Question about Toshiba Satellite P15-S470 (PSP10U-0GGPGR) PC Notebook (PSP10U0GGPGRPSP10U0GGPGR) PC Desktop
Need to reset the bios password
My kids were screwing around with the laptop and set the bios password. now it will not boot up and i cannot get into the bios setting to verify things are correct. on my desktop pc's I could go in and set a jumper to reset the bios. does this toshiba P15-S470 have a similar jumper?
I have had the laptop apart to clean out the cooling fins on the power supply and to replace the hard drive and combo drive, so I am not afraid to take apart again. I just need to know where to look for the bios reset feature.
My sat came with a password installed on it and i had to remove the cmos batt to reset the was located on the right side of the comp under the keyboad, covered by a black piece of tape.
Posted on Jun 08, 2009
  • 813 Answers
U have to reset your bious u have remove the battery from the motherbord few mins then put it back turn on your pc & your bious is reset & passowrd has been removed
Posted on May 31, 2008
Unknown bios password prevents bootup
Ah, those darned unknown passwords on second hand or stolen laptops, or where the kids go off to their new lives and leave you with the laptop you bought them for university :>)
  • Removing BIOS password on Toshiba Satellite Laptop - YouTube
    • 4 MIN
    • ADDED 2012-10-06
    Video embedded · This video will describe how to reset the BIOS password bug on a Toshiba Laptop. What you will need to make sure you do before getting started:
  • Reset Toshiba Satellite BIOS Password ' Find Password Heres a quick and dirty way to reset the password on the Toshiba Satellite A205 BIOS. Warning! You can only use these tips on your own Toshiba computer if you forgot ...
  • Passwords: setting and removing (for BIOS, Supervisor, and ... Passwords: setting and removing (for BIOS, Supervisor, and Windows passwords) ... If you forget the BIOS password, only a Toshiba Authorized Service Provider can ...
  • Jan 09, 2016 | Toshiba Satellite A205-S5804 Notebook
    if its a dell contact support they can reset that if its a ibm your screwed .sorry any other bios password as long as boot up is not requiring a password you should only be limited to changing settings not the use of the laptop
    Mar 01, 2013 | Systemax SYX Venture Mobile XVI.B Notebook...
    Fijustu ah530 corei 5 bios password
    BIOS on a Fujitsu C-Series LifeBook b> Resetting the BIOS system of a computer can help revitalize the computer's usage. Oftentimes computers are "broken" when they are misconfigured in the BIOS menu of the computer before it boots up. When the settings are improperly selected, the BIOS prevents the computer from working properly. To get the computer back up and running again, the BIOS needs to be reset. The Fujitsu LifeBook C2111 has its BIOS system located on the motherboard beneath the keyboard.
    Turn the Fujitsu laptop over with the computer powered off. Remove the AC adapter and push the battery release latch in and pull the laptop battery out of the Fujitsu. Remove the screw holding the hard drive in place and slide the cover off of the laptop. Remove the two screws underneath the cover that holds the hard drive onto its bracket. Slide the hard drive out of the laptop. Turn the computer back over and lay the screen down so that it is parallel to the surface on which the laptop is resting. Remove the small screw above and to the left of the keyboard with the Phillips screwdriver. Push the keyboard toward the screen until it disengages. Fold the keyboard over the screen and rest it there with the keys facing the screen. You will now see the motherboard of the Fujitsu C2111. Locate the small, round lithium-ion battery on the motherboard and remove it. This is the BIOS battery that stores all of the settings and password of the BIOS when the computer loses power. Hold the power button in on the computer to drain the BIOS system and leave the battery out of the laptop for at least 30 minutes. Place the BIOS battery back into the motherboard and reattach the keyboard. Tighten the keyboard screw that you removed earlier, and turn the Fujitsu back over and reattach the hard drive along with the covers for the hard drive and RAM. Push the computer battery back into place and attach the power cable to the computer. Turn the Fujitsu back on and the BIOS menu will be reset.
