Destination.msi issue (O/S = Vista SP1)
During boot up, windows installer is trying to find destination.msi at some default file path it thinks it should be but. I've been searching & searching forums and posts for answers and don't seem to get a good one... It would seem my registry cleaner killed it at some point. I think it has to do with a HP 6840 network printer installed on my network... I have searched the cd for the file to try to replace and don't seem to be able to locate it... Please provide some direction here...
  • ssb811 May 31, 2008
    Worked great after a refresher on DOS commands! Thanks!
    Problem Solver:
  • 19 Answers
1. Right click on Command Prompt and click Run as Administrator
2. CD to C:\Program Files\Windows Sidebar ( cd drive letter:\Program Files\Windows Sidebar )
3. Run these commands in this order:
1. regsvr32 -u sbdrop.dll
2. regsvr32 -u wlsrvc.dll
3. regsvr32 atl.dll
4. regsvr32 sbdrop.dll
5. regsvr32 wlsrvc.dll
And start up the side bar
Posted on May 31, 2008
Microsoft Windows could not start the windows installer service on local computer error 3: the system cannot find the path specified
What is the Operating Software? If It XP SP1 or 2 you have install windows installer version 3
Sep 04, 2014 | Computers & Internet
Nti backup now error message during installation
Install the software before plugging the device in. You may have to uninstall first. Right - Click on the installation file and click ' Run as Administrator'
Dec 05, 2013 | Computers & Internet
How to create a bootable Windows XP SP1 CD
Using nero .
Step 1
Create 3 folders - C:\WINXPSP1, C:\SP1106 and C:\XPBOOT
Step 2
Copy the entire Windows XP CD into folder C:\WINXPSP1
Step 3
You will have to download the SP1 Update, which is 133MB.
Rename the Service Pack file to XP-SP1.EXE
Extract the Service Pack from the Run Dialog using the command:
C:\XP-SP1.EXE -U -X:C:\SP1106
Step 4
Open Start/Run... and type the command:
C:\SP1106\update\update.exe -s:C:\WINXPSP1
Click OK
Folder C:\WINXPSP1 contains: Windows XP SP1
How to Create a Windows XP SP1 CD Bootable
Step 1
( no download manager !! )
Extract file (xpboot.bin) in to the folder C:\XPBOOT
Step 2
Start Nero - Burning Rom.
Select File > New... from the menu.
1.) Select CD-ROM (Boot)
2.) Select Image file from Source of boot image data
3.) Set Kind of emulation: to No Emulation
4.) Set Load segment of sectors (hex!): to 07C0
5.) Set Number of loaded sectors: to 4
6.) Press the Browse... button
Step 3
Select All Files (*.*) from File of type:
Locate boot.bin in the folder C:\XPBOOT
Step 4
Click ISO tab
Set File-/Directory length to ISO Level 1 (Max. of 11 = 8 + 3 chars)
Set Format to Mode 1
Set Character Set to ISO 9660
Check all Relax ISO Restrictions
Step 5
Click Label Tab
Select ISO9660 from the drop down box.
Enter the Volume Label as WB2PFRE_EN
Enter the System Identifier as WB2PFRE_EN
Enter the Volume Set as WB2PFRE_EN
Enter the Publisher as MICROSOFT CORPORATION
Enter the Data Preparer as MICROSOFT CORPORATION
Enter the Application as WB2PFRE_EN
* For Windows XP Professional OEM substitute WB2PFRE_EN with WXPOEM_EN
* For Windows XP Home OEM substitute WB2PFRE_EN with WXHOEM_EN
Step 6
Click Burn tab
Check Write
Check Finalize CD (No further writing possible!)
Set Write Method to Disk-At-Once
Press New button
Step 7
Locate the folder C:\WINXPSP1
Select everything in the folder and drag it to the ISO compilation panel.
Click the Write CD Dialog button.
Oct 11, 2010 | Microsoft Computers & Internet
I'm trying to install Vista for a friend of mine on his computer. It uses vista boot loader 2.1.1 (or something similar) The first time it will boot just fine - vista will boot after first start and...
one check the crack make sure it is for what your installing ( i mean ver and sp) if all else fail try a differant crack you know as well as i do they dont all work all the time and check you registry cant tell you here but look in registry file
Sep 24, 2010 | Computers & Internet
Hard drive will not completely finish installing Vista Sp1.
Try booting in Safe Mode (press F8 during startup). Once in safe mode, see if you can see the update in the Add/Remove programs from the Control Panel. Make sure the select the "View updates" checkbox.
If it is there, try uninstalling it before you boot in regular mode again.
While in Safe Mode, also disable the automatic Windows update. You can then try to install it manually from the Microsoft site instead.
Microsoft has some more ideas on how to fix SP installation.
Jul 16, 2009 | Samsung HM060HI Hard Drive
Attempted to upgrade Vista to SP1 on an E-machine, during install, Norton reinstalled, upon rebooting - BSOD so I don't know if SP1 issue or Norton, or both. Using VISTA disk, the bar progresses and then...
Try booting into safe mode.
If you can, I suggest getting rid of Norton. The drivers are not compatable with vista.
Vista has a ton of issues and many types of softwhere will not run or work.
If you want a good virus software, use the new software from Microsoft.
Feb 21, 2009 | E-Machines eMachines Desktop PC
Yesterday my computer crashed and won't reboot. It runs Vista HP SP1, 64 bit. When I try to reboot, it either hangs on a black screen, or recycles to the boot options screen. When I try to boot from the...
Read this tutorial on JSKYS site.
Follow each step carefully. If you can't make the repair
with these the 64-bit version of
Windows 7 Beta at this link. If you lack the capability
to burn an ISO image to a DVD then skip this step.
We recently installed 7 onto a Vista loaded laptop
with a damaged boot sector. Your files will be saved to
a folder during installation. Once you complete the installation
of 7 you can reinstall Vista on the original partition.
This type of troubeshooting takes a bit of experience and a
load of patience.
I hope this will help you get your teeth into it.
Nate P.
Feb 01, 2009 | Microsoft Windows Vista Home Premium with...
reinstall your printer software again
I would also check your add remove programs see if anything like that shows and if so uninstall
also go to start programs startup if it shows in startup delete it
restart your system and then let me know if you still get the message on startup
I'll assi8st you further
Jan 19, 2009 | HP Hewlett Packard Pavilion a6130n PC...
My display drivers and audio drivers not supporting vista ultimate
you shouldn't have installed vista service pack 1
its a known issue with vista service pack 1
if u had vista before and u updated it to sp1...i would suggest you to either do a system restore and uninstall sp1
or install XP back
Jun 04, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
483 people viewed this question
David Payne
David Payne
