Question about Kenmore 88732 Top Load Stacked Washer / Dryer
After it fills up it wont agitate .the lid switch is acting up ,any way it would work if i disconnect the switch?and whats the easiest way to disconnect it? model # 110.88732792 stackable
jsrock516
  • 5911 Answers
SOURCE: agitated with my agitator and spin cycle
Your problem could be with your transmission, which is located directly above the drive belt pulley under the wash tub. If they go bad, your motor will still function normally, but the wash tub will not spin or agitate. Now, another possible problem could be a nail or screw stuck in one of the wash basket holes pressing against the outer tub. I have personally seen this a couple of times. A dry wall screw or nail will stop the wash tub from spinning and cause the drive belt to smoke as the motor pulley turns, but the belt stays stationary. That could be the source of your smell. If you're a do-it-yourselfer or do a lot of carpentry work, you may have washed some clothes with a nail or screw in them. Inspect all the holes in the wash basket throughly. A nail or screw can easily be missed if your not looking for it. I hope this may help you.
Posted on May 04, 2007
appldoctom
  • 311 Answers
SOURCE: KENMORE WASHING MACHINE MODEL#110. 254872300 WONT SPIN
if your sure it will agitate?[because the pump is on the other side of the motor and will drain,but if coupler broken ,wont agitate or spin although it makes noise like its working.so if will truely agitate drive coupler fine and its going to be the clutch or that area unless somthing[clothing] is between the two tubs creating anough resistance to stop the tub from taking off.clutch pads will just slip on drive plate.hope that helps>God bless ,tom
Posted on Jan 04, 2009
jumptrout51
  • 3361 Answers
SOURCE: Kenmore washer (model # 110 24872300) won't agitate.
Your machine has no belt. It has a direct drive coupling. The direct drive coupling between the motor and transmission must be replaced.
Posted on May 20, 2009
  • 126 Answers
SOURCE: Washer wont spin or take out the water
Hi 1st remove cabinet by removing 2 screws securing the console to the cabinet top.pry clips at corners and remove .you should now be able to pull cabinet towards you and separate it from chasis .motor /pump at center front bottom.plastic plug on right, wiggle that plug with washer in spin probably bad connection in plug.red/black wire Hope this helps please rate my solution. :)
Posted on Jun 26, 2009
SOURCE: Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Posted on Jul 04, 2009
Kenmore 417.97922701 washer tub will spin but will not agitate
Disconnect power to the unit.
Does the agitator move freely in both directions by hand?
Could be your agitator coupler needs to be replace
Also need to verify the lid switch and pressure switch are working properly. Let me know if you need further assistance
Nov 10, 2014 | Washing Machines
Wont spin just clicks
Hello & Welcome to FixYa
When the washer fills but does not agitate or spin then you can check if the lid switch is fine. You can jump start the lid switch by connecting both the wires with each other or use the third wire to act as jumper between the two. After this if the problem is solved then replacing lid switch is recommended repair. Please get back to me if you have any other questions.
Kevin
Sep 07, 2011 | Whirlpool LSR5132PQ Top Load Washer
My kenmore washer model#110.24422300 is not agitating, spinning or draining. Problem started today, it work fine yesterday. Tried selecting different settings to get to agitate or drain, did not work.
Kevin
Aug 07, 2011 | Kenmore 22422 Top Load Washer
Wont agitate or drain water to spin
Check to see if your lid switch is working. On most models the lid switch will prevent the washer from spinning with lid open. Some models will stop once the washer fills with water. Depending on what brand you have depends on where the lid switch is. If you need assistance finding the lid switch or replacing it please respond back. Thank you
Aug 02, 2011 | Washing Machines
My Maytag Bravos pumps, drains but wont spin.
Kevin
Jul 22, 2011 | Maytag Bravos MVWB700V Top Load Washer
Washer fills but won't agitate..
Kevin
Jun 09, 2011 | Maytag Washing Machines
Washer fills but does not agitate or spin.
Hello
When the washer fills but does not agitate or spin then you can check if the lid switch is fine. You can jump start the lid switch by connecting both the wires with each other or use the third wire to act as jumper between the two. Please get back to me if you have any other questions.
Kevin
Nov 10, 2010 | GE WBSR3140DW Top Load Washer
Kenmor top load Washer, Wshr fills, agitates, wont spin or drain
The Lid switch is the most common problem with what you have descibed.
some of the lid switches are located in the control area and some are on the right side center lid area and their is a hole where the lid has a plastic pin that presses it.
Jan 12, 2010 | Washing Machines
Agitator doesnt start
Sounds like the lid switch is acting up on you.
Jul 26, 2009 | Whirlpool LTE6234D Top Load Stacked...
Whirpool washer wont work
The lid switch, get something to hold it down to make machine work. Turn machine on and push down on lid.
Jul 26, 2009 | Whirlpool CAM2752KQ Top Load Washer
Kenmore 88732 Top Load Stacked Washer / Dryer Logo
35 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
