Question about Yamaha DSP-A1000 5-Channel Amplifier
Yamaha dsp a1000 left channel cuts out sometimes in surround mode, sterio works fine
Yamaha dsp a1000
the left channel sometimes cuts out while running for a while in the surround mode. sterio works fine. if you bang on the front of the unit, it stops doing it for a while. i use the tape monitor input instead of one of the inputs on the main selector switch. is it a switch dirty pots or something more un happy. please do advise.
The easiest way is to buy the new part online and replace it - cost about $50US.
However, if you're up to it, this problem is fixable without the need to buy any parts. The selector switch has four sets of spring contacts which need to be bent slightly to increase the pressure on the pads against which they press, but it's a tedious job and not for the faint-hearted.
Here's what you need to do:
Open the case (6 screws) and also free up the front panel (9 screws).
You'll see that the switch consists of a PCB, an aluminium box and a motor. Remove the two screws holding it to the front bulkhead. take oyr the small "L" shaped circuit board that overlays it. A plastic pop-in holds the bottom of the switch PCB and the switch assembly can then be removed entirely.
Next you will need to remove the aluminium switch box from the PCB. Firstly de-solder all the connections which hold it in place. Now pull it clear.
Here is the MOST critical part of the job: inside the switch box you'll see four circular plastic wafers - these contain the contacts you need to fix and you'll need to bend the tangs which hold the shaft assembly onto the housing and then the tags which are holding the wafers in place. Your difficulty will be making sure that the wafers go back on the shaft with the rightr alignment and that the wafers go back in the same order.
Take some digital pictures while the wafers are still on the shaft with the orientation of the KNOB included - if you mess this up (I did) the job becomes horrible! Also, mark each wafer with a number 1-4 because there are three different kinds Once you are comfortable that you can replace the wafers in the proper rotary configration with respect to the shaft, remove them individually and pop out the gray plastic cores and bend the spring contacts upwards so that they will go back pressing more firmly against the pads. Now reassemble, and good luck!
Posted on Dec 29, 2008
    Problem Solver:
  • 19 Answers
Hi, Your luck is in. This is a small problem but it might be hard to find. You need to look for a Dry joint. This will sitting either on the front panel or on the output stage of the left channel that is going mad. I would suggest that you have a look at the front panel first. Also clean your selector switch just in case.
Posted on Jun 02, 2008
YAMAHA DSP-AX1 SOUND CUTTING IN AND OUT OF FRONT CENTRE CHANEL
Check if the sound comes from a digital source like an optical cable or the one that generally the color is orange (not the common red and white, nor the yellow terminals) then check also if this ocurr with certain music. Let me know
Jan 18, 2014 | Yamaha DSP-A1000 5-Channel Amplifier
Dsp-a1000 center channel has a very low volume
By opening a new incident you are losing all that good thread (*) we were already working on and you will probably have to re-explain everything to whoever chimes in going forward.
* http://www.fixya.com/support/t9198666-own_yamaha_dsp_a1000
Jul 14, 2011 | Yamaha DSP-A1000 5-Channel Amplifier
Own a Yamaha DSP-A1000. Center channel "died" this week. Everything had been working for years. Suddenly, the center channel stopped working (very obvious in DSP fields for Home Theater). Any...
If you run through the setup and certify it knows about the center channel first, then test it with tiones, then maybe swap the center speaker with another one you might come to an answer.
May 13, 2011 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha dsp a1000 two remotes and both don't work at all any fix for them
Are you certain they are at fault? It could be that the Yamaha isn't responding, due to a faulty remote censor. Try a good universal first to be certain, before attempting repair of the remotes.
Nov 16, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha DSP-A1000 , wiring details
Go to Yamaha's web site and download the user manual. It's free!
May 07, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
Problem with Yamaha dspA1000
Be sure you are using the AUDIO OUT on the vcr then going into a AUDIO INPUT on the DSP A1000, this will allow the DSP A1000 to amplify the audio line level.
Jan 31, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
STG DR510 no sound on left front channel
Can I assume the calibration procedure also didn't work for the Front left channel? (It's not a "surround" if it's in the front). Switch the receiver to Stereo mode to eliminate any DSP actions. Tune an FM station to eliminate any external device or cable issues. What do you hear from the two Front speakers?
OK? Select a DSP surround mode. Check all modes. What happens?
If the channel goes dead using some or all DSP modes there's probably something wrong with the processor. If they all work...
Isolate the source that exhibits the problem.
It was a bad left channel cable somewhere, wasn't it?
Dec 24, 2008 | Sony STR-DG510 Receiver
Problem with Yamaha Amplifier 361
volume levels on all channels varies depending on what dsp mode you are using. to be able to determine the level you desire, just chnge the level setting of those channels. either you do it by remote control or the front panel of the amp. try setting the dsp mode on disco and you should hear higher vol levels on all channels. Do not expect as well all channels to produce same vol levels as your effects speakers may not be able handle higher power levels.
Aug 12, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha Dsp-A1000 5 ch amp Bought a used amp will be hooked to an awia reciever and speakers also have two subwoofers need help to install correctly witch connections to use
if you wanted to use your receiver as your controller and source then try to find out the receivber has got a bridge (jumper) between the pre-amp stage and the power amp stage. if your receiver does not have that, then you can just connect your receiver tape record out to one of your DSP inputs. subwoofers, the DSP has got a sub woofer out connector. you can use that (RCA type) to your sub woofers. put in series because DSP has got only one output for sub. or, you can connect your subs directly to the mains speakers, parallel connections. maybe one sub to your left and the other to your right channel.
Jul 24, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
No center main volume
Make shure your initial setup on the amp is for center as an active speaker,then to check volume on center at zero. Possible to check speaker and wires for open or short.BIGRED
Sep 16, 2007 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha DSP-A1000 5-Channel Amplifier Logo
517 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
