Question about Victorinox Swiss Army 25179 Watch for Women
The clasp on my swiss army officers ladies watch v 25568 has broken, please help!
2 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: victorinox swiss army 020233547
First let's start with the battery replacement;
  • Set the watch face down on a flat rubber surface. This will keep the watch firmly in place and will protect it from being scratched on a more hazardous surface.
  • Use a pair of needle-nosed pliers to pull the points just far enough apart so that each point can be pushed into each of the two notches on the back of the watch.
  • Keeping the pliers pushed into each notch, turn counterclockwise to begin removing the back of the watch. Once it has been loosened, finish removing it by hand.
  • The battery will be the only part inside of the watch that is not directly connected. Make a mental note of the battery's position and then remove it.
  • Insert the replacement battery into the same spot where the original battery was located.
  • Use the needle-nosed pliers to screw on the back of the watch in the same fashion you did in Steps 2 and 3, except this time turn clockwise.
For the wrist band replacement;
  1. Measure the band around your wrist to determine how many links must be removed.
  2. Identify the arrows on the underside of the watch band. These indicate what direction the pins should be pushed.
  3. Place the pin pusher above the first pin of the band, where the band connects to the watch clasp. Make sure the pin pusher is the proper size for the pin in question. Tap the pin pusher lightly with the hammer to remove the pin. Very little force should be needed to remove the pin. If you meet with resistance, make sure the pin remover is lined up with the pin. Set the pin aside.
  4. Move the pin pusher down the watch band to the amount of links needed to be removed. Tap the pin pusher with the hammer to remove the pin and the extra links.
  5. Reattach the watch band to the claps by putting the band back in the clasp and tapping the pin back into place with the hammer.
I hope the above helps....
Good luck.
Posted on Mar 19, 2011
Swiss army watch S.A.W CO. Where do we find a list of model numbers. Model number 1789A 00146 I cant find on internet.
Swiss Army Watch S.A.W. Co was acquired at 2002 by VICTORINOX. You can find information about prouct at
VICTORINOX website and you can get more information through teit CONTACT link.
http://www.victorinox.com/ch/content/contact_us?lang=en&
Apr 23, 2015 | Swiss Army Watches
Swiss army watch 241083, what battery does it take
Any Brand, Type 371 1.55v. I replaced the same Swiss Army Victorinox Infantry Watch model 241083 specifically with the Energizer 371BPZ Zero Mercury Battery. BTW, the replaced original was also a 371.
Jun 30, 2013 | Swiss Army Watches
Swiss army 24712 after using stopwatch sec hand wont return to 12
pull crown out to second position press start till it goes to 12 then push crown back in
Jan 22, 2013 | Swiss Army Mens Victorinox Officers 1884...
Replace battery for officer's 1884 watch
You have to carfully pry the back off of the watch. There you will find the battery.
Jan 02, 2013 | Swiss Victorinox Army® officers 1884 Xs...
How do you open back to change battery?
Swiss Army watches require a special tool. You will need to call your local jewelers and ask if they do Swiss Army watches as not every jeweler has the tool to do it.
Good luck
Jul 19, 2010 | Swiss Army Wenger Standard Issue 70609...
Scratched crystal
mcdevito75 here, If the crystal is Glass a replacement crystal may be your only choice, If Plastic It may be saved. Check with the watch repair service directory, right here on fixya. Bottom of this page, click on repair service directory then watches.
Jun 30, 2010 | Swiss Army Wenger Swiss Army Officer's LS...
Wenger Swiss Military Watches Sportedge Bracelet Watch (For Women): I've dropped my watch on the ground twice at work ...
Please run through below link. That is the site of Swiss, and Customer Services will help you, depending from what country you came from.
Swiss
May 17, 2010 | Swiss Army Wenger Sportedge Bracelet Watch
Can't get the hour hand or minute hand to move
If your watch is genuine SWISS ARMY made, then follow this link, choose your watch and download the instructions (movie style): http://www.swissarmywatches.co.uk/index.htm
Feb 04, 2010 | Swiss Army Wenger Victorinox Swiss Army...
The second hand stops on the minute hand
If the hands are binding the movement needs to be removed from the case and the hands set right. i.e. parrallel and not binding.
Jul 18, 2009 | Swiss Army Wenger Swiss Army Officer's LS...
Victorinox Swiss Army  25179 Watch for Women Logo
56 people viewed this question
Top Victorinox Watches Experts
Tom Chichester
Brian Williams
Brian Williams
Are you a Victorinox Watch Expert? Answer questions, earn points and help others
