Question about Hampton Bay 04345 Cruiser Ceiling Fan
Hampton Bay CF No Model #!!!!
I have no clue what the model of my HB CF is. It is hard-wired to the wall switch, has no visible speed control switch on it anywhere, or a direction change switch, and a round fluorescent "bulb." HB makes 1 million different fans, and it's hard to know which one I have. Your pictures are not large enough to tell. It has a rounded half globe covering the bulb, which unscrews, and the only info inside or under the bulb pertains to the bulb.
I need to download a manual for this CF! I also need to know how to change the speed and direction. Since it turns on at the wall switch and has no chain pulls, I'm at a loss.
I hope someone can help me! Thanks in advance!
Dallas
dallasnk9@aol.com
    Problem Solver:
  • 6 Answers
I had this exact same problem at an apartment i lived in awhile back. Unfortunately, there IS no was to change speed or direction. It is a one-speed, one-way fan. Sorry for the bad news.
Posted on Nov 29, 2008
Fan has no visible forward/reverse button and when it is turned on it only goes in reverse
There should be a slide switch on the wire enclosure under the motor.
You may find that your universal remote control does not work unless it specifically includes fans. Most of them don't.
Aug 07, 2017 | Hampton Bay Dryers
Trying to find manual for a Hampton Bay ceiling fan. I have two. Tag on fan says model: AC-552AL, Item# 154620 NN, Another sticker on fan says 05/02 E192641 UL Listed CEILING FAN 47BF
You should find what you need here:
http://www.homedepot.com/b/Lighting-Ceiling-Fans-Ceiling-Fans-Accessories-Ceiling-Fan-Parts-Remote-Wall-Controls/Hampton-Bay/N-5yc1vZbvmuZp4
Apr 03, 2017 | Hampton Bay Dryers
My Hampton Bay Windward II
I need a fan chain pull switch for my Hampton Bay 5 Blade Model 552 od--
SKU # 409-952----
MFG # 5A00007
SER # 720275940415653B
The switch controls High,Medium,Low Speed and Off.
4 Wires--Black,Brown Purple and Gray are connected to awitch, they come from a Block Capacitor (4.5mf,6mf and 5mf)
This fan was purchased around 1995 and is in good condition but needs this replacement switch---
Where can I get the replacement for this model?
Apr 19, 2009 | Hampton Bay 24002 Ceiling Fan
Bay Model # 526-012 Fans what size speed control
I can't see any reason why a Leviton fan speed control couldn't be used on any ceiling fan, after all, I don't even think Leviton makes ceiling fans. Second, you may be able to try using the 1.5 amp fan speed control and see if you can get by. The worst that could happen is the speed control wouldn't work or would only work for a short time and be junk.
Jan 03, 2009 | Hampton Bay (261025) Dual Mount Ceiling...
Remote needed
If you talk to Fantasia Fan people, they may be able to help you. I've had spares from them, & they were helpful.They also supply a wall mounted, wired controller, but it needs an electrician to do the wiring. The plus with hard wiring is that it doesn't have a wireless controller pack to go wrong.
Dec 18, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Oct 11, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Need Wiring instructions
no problem just wire the black to black and white to white. connect the ground and cap off the blue wire, its used only for ooptional light assy
Apr 03, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
Hampton Bay Ceiling Fan At Slow Speed
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Aug 10, 2007 | Hampton Bay 52 In. White Redington...
Hampton Bay 04345 Cruiser Ceiling Fan Logo
127 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
