Sanyo VWM-950 VHS VCR
Problem for Sanyo VWM-950 VHS VCR
Spindles don't move anymore
By cat2000_ca on May 31, 2008
The usual thing happened... tape stopped playing, machine turned off, turned machine back on and it ejected tape with some of it hanging out. Normally I just push tape back in and it corrects itself, but this time it just hung. I couldn't get the machine to release the tape (stuck in down (play) position), so I removed the lid, the front panel and the top bracket. Then I cut the protection piece off the tape cartridge and slid the tape out from the mechanism and thru the front (where I had removed the panel).
I put the machine back together, except for the lid (which I never screw back on anyway). I plugged it in and it went thru the load/unload movements twice. Then I put a tape in and the spindles did not move to grab the tape. It just spun as in fast forward and the take-up reel could not keep up with the feed reel. Note: When I put the tape in I heard a loud noise and suspect something snapped, probably a nylon piece. I uplugged it right away, but it was too late. I need a schematic to figure out what has broken and if it can be fixed.
Thanks
Best Solution
posted on Jun 03, 2008
Very Helpful)
Abrsvcs
Rank: Guru  Televisions & Videos  Expert
Rating: 88%, 1882 votes
The most likely culprits here are belts. This unit has belts and a rubber idler. Replace all of the rubber parts and you should be OK. This is a normal maintenance procedure for VCRs.
Dan
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Sanyo VWM-950 VHS VCR
Questions and Unsolved Problems for Sanyo VWM-950 VHS VCR
Do you recommend Sanyo VWM-950 VHS VCR?
Answer
Answer
Do they make a DVD/VHS Combo with a built in decoder that will connect to my Analog TV using only a... (More)
Answer
how do you turn the closed caption off
Answer
There is no switch on the back of the unit it is currently on channel 3 how do I change it to... (More)
Answer
Hi, I just bought a used vwm 950 and my son dropped it. Now the power will go on but the tape will... (More)
Describe your VCRs problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top VCR Experts
Top Audio & Video Equipment Repairmen
in Van Nuys, CA
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
