Question about Cameras
A problem has just arrisen on my cannon 5D camera, it simply does not want to shot a picture, it focuses fine, I hear the blip but when I press the sutter it doesn't take the picture. I turned it off and then back on again and this time it took a photo but I could hear the camera trying to process it and then err apeared. Please I would appreciate any comments or advice on what I should do
  • photos_buckl Oct 10, 2010
    still the same, the message which appears is err 01
  • 567 Answers
Please take a backup of your pictures on the menory card.
Format the card in the camera and try again.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this solution.
Thank you.
Posted on Oct 10, 2010
  • Anuj Joshi
    Anuj Joshi Oct 10, 2010
    Thank you for the update.
    The error message "Err01" is short for "Error 01." It indicates that the camera is not communicating correctly with the lens you currently have mounted.
    to resolve this error, remove the lens, reattach it, and check to see if the error message reappears. If you see the error code again, you'll need to clean the lens contact.
When take picture in normal mode or 1x/ 2x zoom the picture clarity and sharpness is very good.but when i take picture in 3x/4x optical zoom ,picture clarity and sharpness is very poor..my camera i cannon...
Turn on auto focus and when you are taking a shot let Auto-Focus adjust the blurry image in the viewfinder beforeyou take a shot. If you do not know how to do it please let me know and I will give you detailed instructions.
Sai.
May 16, 2011 | Canon PowerShot A570 IS Digital Camera
Pictures are blurry unless I push the picture switch down very slow
Good day,
I have heard a lot of complaints about people taking Blurry Photos.
There are a few possibilities for it and a few easy fixes.
The first possibility I would identify is a dirty lens. To fix this simply take a clean microfiber cloth and gently clean the lens until there are no smudges visible.
The other possibility I would identify is that the pictures are out of focus.
This problem can be caused by a dirty lens or because the object or person was not focused on. To ensure focus on your photos, line up your shot and wait for the camera to focus by pressing the shutter button half way down. When focused press the shutter button in all the way and hold the camera still until the photo appears on the screen. By doing this you will eliminate any motion that might mess up your shot.
Please let me know if these tips work for you!
Regards
Mar 18, 2011 | Canon IXUS 80 IS Digital Camera
IM USING CANNON SX 210 IS MODEL MOST OF THE SHOTS WHEN IM ZOOMING ITS GETTING BLURED, ITS NOT LIKE HOW I EXPECTED FROM CANNON.
Make sure you are shooting in a mode with the flash enabled and that should enable the anti-blur features of the camera
Feb 28, 2011 | Canon PowerShot SX210 IS Digital Camera
Cannon Power Shot A80 with error code E18
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
If none of this works for you please comment.
Good Luck!
Stay Classy
B.
Mar 29, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Out of focus pictures
Try allowing the camera to focus by pressing the shutter button halfway.  Wait for a beep then press the rest of the way to take the picture.  This should result in much sharper images.  If this helps please rate my solution.
Dec 11, 2008 | Canon PowerShot A75 Digital Camera
Focus problems.
The canon 5d was suspected to produced low sharp pictures, but it's wrong. Sharpness is a parameter on the 5D. You can tune it in the menu/image style/ then you choose your style and hit "jump". The first cursor is sharpeness. Enjoy.
Nov 03, 2008 | Canon EOS-5D Digital Camera
Canon 5d af points...
The AF point will luminate very briefly when you press the shutter half way. To change the AF points press the Zoom in button + and then use the dial on the top to select the point you want. If you are not able to do this go into the Menu setting and under custom funtions go to No. 13 and set this to 0:Normal.
To get the image to focus and remain focused while you recompose set the shooting mode to 'One Shot' do this be pressing the AW-WB button them turning the top dial to get to 'One Shot'. When in 'one shot' press the button half way recompose whith out lifting your finger and squeeze all the way when you have recomposed.
Hope this helps.
Jun 21, 2008 | Canon EOS-5D Digital Camera
5d focus confirmation light
Just a wild guess, but in predictive AI focus mode you need a subject in motion for focus to lock and focus adjustment is continous until the exposure is made, in one-shot AF or manual focus mode focus will lock on still subjects. Super nice camera btw.
May 17, 2008 | Canon EOS-5D Digital Camera
FOCUS OUT OF WACK...big problems
Hi
Change the mode to 'One Shot'. Press the AF-WB and turn the top dial to 'One Shot'.
2. Increase your depth of field. When shooting in Av try using f11. This should help with te out of focus people on the ends. Check your shutter speed as well. Good rule of thumb is to keep the shutter speed higher than the focal length of the lens. i.e. 100mm lens should have a shuter speed of 100+ for hand held shots. You may need to change the ISO speed to get the shutter speed in low light. Lternative is to use a tripod.
Hope this helps.
Apr 10, 2008 | Canon EOS-5D Digital Camera
Cameras Logo
19 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
