My name is Peter. I am a retired field refrigeration technician.
It sounds like your ice maker has a bad motor module/circuit board.
It is like a control board. This module reads a temperature sensor that indicates the water is frozen and ready for harvesting the ice cubes. Then it turns on a electric heater under the ice cube mold, then turns on the motor to harvest the ice cubes. After the ice cubes are harvested, it opens the water supply solenoid valve to fill the mold with water. The ice maker needs to be replaced.
Need more info. Are there ice cubes in the storage section just behind the freezer door? You may have turned the ice-maker OFF. When your depress the ice flipper, does the motor run behind the door? The motor may be burned out or the ice cubes in the storage section are so melted together in a giant glob that the agitator cannot turn.Or, maybe someone turned OFF the water supply.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Here is a tip that I wrote about the reasons why ice makers do not work.
Problems not related. The first is most likely the fan, or possibly water dripping on to the fan and freezing, but usually the noise comes from the fan struggling to run. The cube problem could be as simple as the ice dispenser being put back in wrong. There is a metal lever under the ice tray that switches between crushed and cubed. Make sure it is seated properly.
We will need to check the voltage at the auger motor while depressing the dispense switch. If all the other features work on the dispenser panel while I would consider checking the voltage going to the motor. Some auger motors are in areas where water causes the voltage to be shorted by constant moisture. We will need to remove the panel and simulate what you have done on the outside but this time we need to see if the voltage has been altered or if the auger motor itself is defective. Sea Breeze
You have a solenoid switch which switches the dispenser back
and forth from crushed to cube. It could be stuck or not working or the parts
connecting it could be disconnected or broken. You will have to observe to see
if any parts are moving and if any noise is coming from the solenoid. With your model number I can find a diagram which may help.
THE SOLENOID IN THE ON THE ICE MAKER MOTOR IS NOT WORKING IT HAS ICE BUILD UP ON IT OR IT HAS A SHORT IT PULLS THE PLUNGER THAT OPENS THE FLAP THAT LET ICE CUBES FALL OUT. REMOVE ICE MAKER AND THER ARE 2 5/16 SCREWS THAT HOLD PANEL IN THEN UN PLUG MOTOR AND USE HAIR DRYER & DEFROST MOTOR AND SOLENOID SHOULD WORK IF NOT MAY NEED TO REPLACE SOLENOID.
First pull out the ice bucket and close the door. Set for cubed ice. Press the button for ice to come out and listen for a loud clunk noise. That is the sound of the solenoid. You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down. Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into. If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work. If solenoid is not working then it will need to be replaced. Let me know what you find.
Behind the ice bucket is a metal housing that holds the auger motor and solenoid. The solenoid is bad. When you go for cubed ice that solenoid should pull up the metal rod on the ice bucket so full cubes will come out. First check to make sure the metal rod on the ice bucket isn't somehow caught under the solenoid and not letting if move up and down. You can take out the ice bucket and press for cubed ice. You should hear a loud clunk noise. If not then you know the solenoid is not working.
