Question about Lexmark X5650 ALL-IN-ONE PRINTER
Needed to move printer to new laptop but cannot find my software driver to add printer as new device?
  • 340 Answers
I have TVSE 240 printer that have parreal port for PC conection, but in my New PC and Laptop this port is not available, how can i use this printer with my new PC and Laptop that have USB port only
With most printers there is a software download for your printer. Download and install the software should walk you through the process. That said, plug in the USB into your New PC and the software should find a driver, i don't know your OS, and it SHOULD work. You may not get the Full fuctions of the printer until you install the Full software for the printer. If this is your printer the software will be found here, in case you do not have it:http://www.support.xerox.com/support/phaser-240/downloads/enus.html?operatingSystem=win7x64 I do not see that it is wireless? Just connect to the New PC via a USB port in the rear of the new PC. Use Device and Printers on start menu to ADD a Printer. When you have added the printer, right click and choose Sharing, Share this Printer. Set up a Home network on the New PC that has the printer attached. Re-Boot. On your laptop set up to the Home network that you just created on the NewPC with the printer. Reboot the laptop, you will get a network message like Welcome to "your: network. Go to the laptops printer section in start menu and Add a Printer, it will pop up if configured correctly, some changes may be made in Network and Sharing. Now you can print through your network "wirelessly". if you need assistance respond to this post.
Nov 09, 2012 | Xerox Phaser 240 Thermal Printer
Bizhub 350 windows 7
After you connect printer in network just set up DHCP in your printer and from windows 7 (Devices and Printers, Add new networked printer) and job is done because windows 7 will recognize printer and install appropriate drivers.
If you have problem with that uou can set up Static IP Adress in printer and search by that IP, also you can download drivers and software for that printer from this link:
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productid=867
Feb 09, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
My printer (HP deskjet F4200 series) will not work. I tried installing the disk it came with, But it dosent work.
What is the operating system installed on your computer? Since you didn't mention the Operating System, I am unable to give you specific instructions. If your CD doesn't work or if it's not installing, you can try with another driver, to download it, click HERE and click the name of the Operating System installed on your computer on that page. Once the Operating system is selected, all the available downloads will be displayed, click +Driver and download it from there.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jul 06, 2011 | Computers & Internet
Hi... I need to connect my printer to my new Toshiba lap top
What printer do you have? You should check the manufacturer's web site for updated software (new OS). If the printer is an all-in-one, you should install full featured software before connecting the printer to the computer. If the printer is a USB printer, then just plug it in when directed to do so. If full-featured software isn't available, either a driver will be on that site or a generic driver may be part of the OS.
If you have an older printer that uses a parallel port, you will may need a parallel to USB adapter. If the printer is an all-in-one, then you need a bi-directional version of the adapter. (With newer Windows versions, the installation will require you to start the Printer Wizard. Click Start > Devices and Printers > Add a printer. Select Add a local printer if it will be directly connected. )
I hope this helps.
(networked printers also use the Printer Wizard)
Jun 19, 2010 | Office Equipment & Supplies
Can not find driver for Dell 964 to macbook
Dell does not offer any driver for Mac or Linux or anything but Windows XP and Vista. The best bet is to simply plug it in and try it out.
In Mac OS X 10.5, go into System Preferences and add it as a printer. You may need to choose Generic as the printer type. (In Mac OS X 10.4, use the Printer Setup Utility to add it.)
Also from System Preferences (or Printer Setup Utility), add it as a Fax.
Open the Image Capture utility to perform scanning.
Mac OS X supports most of devices without any additional software. However, in some cases it may only be able to regard it as a generic type of device and some functionality may be simplified or not available. In such cases, it is up to the vendor (ie: Dell) to provide software to support the extra/advanced features. But unfortunately (and not surprisingly), Dell don't.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 28, 2009 | Computers & Internet
No software disk to load 1700 into Dell 6400 Inspiron laptop.
In Windows, how do I install my printer? Most new printers, especially USB printers, come with installer programs. If you have neither installation instructions nor an installation program, you can use one of the following procedures to install most printers:
USB printers (Windows 98, Me, 2000, and XP only)
  1. Make sure that the USB cable is unplugged from your computer and your printer. USB devices work differently from older devices and usually need to have the drivers installed before you connect the device.
  2. If you have an installation disk, insert it into the drive. If there is an installer provided, it should run or be executed here. Follow its instructions, and it should take care of installing your printer in a few moments.
  3. If you don't have an installation program, plug the USB cable into your computer and your printer. This should trigger the Add New Hardware Wizard.
  4. Click Next, and then select Search for the best driver for your device. Click Next.
  5. Uncheck all options except Specify a Location. Click Browse. Browse to the disk, CD, or directory where your printer drivers are located. Click OK, and then click Next twice. Note: You can download some drivers from the web. Consult the web site of your printer's manufacturer, or see Where can I find driver updates for my Windows computer?
  6. When all the files are copied, click Finish.
  7. Turn on your printer. Windows should detect the printer's presence and finish the installation. If the option to print a test page is offered, do so. This will confirm the installation. Click Finish.
Jan 06, 2009 | Dell 1700n Laser Printer
Adding a printer without a disk
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=90809&lc=en&cc=us&dlc=en&submit.y=1&submit.x=6&lang=en&cc=us
go here select your operating system and download the driver/software that your need for your printer. Install the software and connect your printer when you are asked to.
I hope this helps
Dec 30, 2008 | HP PSC 2175 All-In-One InkJet Printer
Hp printer f2180...usb device not recognise
Mate, I gave up completely for the night when I got mine and had similar issues. Some help though.....
First, make sure the USB Port is a 'powered' port (i.e. one that's in your PC or Laptop and not from a plug in HUB). That's needed. Secondly, the install software is ****, so I ended up installing the drivers by downloading them and the install tool from the following website (you can't do it form the CD):
http://h20180.www2.hp.com/apps/Nav?h_product=3177559&h_tool=software&h_lang=en
Just select the Printer Only driver. Once done, this doesn't present the device to your PC as a printer, so you have to go into the Control-Panel / Printers and Faxes / Add Printer and add it manually. you'll be asked to select the PORT for the device, and you need to select USB Virtual Printer Port. Then it will just go through whatever it goes through and install it. When you next Reboot, it will then install all of the other stuff to link it to the generic HP software it loaded off the CD. Seems to do that all by itself. Good Luck.
May 06, 2008 | Office Equipment & Supplies
ADD A DEVICE????
Remove the old and reinstall the new. First go to Control Panel/Add Remove Programs and remove the old software package. HP has a software cleaning utility to *really* remove all the old driver files. i suggest you run through that utility, Then install the new drivers/software for the new device.
Jan 15, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Lexmark X5650 ALL-IN-ONE PRINTER Logo
19 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
