Question about Dual XD-7500 CD Player
No memory every time I turn the car off the settings are erased, how do I fix this?
    Brigadier General:
  • 6,966 Answers
Most current car head units requires two (2) kinds of B + supply; the yellow should be connected to an always on/constant B+12 such as the positive terminal of the battery. This is responsible for the memory and setting/configurations not to be erased when powered off. The red wire is connected to a switchable B+12 such as the ACC terminal of the IGN switch making the radio work only when the key is turned to ACC. Of course,the black is connected to the chassis/ground.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 31, 2008
How do you reset a pcm on a 2004 volkswagen jetta
Pull the battery negative cable of for 30 minutes. This erases the keep alive memory and set it to factor defaults. If you are want to erase codes and get the check engine light off. You need a code reader or scanner. If the problem has been fixed. The light will come back on if not fixed.
Feb 06, 2015 | Volkswagen Cars & Trucks
My computer has one long beep 2 short beeps, I put in new RAM and still does the same.
One, if I may; clean the gold plated contact pins with a pencil eraser, use air to remove the eraser dust. THEN try again before buying new Ram Memory.
(You are Following Anti-Static Precautions, right?)
Unplug the computer from power. Press the Power On button in, and hold for a count of 10 seconds. Let go.
Do this procedure two more times.
Plug the computer back into power.
What this does is clear CMOS Error Codes, and resets BIOS Setup back to the factory default settings.
We are just trying to clear CMOS Error Codes.
WAIT 1 minute, turn the computer on.
Still no?
'Slap' BIOS around a little bit.
Hold the Power On button in for a count of 10 seconds, or until computer turns off.
WAIT 1 minute, turn the computer back on.
I had to do this 3 times, one time, in order to get BIOS to recognize the new Ram Memory.
A) Ram Memory HAS to be in Slot 1. (DIMM 1)
That is the ram memory slot the Processor reads first.
Don't care about the other Ram Memory modules at the minute.
Just want to make sure a module is in Slot 1.
B) Are you SURE you have the correct Ram Memory?
There is a TOTAL amount for the motherboard, and EACH ram memory slot has a Maximum amount also.
Install in Slot 1 first. Try computer. If it works, then install ram memory in other ram memory slots.
No didn't work?
Then install in Slot 2.
You may find one of the ram memory slots is bad.
Regards,
joecoolvette
Feb 28, 2013 | ASUS M4N68T-M-V2 M4N68T-M V2, Socket AM3,...
Fax memory full
To gain extra memory, you can turn off Fax Storage OR Print fax messages in memory (See Setting Fax Storage, page 48.) OR Expand the machines memory.
Retrieve or Erase a Fax
Press 9 6
then to
Retrieve all faxes Press 2, then enter the number of remote fax machine and then press # #. After
the beep, hang up and wait.
Erase all fax messages Press 3. If the data stored in the memory has not been printed before, it will be printed first and then erased.
Setting Fax Storage
If you set Fax Storage to ON, you will be able to retrieve fax messages from another location, using Fax Forwarding or Remote Retrieval functions. The screen will indicate when you have a fax stored
in memory.
1 Press Menu, 2, 5, 2.
2 Press left arrow or right arrow to select ON (or OFF), and press Set when the screen displays your selection.
3 Press Stop/Exit.
If there are faxes in memory when you turn the Fax Storage OFF, the screen prompts you to erase any faxes in memory.
If you press 1, all fax data is erased and Fax Storage is turned OFF. If the fax data in memory has not been printed before, it will be printed first, and then erased. If you press 2, data is not erased, and Fax Storage remains ON.
Feb 07, 2012 | Brother FAX-8360P Plain Paper Laser
I accidently erased the memory on my panasonic cq-vd701u how can i restore it?
There is no way to restore the memory that was erased as there is no temporary back in the set.
You will need to reset the memory once and take care of any accidental erasing next time.
Oct 27, 2010 | Panasonic CQ-VD7001U Car DVD Player
Check engine lite stays on
have it tested for the fault code that this light set in the engine control computers memory, pos the fault code back here and i will tell u what to look for to fix it.
Jan 20, 2010 | 2002 Kia Rio
Cannot erase the key memory for the seat on my
try disconecting the batery for 10 - 15 min it might reset the base comands and recorded features
Jan 03, 2010 | 1998 Porsche 911 Carrera
OUR FAX SAYS 98% MEMORY FULL SOMETIMES WHEN THEY TRY TO FAX SOMETHING. HOW DO I CLEAR THE MEMORY? NATALIE
Press Menu, 2, 5, 2. The screen prompts you to choose a fax setting. Press <-- or --> to select OFF then press SET. If there are faxes in memory when you turn Fax Storage to OFF, the LCD prompts you to erase faxes in memory. If you press 1, all fax data is erased and Fax Storage is turned OFF.
You may want to enable Real Time TX so you can send fax without using memory. (Under FAX-SETUP SEND-REAL TIME TX)
You may also disable Fax Storage if you don't want to store incoming faxes in memory for remote retrieval (Under FAX- REMOTE FAX OPT-FAX STORAGE)
For effective use of the memory, you may also clear the caller IDs stored in the memory. Press MENU, 2, 0, 2 Press the arrow keys to display # then press CLEAR.
Hope this helps!
Jul 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Ford mustang gt 2005 dtc codes
B1318 are related to low battery voltage .
B1202 is fuel sender circuit open.
P0463 is fuel level sensor circuit, (high input.)
If your gauge appears to be working o.k. all I would do for now is double check my voltage at battery with engine off & running, to make sure all is good there, erase codes & start fresh. The cheap way to erase is to remove neg (-) cable form battery for about 5 min., or more & then reconnect. You eill lose your memory on radio stations & have to re-set them though, otherwise have someone hook-up scan tool to erase them. Is vehicle starting & running o.k. at this time?
Feb 27, 2009 | 2005 Ford Mustang
My phone froze
reset all settings to default and format memory and after take bettery out and in then reset settings again and then turn phone on and off again then it should work make shure the memory card is clean and dont have any unrecognised files on it this can cause it to crash and format the memory card aswell just for better results but back up the memory before you do this because this will erase ALL data you have if this continues take it to get it fixed
Dec 19, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Stored radio stations and time erase when car is turned off
The radio was installed incorrectlly. Make sure the red wire from the radio is connected to a switched 12 volt source(has voltage when car is on, none when it's off) The yellow wire to a constant 12 volt(hot at all times) this wire mantains the radio memory and must always have power.
Nov 21, 2008 | JVC KD-G220 CD Player
Dual XD-7500 CD Player Logo
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
