Question about Pitco Frialator Kitchen Appliances - Others
Fryer maybe leaking propane
I have a pitco fryer #35c+ it is brand new
when i put it on pilot and light it and turn it to the on position i felt air coming from the on/ off/ pilot knob is that normal should i turn the thermostat up.
    Champion:
  • 254 Answers
Hello
To see if this is leaking you can make a soap solution of 1 tablespoon of dishwashing soap to 1 cup of water to see if it bubbles. Just apply it around the knob on the gas valve or pilot valve.If it bubbles it is leaking and will need replaced. This will rule out a draft of air coming from somewhere else.
Hope this helps
Posted on May 31, 2008
Instuctions on how to change a pitco fryer from nat gas to propane
Hi there!
You need to order a gas valve conversion kit (from nat to propane), propane pilot orifice and propane burner orifice,
Gas valve conversion kit consists of a replacement spring thicker than of natural gas valve spring, gas valve cap and a sticker.
Pilot orifice for propane has smaller bore than of natural.
Burner orifice for propane has also smaller bore than of natural burner orifice (one for each burner).
You will be able to find these parts on the list of Pitco Distributor when you visit http://www.pitco.com
Regards.
Jul 08, 2012 | Pitco Frialator E24 Deep Fryer
Burner problem
Hi there!
Check the incoming gas pressure.
Insufficient gas pressure will greatly affect the unit's efficiency.
Regards.
Apr 03, 2012 | Pitco Frialator 35CS Deep Fryer
I have a pitco 35c fryer the pilot light will light but the flame is very low it goes out when i release the controll the pilot light adjustment has no effect on flame i have the right amount of fuel...
Check and clean the thermopile, it is the cylindrical piece of metal standing behind the pilot assembly.Try also to tighten its wiring connections to the gas valve and high limit.If it does not correct the problem, replace the thermopile.
Apr 06, 2011 | Pitco Frialator 35CS Deep Fryer
My pilot light is out on pitco 35cs fryer, i cant locate it to relight it
Pilot assembly is located between the two middle burners, this is where the pilot is lighted. You have to turn the gas valve knob to pilot position then push it while lighting the pilot assembly.
Jan 27, 2011 | Pitco Frialator 35CS Deep Fryer
I am converting a pitco model 14c fryer from nat gas to propane, and am wondering where does the pilot oriface install at. It looks like a small cap with a hole in the end. Thanks Jim
The pilot light is attached directly to the front of the pot near one of the burners. You will see one small gas line and a set of wires. Loosen the nut where the gas line goes into the pilot light. You will have to hold the pilot light as well as turning the nut on the line. Pull the line from the pilot light assembly. Sometimes the pilot orifice comes out with the line and other times it stays stuck in the pilot light. If it is stuck take a small blade like a pocket knife and pry it out. put the new one in and tight it all back up
Oct 02, 2010 | Pitco Frialator SG14 Deep Fryer
Pitco frialator (propane)
Better check the incoming gas pressure first, it should match the requirement as stated on the nameplate. Low gas pressure will make the pilot flame small until it could not heat up the thermopile which will shut both main burner and pilot flame.
Apr 11, 2010 | Pitco Frialator SG18S Deep Fryer
Lighting the fryer
If this is a milivolt unit, meaning no solid-state or computer/digital controlled. You would need to turn your gas valve to the pilot position, then press in and hold until you can light the pilot using a lighter (this may take several minutes, to bleed the air from gas supply) once there is a pilot flame present, you will need to hold the valve button in for about 45 seconds to heat the thermalpile. Once pilot is lit, thene turn to on position and proceeed to turning thermostate to set temp.
Scoota
Jan 25, 2009 | Pitco Frialator SG14 Deep Fryer
Converting a pitco frialator from natural gas to propane
you need to change the pressure regulator,burner orfices and possibly the gas valve.goto northernparts.com and type in the model of the fryer for propane
Dec 12, 2007 | Pitco Frialator SG14 Deep Fryer
Kitchen Appliances - Others Logo
110 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
