Question about Kirby Ultimate G Bagged Upright Vacuum
First the belt kept coming off, now the machine will not turn on at all. Is it worth repairing? I put the belt back on a couple times. If this was a car, I'd think I had a dead battery!
  • 171 Answers
The question is what is stopping it from turning on? And if it is a blown motor I would recommend a new vacuum. If it is just the on and off switch I would fix it.If you put the belt back on and make sure the bag assembly is on the machine properly will it then turn on?
Please get back to us with this in fo so I may further assess your issue
P.S. a new belt may solve this as the old one is most likely stretched and needs replacing!
Posted on Oct 10, 2010
Hoover repair manuals
Sounds like you need a new belt underneath the machine. They are easy to change. Use a paper towel when you remove the old one, the black rubber will come off on your hands and get all over everything. If you can, take close up pictures of the beater bar when you take it off. It just pulls straight off. Remember which side goes where and what the little ears look like when you pull it off - slowly so you can see how they went in. Take the old belt to the store along with the make and model of your machine. Some belts are round, some flat and some longer than others. This will end any confusion:) When you put it back together, you may have to wiggle the beater bar to get it in properly. Be patient, they rarely go in the first time. Good luck.
Jul 24, 2014 | THE HOOVER COMPANY Hoover Multi-Cyclonic...
My hoover elite belt comes off within 5 seconds of turning it on
Those machines sit in the box in transit across the world and waiting for purchase. In time the rubber stretches out from just sitting there. In the old days they packed the belt separate from the vacuum and you had to put in on yourself. Today's buyers aren't so handy so the manufacturers are forced to put the belts on before sale. 80% of returned vacuums are due to this! Find the local Hoover Warranty center on the hoover dealer locator at hoover.com and they'll set you up with a new belt at no charge. Good Luck!
Oct 03, 2012 | Hoover Elite Rewind Bagless Upright...
How to install broken belt
Why would you want to put in a broken belt?
Turn the machine upside down. There are two clamps that hold the sole plate on, un click then. This will reveal the 'belt alley' where the belt runs from the motor to the roller. Lift the roller out of the slots. Take this time to clean all the hair and threads off the roller.
Put the new belt over the wooden pulley on the roller and put it almost back in. Put the other end of the belt over the motor shaft. Stretch the belt by returning the roller to its slot. Put the sole plate back on - snap the clips - Presto.
Simple
Thanks for your question today.
Feb 03, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
How do I change the belt
you need to flip it over and get access to the bottom of the machine. Then you need to remove screws that are holding the cover on. there may be little tiny arrows in the plastic pointing to the screws and if so you will know that these are the screws to remove. Once you get the cover off you will see the roller bar and the little motor with a steel shaft sticking out ; this is the shaft that the belt goes on to. The old belt will often be sitting right where it broke and that is right where you install the new belt . you will need to pull up on the roller bar to get the belt around the end of it . Once you put the roller bar back down in to position you can take your screwdriver and put it through the belt and pull it back so you can slide it over the shaft.. Now the belt is new and has not been stretched so it may take you a couple of times to get it on . Do not get discouraged it will go on if you have the correct belt. Once the belt is back on you can put the cover back on and you are off to the races....Good luck
Oct 07, 2010 | Eureka 3276AZ Pet Lover Bagless Upright...
Got Dirt Devil Featherlite,keeps burning the belt out immediately and there is only one way to put the belt on...have put on 4 new belts.....what up?
Hi There,
When a belt breaks immediately after installing it, this can ONLY mean one of two things. The first is that the belt was put back on incorrectly, and it may be pinched underneath of the beater bar. This would cause it to break immediately, but I seriously doubt after 4 belts that you put the belt on wrong all 4 times.
The second, and more probable cause is that your roller brush has gone bad. This could be why the belt broke in the first place. In order to test to make sure the brush is bad, unscrew the bottom plate, and remove the brush like you were changing the belt.
Hold the brush at the very end on both sides, using only your finger tips. While holding just the bearing caps, try spinning the bar with your thumbs. Does the brush spin freely in your hands? It should spin completely around 4-5 times on each spin. If the brush will not spin, or if you feel any resistance to it spinning, this is the reason why your belt continues to break.
