Question about Pool & Spa
Have a #320 chlorine dispencer installed along with all new equiptment spring 09., worked fine, kept chlorine level right. Now can not get level to only a trace. Dismantled and re-assembled, all looked OK. Removed supply from bottom to top, still low chlorine levels.
    President:
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Have you checked your water for acid levels to ensure you have enough to maintain your chlorine level? Adding stabilizer (cyanuric acid) helps the chlorine remain in the water longer and if you had to replace much of the water since your chlorine levels were OK you need to add more stabilizer to keep the chlorine in the pool. Have you altered the amount of time the pump runs too? An erosion feeder like yours only adds chlorine when the filter system is running. If you have scaled back the amount of time the equipments runs you will also be adding less chlorine over time than you previously had.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Oct 11, 2010
  • fixzum May 13, 2015
    Chlorine tablets do not dissolve properly if they do not have enough water flowing over them, and this is not necessarily the fault of the chlorinator at all. I tried replacing my all my Pentair 320 chlorinator parts - screen, tube, check valve and control valve - and they were not the problem. It was the pool filter! If your pool filter is dirty, or it stays yellow or brown despite regular cleaning, then it will reduce the water flow into to the chlorinator, even to the point where no water gets to the tablets.
    A strong indication that this is happening is that your pool pump is registering 5 psi or more than its usual operating pressure, because it is trying harder to drive the water through the old filter. Treat yourself to a nice brand new filter. I did, and the pump pressure dropped back to normal and water gushed through the chlorinator. After this you can adjust the flow control valve and the number of tablets inside the dispenser to suit your pool's requirements as per its chlorine and pH test results.
  • 1,631 Answers
The chlorine feeder, maybe installed improperly?
Check this...
Turn flow control dial to 0, then remove lid, then turn flow control dial to 5.
Now watch the water fill into the canister. Does it overflow?
If not the pressure is wrong. Or it is plugged. Most commonly at check valve at bottom, and/or the flow control dial.
How long have the tablets been in the feeder?
If there is correct installation, or if all flow is correct, when you remove the lid, you should NOT smell a strong chlorine odor! If there is a strong smell, the water will probably have a yellow tint?
If so, it is either plugged or installed incorrectly.
Do the tablets appear to have melted? Or do they look exactly the same as when they were added? If you do have actual erosion of tablets and you refill frequently, then you need to either add additional tablets maximum up to 10 tabs, or hand feed from another source: Liquid or Granulated. Your chlorine demand is high if that's the case, and you need to meet that demand.
Posted on May 13, 2015
Pentair 320
There is a term out there that is called "chlorine lock". It happens when the cyranuric acid level is excessive. Cyranuric acid (Cya) is also known by the names "conditioner" and "stabilizer".
Although it has not been scientifically verified, many pool pros including myself have run across chlorine lock, although it is very rare. An extensive study was done by Occidental Petroleum back in 1995 that took Cya levels to over 3000 ppm with no unusual effect on pool chemistry. (normal is 30-90 ppm)
However, it cannot be denied that chlorine can remain at high levels for weeks on end during the hottest times of the year with no additional doses.
The 320 chlorinator has been a staple in the industry for decades and has been proven very predictable and reliable.
Have your Cya level checked at a pool supply. If excessive, drain off some water and refill. Chlorine neutralizer is available at any pool supply to alleviate the high chlorine issue very quickly.
Jul 03, 2013 | Pool & Spa
Low reading on salt water pump
Elevate the pump, put in on blocks, then the reading will be higher.
May 05, 2012 | Pentair Pool & Spa
Pentair model 320 pool chlorinator...now filling with high volume from the bottom of the unit in addition to the chlorine control valve on the top. The result is lack of chlorine metering; tablets are...
This issue sounds tricky. I recommend you call the Pentair technical support at 800-693-0971and they should be able to help you figure this issue out. I hope this helps.
Please vote on this answer. Thank you.
Aug 15, 2011 | Pool & Spa
Hello I have a 15x48 intex above ground Easy Set pool and saltwater system. All was working well for about a week and a half. I couldn't get my ph and TA levels right so I brought a sample to my...
I've been running mine for 2 years without checking anything other than the free chlorine level and it's always crystal clear without adding NO CHEMICALS. Make sure you have the correct salt level and start the unit. Take a water sample at the discharge after the chlorinating light comes on and check to see if it measures chlorine. Should be slightly yellow color. If so, your unit is producing free chlorine.
