycle first and see if the breaker will trip. Then with additional details I may be able to help you further.
Jan 05, 2011 | Kenmore Dryers
MDG4000BWW gas neptune dryer The timed dry/air fluff doesn't work until it gets to damp dry or wrinkle release. Works on the other cycles. Have removed lint screen & 4" hose cleaned and vacuumed.
on a timed dry cycle u are selecting the time it will dry
only after the time has run out will it tumble with no heat
on other setting the machine is stopping the heat and putting the machine into a cool down or air fluff mode
sounds like it isworking normally
(solv ya prob)
Oct 17, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Crosley CDE6500AZW heating, but drum not rolling
OK Here is what I think happened. I have heard of this before. You melted a wheel and that broke the belt. This is a simple dryer to repair and parts are not that much. Well worth fixing. Start by popping the top remove the front then get the drum out and inspect the damage.
Mar 01, 2009 | Crosley CDE6000 Electric Dryer
DRIER OVER HEATS, WORKS ONLY ON "FLUFF" CYCLE
You need to have the thermostats tested by a qualified servicer.
May 21, 2008 | Crosley CDE6000 Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
