Question about Fisher Washing Machines
The washing machine is plugged in, and there is power to the circuit, but the board doesn't light up or start. What gives? I need to get this running.
  • Fisher Master
  • 713 Answers
Hi just read your posting.To help you I need the model number of the machine which is located on a sticker at the back of the machine, top left.The reason I need this information is some machines will not power up if the pump is open circuit.Please reply and I will help you rectify this fault.Looking forward to your reply.
Posted on Oct 10, 2010
No ights or power to machine. plug and wall ave power
This should only be done if you are qualified and safe to do so. Remove the panels/covers and check if the mains voltage is reaching the cable connector/circuit board with a voltage tester/meter. If not, the cable must have been damaged and gone faulty. If yes, check any fuse/relay on the circuit board. If voltage is present, then the circuit board must be faulty which either needs replacement or fault-finding down to component level.
Apr 10, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Kenmore HE2 plus washing machine.. the power goes off. no code appears. I seem to have a temporary fix but need to understand what to change
This could be an intermittent failure of some component on the circuit board. Eventually when you tire of bashing your machine to make it behave you will have to give that circuit board a thorough examination and possibly replace it. One other thought, there could be a problem with the door latch interlock causing the periodic failure.
Dec 14, 2013 | Washing Machines
Problem with my washing machine
You need to replace your wash timer or circuit board this is your problem. This is the unit behind where you turn your machine to heavy load whites and what have you. Remember to rate my solution and give testimonial this is how i earn my achievements here on Fixya Thanks in advance.
Apr 26, 2012 | Kenmore Washing Machines
Washing machine wont start
Try unplugging the machine for 15 seconds. After it is plugged back it open and close the door several times. I know this sounds weird but it resets the safety circuit that sometimes shut these machines down. There may be some other safety reset sequences specific to the machine (you can search these on the net) if the one I told you doesn't work. Please rate my answer so I get points for it.
Jan 20, 2012 | Whirlpool Washing Machines
No power, no display
check breaker then check plug
May 04, 2011 | Washing Machines
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 21, 2009 | LG WM-2277HW Front Load Washer
Machine freezing with three lights flashing.
HI JOHNNYHEFF,
JUST GOT A NEW HOTPOINT STARTED TEST WASH ALL THE LIGHTS FLASHED SO SWITCHED OFF TRIED AGAIN NO JOY. TECHNICIAN COME OUT SAID THE CIRCUIT BOARD WAS GONE, NOT GOOD NEWS FOR YOU BUT THOUGHT I'D LET YOU KNOW!
Oct 23, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
F & P 603 Top Loader
lid switch possibly open circuit
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
Power but nothing happens
Check your washer's plug. Set the wash programme & then press 'start'.
Feb 10, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Washing Machines Logo
27 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
