Question about Nokia Classic 2700 Cell Phone
When i turn on my phone,the message contact service appear how i can format my phone manually
  • 37 Answers
You just have to do that to open settings then there will be the last option named restore factory setting you have to click it mobile will ask for security code after giving security code , , , it will be formated then you have to switch off your phone and on it again but you have to be careful because some time data is removed
Posted on Oct 10, 2010
Start up failed please contact your retailer. this is the message i get whenever i open my nokia 5230. what should i do? thanks!
Try to manual format your phone. Here's how;
1. Turn off your phone first.
2. Hold and press Green + Red + Camera button and Power button. Wait until phone vibrates.
3. Release Power button and wait until the selection for your location appears.
May 31, 2011 | Nokia 5230 Cell Phone
When i power on my n95 8gb its writing : phone start-up failed. contact the retailer . what i must do
hi
there must be software corruption in your mobile. kindly format your phone . this will able to fix your problem if still having this problem means then there must be some hardware problem in your mobile. kindly ask your service provider to fix this problem. but formatting your phone will fix your problem
thank you
Dec 20, 2010 | Nokia N95 Cellular Phone
I have a motorola razr v3 and it was asking for a subsidy code then when i found a code and turned the phone back on it says contact service provider and there isnt a way to enter the code does any one...
If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you already entered too many wrong codes, you just have to let the phone ON on theses errors messages and after 40 min to 2 hours, the message "Enter Code Special" will appear again !
please try again after some time.
Hope this information helps you
Thank you
Oct 02, 2009 | Motorola Mobility RAZR V3
I am getting an error cf..tried to format card and get error 99
I Googled the error code you're getting, and found a list of things to try and steps to attempt directly from Canon. Try out some of the stuff below, it should help.
To isolate the cause of the issue, we suggest that you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Message Contact service Nokia 6021
It sounds like it has gone into secure mode...have you entered any codes unsuccessfully into your device before it did this? If you entered any codes in before this happend and you have turned off your phone and turned back on and it's still doing the same thing..unfortunately anything you saved to your phone is a loss cause.
Feb 11, 2009 | Nokia 6021 Cellular Phone
On receiving message it automaticall goes into outbox and sends back to sender as MMS
i'm pretty sure your phone or mmc is infected by a virus, format both your mmc and phone, hard format i recommend,
hard formatting
make sure you backed up all important details, especially your contact
fully charged your phone
procedure: switch off phone, press hold: ' *' , '3' and the send key, the green one, while holding this turn on your phone if you can do it yourself or let someone else do it. Don't let go of the three keys you are pressing until the word FORMATTING appears on the screen, then you can let go
Oct 13, 2008 | Nokia 6600
Contact Service
hi,
Please try to hard format your phone..the procedure is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button,While holding these buttons, press the power button and switch on the phone.When the message ‘Formatting’ appears on the screen, release all of the buttons..please note that you will lose the datas in your mobile after doing this..hope this solves your problem else please take your mobile to nokia customer care..thank you!!..
Jul 06, 2008 | Nokia 6300 Cellular Phone
"Connection Error" - Nokia 7610
hi there did you try to reset the phone? but first must backup the phone contact. now to reset the phone just input the code: *#7370#.
then if the problem still the same. final is to format the phone, no problem cuz' you can manually format that phone by holding 4 keys. here's the trick
power off the phone first then PRESS and HOLD
"CALL KEY" + "* KEY" + "3 KEY" then power on the phone just hold and wait till FORMATING appears then release after formating finish phone will be ok. DONE
ok!
peace!
Mar 26, 2008 | Nokia 7610
Problem is""phone star-up failed. contact the retailer"
The best solution for this problem is to format the phone memory. U may think format will erase all applications but it is false . The essential softwares like mp3 player, camera, etc. are not erased.
The process for format of phone is :
1) turn off the mobile.
2) press and hold ( green dial button + 3 keypad + * ) and turn on the phone holding these 3 buttons(dial button + 3 + *) until formatting screen appears.
3) When formatting screen appears, just leave the keys. and ur phone is formatted now.
4) When finished, it asks for restart of phone.
5) Restart ur phone, and ur phone is ready.
Sep 09, 2007 | Nokia 3230
Nokia Classic 2700 Cell Phone Logo
49 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
