Question about Samsung HT-X810R Theater System
Hi, I am trying to program my sky+ remote to work with my HT-X810R Samsung soundbar system. I have tried lots of codes with it to no avail so the procedure I'm using may be incorrect.
  • 570 Answers
Please just follow the below steps and you will be able to fix it.
1. Turn on your TV.
2 . Remove the battery cover from the back or back/bottom of your Sky remote control.
3 . Get your TV remote control code. Look for your remote control version number on a sticker on the cover or inside
the battery compartment. The number (for example, 4, 6 or 8) appears after the words "Sky rev" "Sky + rev" or "Sky HD rev".
If you can't find a sticker but received your remote after 2002 (versions 4 and higher) or have a Sky+ or Sky+HD model,
look for your version number by year on the chart offered in Sky's Help Center.
To look up your TV remote control code for versions 4 and higher, use the Remote Control Look up Tool by clicking on "Find your remote control code now" on Sky's web page (see Resources).
Select your remote version and the make/model of your TV from the drop-down menus and then click the "GET MY CODE" button.
The code should then appear in the same window at the bottom in blue.
To find your TV remote control code for versions before 4 or if you can't find a sticker,
look for codes that may work with your remote and TV through SkyUser's Sky Remote TV Code Checker (see Resources).
4 . Point your Sky remote control at your TV and then push the "TV" button on the top of the remote to select the TV for tuning the remote.
5 . Push the red and "Select" buttons at the same time and wait for the red light (red LED) at the top of the remote to flash two times.
6 . Input your three or four digit code. For a three-digit code, enter the code. If the red LED flashes twice,
turn the volume up/down or the TV OFF. If it works, press "Select" to save the code.
For a four-digit code, push the "TV" button, enter the code, wait for the red LED to flash twice and then try to turn OFF your TV using your Sky remote.
If it works, press "Select." If the light doesn't flash twice, try the code a second time. If retrying the code doesn't work, try searching for the code by pressing back-and-forth between the "TV" button and the power button repeatedly until the TV turns off. Press "Select" once the TV turns off. If it doesn't turn off and/or the red LED blinks three times, contact Sky.
Hope the above information will be helpful to you.
Had a great pleasure to assist you.
Thanks.
Posted on Oct 10, 2010
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
How to get my Sony HT-CT60 Sound Bar Home Theater programmed to my GCI Cable remote?
This worked for me, but I have a Comcast Motorola DVD-R:
These are the codes for your SONY SA-CT60 Audio Device. Follow the instructions below to program your remote.
silver_with_red_ok_button-lg.gif Most likely code: 30158
Others to try: 31758, 31759
To program your Comcast remote:
  1. Turn on the TV or other device that you would like to program.
  2. Press the TV button on your remote control.
    NOTE: If you would like to program your remote control to work with a DVD Player, VCR or Audio device press the AUX button.
  3. Press and hold Setup until the red light blinks twice, then release Setup.
  4. Enter the first code for your device listed above. If you perform this procedure correctly, the red light will blink twice.
    NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 4 with a valid code.
  5. Aim the remote control at your device and press Power once (press the Play key for devices that don't have a POWER button). If the TV turns off, make sure that the VOL+/- and Mute buttons also work. If so, you're all set!
  6. If not, repeat these steps using the next manufacturer's code (you may need to try several codes to find the one that works).
Nov 24, 2012 | Sony Audio Players & Recorders
I have a new 8 series LED TV + I got the newly released Samsung soundbar HT-BD8200 and connected them both up. I have wireless + DLNA etc and everything was working fine -- till yesterday -- when i used...
Hi thanks, I got the Samsung customer support desk to assit me and fix the problem.. sorry for the bother -- I thought you were a samsung support site.
Oct 11, 2009 | Samsung Televison & Video
Samsung HT-A100 Home Cinema system plays cd only with tv on!
You need to put away the remote for your TV and use only the remote for your HT system. Your HT remote should work on your TV by default. Your Samsung HT remote should have a TV button and a DVD/Receiver button (or HT button). When using only the TV, press the TV button and then use it for just the TV and when using the HT system, press the DVD/Receiver button and then you can use the HT system.
If for some reason your TV is not set on the Samsung HT remote by default, your HT users manual should have a list of codes that you can use to program your HT remote. Hope that helps you. Gary
Mar 18, 2009 | Samsung HT-A100T Theater System
Unclock code for HT-X810R
Hi there, this code should allow you to unlock your HT-X810. I'm not sure about the HT-X810R specifically, but its worth a shot, let me know if you need any further assistance,
First, turn on the X810 without any disc in the player.
Next, press [Enter][8][4][2][6][9][Enter]
Feb 17, 2009 | Samsung DVD-V4600 DVD Player/VCR
Cannot turn TV off when playing CD's with samsung HT-X810R/LG50PG
Problem traced to Samsung's Anynet+ System interacting with LG's Simplink. They seem to be
compatible. Cured by Menu/Option/Simplink/OFF. Hope this helps with anyone else having this problem. trev6.
Jan 08, 2009 | Sony DAV-S500 System
Using An Onkyo Remote to control Sky+
Code that I have for sky + is: 01175. There are several other codes for other versions of sky boxes if you think you may need them but that should be the one.
Samsung has a huge code list: 10017, 10037, 10047, 10054, 10056, 10060, 10090, 10092, 10093, 10154, 10156, 10178, 10226, 10702, 10766, 10814, 11060, 11235. Unfortunatly you'll just have to try them one at a time until you find one that works. Hope this helps.
Jan 07, 2009 | Onkyo HT-S780 System
Samsung ht tz315 unlock code
i JUST tried the unlock to multi region for my samsung ht-tz315 and it didn't work does anyone have a crack for this please. thks
the code was
Turn On player with remote
Press Enter on the remote
Press 8, 4, 2, 6 and 9 on the remote
The player will power Off
Switch On power from remote
does not work
Aug 01, 2008 | Televison & Video
Samsung program codes for ht-q100 Remote
You can try any of these 006, 011, 014, 015, 019, 027, 036, 037, 077
Hope this helps..
Nov 30, 2007 | Universal Remote Control Activity Based...
Samsung HT-X810R Theater System Logo
223 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
