Question about Denon AVR-3805 Receiver
Why my Denon AVR-3805 keeps going to protection mode?
  • 4 Answers
SOURCE: connecting PS3 to Denon AVR-3805
refer to manual
http://www.playstation.com/manual/pdf/PS3-01-1.0_2.pdf
think you can use AV multi out connector
Posted on Nov 25, 2008
  • 133 Answers
SOURCE: ''Protect'' mode on Denon AVR 800
Protect mode appears when there is a problem with the amp it goes into this mode to avoid any further damage to the system. to begin with disconnect all the speakers and see if it continues or else it could be that moisture in the circuits have caused it to go in protect mode or else ther is some shorting in the circuitry. It wud be wise to have it serviced by an authorised personnel
Posted on Jul 23, 2009
lscf150
  • 443 Answers
SOURCE: I just purchased a . Samsung 50
No, you would be better off sending the video signal from your sources(satellite,digital cable,DVD,BluRay player,any digital HD source,etc.)directly to your Samsung TV, and then use the fiber optic output from the TV to transfer the audio signal to your Denon receiver, or another way is to send all video signal to your TV and send all audio signal to your Denon receiver seperately, keep in mind that there really isn't a good reason to send video into a Denon receiver, that processes sound not picture! Good Luck !
Posted on Jan 05, 2010
Testimonial: "tHANK YOU, YOUR ADVICE IS SOLID, LOGICAL AND MAKES THE BEST SENSE!"
tvservice306
  • 458 Answers
SOURCE: I have a denon AVR-2000 that has gone into protect
power output short....or spk or spk wire short check and .need service...
Posted on Jan 07, 2010
taran_2005
  • 10515 Answers
SOURCE: protection error in denon avr-3000
Do you know what caused the protection shut down in the first place? Did you short your speaker wires even briefly?
You could try to Unplug the Unit for Few Minutes, say 30 minutes and then turn it back ON.Usually that would fix the issue.
If you are going into protect mode with no speaker attached,chances are that your output Ic is in need of replacement .This is the most likely cause of a protection error that you are experiencing.I am having a bit of difficulty in locating specific part numbers but feel confident that replacing outputs will remedy your concern.For further info and parts or authorized service locations in your area I suggest to contact mfg at www.usa.denon.com/ .Click on support or call(201)762-6500.I believe that they have a flat rate service and will give you an estimate.
Still, on the remote possibility that it is just a glitch caused by momentary power interruption or fluctuation, try to re-initialize the microprocessor, a hard reset (not unless this is what you were referring to as rebooted). The reset should force the AVR-3300 to revert back to factory defaults removing glitches, errors in settings & configurations, memory & presets as well as user preferences.
* turn OFF the unit using the POWER button;
* press and hold both SPEAKER A and SPEAKER B;
* without releasing the 2 buttons, press the POWER button;
* release the 2 buttons only when the display starts to flash;
* in the event of no display flashing, repeat the process.
Should the above be not corrective, then it would be a hardware fault and not just a glitch.
Let me know, if needed further assistance.
Hoe i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 13, 2010
My Denon dvd-2910 does not play 5.1. It is connected to Denon AVR-3805. It plays just stereo. The center, back channels and subwoofer don't give any sound
Your Denon DVD-2910 produces left and right audio output. Your Denon AVR-3805 generates 5.1 channel output; therefore, 5.1 channel output may not have been selected or the AVR-3805 may be defective.
Jan 29, 2017 | Denon DVD-2910 DVD Player
Denon AVR589 shuts off. I removed all connections and plugged it back into the wall and powered it on. The same thing happened. I think the company told me it was going into protect mode. I have no idea...
One or more channels have a short in the audio output stage causing the protect mode to engage " saving it from further damage " this will require a professional or Denon service. I'am not aware if there are issues with this model.
May 07, 2011 | Denon AVR-3805 Receiver
Does the Denon AVR 3805 have an HDMI port? Would it be compatible with the new apple TV?
No this unit does not support HDMI I downloaded the 3805 manual at http://usa.denon.com/US/Downloads/Pages/InstructionManual.aspx
page 100 list the three types of video connectios
Mar 14, 2011 | Denon AVR-3805 Receiver
Jan 05, 2010 | Denon AVR-3805 Receiver
I have a Denon AVR 3805 and can't get the video to work on the TV.
http://www.usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-3805&imageField.x=10&imageField.y=9
cut n paste the whole link.
Also check all you cables..If you have spares try them in place of the others
Jan 18, 2009 | Denon AVR-3805 Receiver
Connecting PS3 to Denon AVR-3805
refer to manual
Nov 10, 2008 | Denon AVR-3805 Receiver
HTPC connected and no Video out
did you check your I.mode or analog buttons on your remote?
Dec 14, 2007 | Denon AVR-3805 Receiver
Denon AVR-3805 Receiver Logo
117 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
