Question about Bosch T-Shank High Speed Steel Jigsaw Blade
Blade keeps on jumping out during sawing. - Bosch T-Shank High Speed Steel Jigsaw Blade
  • 4,336 Answers
You are not actually tightening the blade in place. The only orientation is front and back, but I suspect that you knew that...
Sounds like you are not actually tightining the blade.Pull up HARD on the quick release knob or it will not actually engauge, but it will sound like it is...and turn clockwise until it jambs, when tightening. then continue turning clockwise until know aligns with the body, and press down to park.
This is a really great tool.
Posted on Nov 08, 2010
Why does my blade keep jumping off track on my black and decker 7 1/2 band saw
There are few reasons why blade jumps off, you may have a poor weld on the blade. Tension could be too tight or too loose. Make sure that the blade tracks properly. I advise you to watch videos about tuning up a band saw or check some informative blogs on bandsawblog.com. I purchased my blades on sawblade.com , check them out if you need any.
May 14, 2014 | Saws
Jammed my 6230 bandsaw during a cut and now it won't start. Are their fuses I can replace?
Go to Milwaukee Tool website and try to check if you can download a manual or electrical diagram there. You can call or email them. Check the motor capacitor.
Are you using an old or new band saw blade? If it's old/dull, try different blade. If it's new, the weld might be really bad. Old Blade and Bad weld can cause the blade to jump off. I purchased band saw blades on www.sawblade.com . Great quality blades; they have porta band blades. Call them.
Oct 23, 2013 | Milwaukee Tool Milwaukee 6230 Deep Cut...
My saw will not tilt fully, it keeps jumping the gears. I have cleaned all areas, i have checked for foreign objects jamming the saw but cannot locate the problem.
Make sure the inner ring on the locking lever has not loosened up allowing it to apply some gravity pressure and is trying to catch.
this happened to me...i could not get the blade to tilt very far and it started "clunking" inside the saw when i got just "so far". It sounded like it was "jumping a cog". I checked everything, a allen wrench" would tighten. Even outside heads on the cabinet . Sprayed everything with silicone. At the end of trying everything, checked the "lever" behind the wheel where you adjust the saw blade up/down (left turning wheel) and accidently discovered the lever had become loose and was tightening just from weight of the lever alone. I loosened the tension fully and the tilt works correctly now. No jumping. Dumb Luck discovery.RGS in Kentucky
Oct 13, 2011 | Hitachi C10FL 10" Stationary Table Saw...
How do I replace a blade on a Delta 36-585 miter saw
There should be a wench on the mecnine that fits the bolt. the bolt turns in the oppiste derection as a normal bolt its called left handed thread this keeps it from coming lose during use. There is a buttom you need to press to lock the shaft then lossen to bolt lift the blade gaurd replace the blade note the washers that go up against the blade and make sure you install then in the same order as they were removed
Dec 17, 2010 | Delta SM100M 13 Amp 10" Compound Miter Saw
Just purchased a 6230 porta band saw and the blade keeps jumping off. Put the blade back on and as soon as you touch the material the blade jumps off.
could be a couple problems, first the blade could be bad, the tires that are on the wheels, a loose axle bolt or the frount housing might be bent. First try another blade and watch for which pulley it rolls off of. Next try to wobble the pulleys and if you can the axle bolt has loosened, I use an impact driver to lock them in place along with loctite. Next if the above are OK check the front housing for being bent (that is a common thing) from the housing hitting after cutting a piece of steel. Let me know if you need more assistance.
Oct 06, 2010 | Milwaukee Tool Milwaukee 6230 Deep Cut...
How to remove the blade
If the saw doesn't have a locking blade button, you need to insert a ( most likely) 14mm thin wrench between the blade and the body of the saw, on the axle, to hold the axle. Unscrew the bolt of the axle and the blade is out. After you place a new one, the procedure is exactly the opposite. Keep the power cable unplugged during the entire time of the blade change. Safety first.
Sep 08, 2010 | Skil 18v Circular Saw saw 18 Volt 5995...
1/8'' blade keeps jumping off wheels on Ryobi BS 900...!! Checked wheels for alignment and both are square to each other. TRension seems right, although I can't find manual to confirm proper tension....
I found a manual online, however it did not give specifics on blade tension. I do know that the blade has to be pretty tight and that it the blade should be just touching the bearings on the back. I hope this is enough help, if not let me know and I'll see what else I can do.
Jan 09, 2010 | Ryobi 9 in. Benchtop Band Saw
The blade keeps jumping out
the blade keeps jumping out
Nov 01, 2009 | Dewalt Saws
Porta Band saw blade jumps off
I had this problem on a used model 725 that I bought. Apparently the rubber tires on the drive wheels develop a bit of a memory after sitting for a while with tension on the blade. I tried cleaning the tires to no avail. Then I removed both tires, flipped them over and re-installed. Still not fixed. Then I put only one back to the original position and the problem was solved. Other than the frustration of trying several times, I was out nothing and I got quite proficient at taking the blade in and out. The saw has worked fine ever since. I hope this simple (and free) solution works for you.
Nov 17, 2008 | Saws
Bosch T-Shank High Speed Steel Jigsaw Blade Logo
353 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