    or b> Start the computer and press the "F2" key while the system boots, if the computer is currently off. If already on, restart the computer and press the "F2" key while the system boots. The BIOS setup utility will appear. Press the right arrow on the keyboard and scroll over to the "Exit" tab. Press "Enter." A drop-down menu will appear. Scroll down to "Default Settings" using the down arrow key and press "Enter." A dialog box will appear, asking if you are sure you want to load the default settings. Scroll over and select "OK" using the arrow keys and press "Enter." All BIOS settings will reset to the default value. Scroll back to the "Exit" tab using the arrow keys and press "Enter." Scroll down and select "Save Changes and Power Off." Press "Enter." The computer will save the default BIOS settings and power down. Fujitsu Lifebook T Series b> Restart your Fujitsu Lifebook T Series computer. Press "F2" as soon as the computer starts booting. Enter your current BIOS password if prompted. Use your right arrow key to select the "Security" menu. Use your down arrow key to select the password you want to reset. Press "Enter" to select the password. Enter the current password when prompted. Enter your new password or a blank password if you want to clear the password. A blank password resets the BIOS password completely, meaning you do not have to enter a password to enter the BIOS or boot your computer. Press "Enter" to save your password settings.
    Repeat the process if you have multiple passwords set. Press "F10" to save all settings and exit the BIOS.
    Jan 30, 2013 | Fujitsu LifeBook AH530 NoteBook
    My ACER TravelMate 5530 laptop is now asking for it's BIOS password. Can you help?
    Get onlineand got to In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Documents and Manuals. Scroll through them looking for Bios Password or Reset Bios Password.
    Apr 14, 2012 | Acer Computers & Internet
    Don't know BIOS password
    Here's how to reset password
    Resetting a Toshiba BIOS Password KeyDisk will reset the BIOS password on Toshiba laptops.
    Older Toshiba laptops can be convinced to boot without their power-on BIOS password by attaching a dongle to the parallel port which crosses a number of the pins. The pin out is:
    Pins 1-5-10 2-11 3-17 4-12 6-16 7-13 8-14 9-15 Some Toshiba's can be convinced to bypass the startup BIOS password if you hold down the <LEFT-SHIFT> key while booting the system.
    Jul 25, 2010 | Toshiba Satellite A105 Notebook
    I am working on a toshiba satellite l355-s7915. the owner's kid forgot her password, so I tried to remove the password with hirens active password changer, which failed. when I started up the computer, it...
    Yes of course all Laptop and Desktop have CMOS battery. Screw the back cover of your laptop locate the CMOS battery and remove to clear the BIOS password. Or else you can reset the CMOS by removing the jamper.
    Mar 29, 2010 | Toshiba Satellite A135-S4527 Notebook
    Toshiba satellite a215-s7437 bios pw
    For that you need to reset factory defaults settings for bios.
    For reset bios u have to open back side of your laptop then u find motherbord circuit there.
    pull cmos cell on motherbord for 15 minute then it reset to defaults.
    Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
    It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
    then again set it in 1-2 its original position.
    Then it not want password.
    Jun 21, 2009 | Toshiba Satellite A215-S4747 Notebook
    Bios password for toshiba laptop needs reset
    Try This: Resetting a Toshiba BIOS Password KeyDisk will reset the BIOS password on Toshiba laptops.
    Older Toshiba laptopsmag-glass_10x10.gif can be convinced to boot without their power-on BIOS password by attaching a dongle to the parallel port which crosses a number of the pins. The pin out is:
    Feb 14, 2009 | Toshiba Portege S100-S1133 Notebook
    Resetting the "Power On" password
    Power off laptop. Disconnect mains pack. Remove battery pack. Wait 30 sec. Connect just mains adaptor. Press power on button. press f10 for bios settings. Your passwords are now cleared
    Nov 03, 2008 | HP Compaq nx6110 Notebook
    Satellite A215-S7416 Bios Password
    There is a jumper that will clear the BIOS password on most of the newer Toshiba laptops such as this model. Here is a link to an article showing where the jumpers are located on various models of Toshiba laptops.
    I hope this helps, if so please rate my solution.
    Jul 17, 2008 | Acer Aspire 3680 Laptop
    Computers & Internet Logo
    386 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