If the brush can not spin, the motor shaft will continue to try and spin the belt, but since the brush doesn't spin, and the belt doesn't move, the motor shaft will just burn right through the back end of the belt.
If your machine is actually the model that's listed on this Fixya repair page, the Dirt Devil Featherlite model M085845, then your machine uses the following roller brush:
Dirt Devil Plastic Brush Roll for Model 085845 Part # 2-881020-000
The next time that change the belt, install the brush back into the machine, but this time pull up on the belt towards the brush to make sure that the belt spins freely, and spins the brush as well. If the belt doesn't spin the brush, there's some issue, and the belt will break as soon as you turn the machine on.
I hope this helped you. If you find out that you don't need a new brush, feel free to use the comment section here on the repair page and let me know, I'd be happy to walk you through some more advanced diagnosing. If you found this helpful, please be so kind and rate my repair and / or leave feedback for me.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 21, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Hello, I have a Hoover 3200 Turbo Power vaccum. while the motor appears to be working fine the vaccum no longer picks up the dirt. I turned the vaccum upside down and the belt appears to be broken. would a...
take the vacuum head off the end of the tube , turn the machine and place your hand over the end of the tube
if it sucks your hand onto the tube , the machine is working as a vacuum machine
then check fro a blockage in the elbow section near the head
if there is no vacuum , junk it and get a new one
Jun 30, 2017 | Hoover Vacuums
Dyson DC14 Brush Bar won't turn
You don't need to take it for repairs, I just corrected the same problem on the phone with a tech. Have the head on your lap, make sure the end nearest the little belt has the rounded side of the bar facing you. The squared off end faces towards the machine. Place your left hand pointy finger under the bar (the 2 inch bar next to the little belt) and lift up, while finessing the loose end of the bar into place, with the rounded part still facing you. Then it sort of snaps into place. Now, replace the face plate. In the upright mode, starting at the carpet dial, switch the dial back and forth between carpet and bare floor, ten times. (the tech actually referred to this as re-setting the vac. LOL) Plug the vac in, incline the hand, and start. It should work. It didn't for me the first time and made a horrible sound. That meant I had to go and repeat the process again, but lo and behold, IT WORKED! When in doubt, call the tech and don't let them get away from you; have them stay on the line until the problem is resolved.
Jun 23, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
HOW TO REPLACE BELT ON kIRBY cLASSIC 111 vACUM cLEANER?
I don't have a diagram, but I might be able to explain it to you.
Take the nozzle off the machine. Remove the brushroller and old belt.
Set the belt pulley to the on postion. Put the belt on the roller and put the roller back into the roller housing with the belt centered. Turn the belt pulley to the off postion. If you look in the hole in the back what you want to happen is the pulley to spin and hook the belt stretching it out.
Put the nozzle back on the machine. Lock it into place and turn the pully to the on postion, and you should be ready to go.
Nov 25, 2008 | Vacuums
Savvy vacuum belt
It is easier when you also take the top off. Then you can put the belt over the roller and re-install it, then put the bottom plate back on, then turn it over, undo the motor and put the belt on the motor pulley, re-install the motor and put the rest back together. To remove the top, thewre are a couple of scres from the bottom, then from the top, remove the Hoover emblem, there is a screw there to remove and the top will come off.
Jul 11, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover Encore Supreme belt replacement
Remove the bottom plate that covers the brush roll and remove the roller. The plate is removed by releasing two clips at the back corners of the plate on either side. Take the roller and install the belt around the pulley and put the other end of the belt through the access hole in the vacuum body. Replace the roller and turn it by haand to ensure that the belt is not pinched. Replace the bottom plate and turn the roller again (same reason).
If you look at the area beside the rear wheel between the hood and the main body, you will see a clip incorporated into the hood. Take a screwdriver and pry it away from the main body. Do this on both sides. You will find a similar clip at the hood just beside the back corner of the plate in the front where the plate clips are located. Pry these as well and hood will come loose. Now you can turn the machine back on its' wheels and remove the hood. You will see the belt where it comes through the main body and you can grab it with a couple of fingers and stretch it onto the motor shaft. Replace the hood and the job is done.
Mar 21, 2008 | Vacuums
Kirby Ultimate G Bagged Upright Vacuum Logo
24 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