Jul 13, 2011 | Intex Automatic Salt Water System for ...
I have a Pentair 320 automatic chlorine feeder. I have filled it with chlorine tabs, but I am still getting a zero reading for chlorine when I test my pool water. Can it be plugged?
It can be but probably isn't. A three inch tab is meant only to maintain your chlorine level. You must first bring the chlorine level up to specs, by adding either liquid or powdered chlorine, than add one or two tabs a week to hold it at that level.
Jun 13, 2010 | Pool & Spa
Cleaning the inside -Pentair 320 Chlorinator Model R172276
their is a set screw in the side of the chlorinator towards the bottom (you should see a little hole in the side of the chlorinator near the base). remove that screw and the chlorinator will unscrew from the base.
Jul 13, 2009 | Pentair 2.0 Hp Whisperflo Pump
I have a 18ft x 52 intex pool with salt water chlorinator.green
although you may or may not have enough chlorine in your pool you must also realize that a pool need turned over at least 3 times a day.
an example is if you have 7000gl of water and a 2000gph pump you need to filter at least 10 hours or so.
More important than chlorine is the actual circulation of the water you can have all the chlorine in the world but if you do not have the circulation the water will become cloudy or green this also happens when you have no swimmers for days at a time
the filtration time is over and above the chlorine generating time your 4 hours a night for generating chlorine sound like you are guessing sometimes it may be 4 and sometimes 2 or 6
it depends on # of swimmers a day sun and what was in the pool to start
It is important to have a test kit for ph and chlorine and keep chlorine at 1.0to 1.5 now set your ph
ph will rise and fall with your chlorine level one you have them set good at the first time then ph should stay safe enough and re level as chlorine is kept right
also remeber that the wrong ph causes more problems than wrong chlorine levels
Also make sure your salt is no more than 3000ppm and no higher like some people recommend and no lower than 2500 test kits are available for 10 dollars
all of this can be found on intex.com either in a video or pdf files for water capacity and approximate time for generating chlorine.
to be sure always use test kits
Jul 12, 2009 | Intex Automatic Salt Water System for ...
Pentair 320 (inline) clorine not disolving
Three possible solutions, and I have personally made use of all of them with great success.
1. A common reason why the flow of water through the Pentair 320 canister is insufficient to dissolve the chlorine tablets is that the pool filter is dirty or just too old with ingrained sediment. If your pump pressure is continuously running high then this usually indicates a dirty or old filter that is making it difficult for the pump to get an adequate flow of water through the chlorinator. If thoroughly cleaning it makes no difference, treat yourself to a new filter; it's often an immediate fix and the pump pressure drop may amaze you. Old filters that have served their time are deceiving. They may look clean but the fine sediment trapped in their fibers can seriously degrade performance downstream in the chlorinator.
2. Another trick to help SEE what is going on is to replace the short black feeder hose to the Pentair 320 canister with PVC tube, 5/8" outside diameter, 1/2" inside diameter, and a short piece of Pyrex tubing inserted into the middle of the PVC tube to serve as a clear sight glass. PVC tube is rated 100 psi and is readily available at just 50 cents a foot at local hardware stores. Pyrex tube with an outside diameter of 1/2 inch (13 mm) can be bought cut to length for about a dollar per inch from EBay sellers. I also strongly recommend swapping this new feed tube assembly to the UPPER inlet of the chlorinator and moving the plug from there down to the lower inlet. See the attached photo.
You will need an 8 inch and 3 inch length of PVC tube, and a 4 inch length of Pyrex tube. Insert the ends of the Pyrex tube 1/2 inch into each piece of PVC tube with some Goop glue smeared all around the outside of the Pyrex ends. Do not get any Goop inside the Pyrex tube, and do this as quickly as possible, rotating the Pyrex as you insert it into the PVC to ensure that the Goop forms a complete seal. Then let it set, preferably for 24 hours.
Now you have a new feed tube 14 inches long in total, 3 inches of which is the Pyrex sight glass. Just take the unions and spring off the original black hose and transfer them to the new PVC tube, putting the spring on the 8 inch piece of PVC tube. The 3 inch piece of PVC tube should be at the top of the feed where it enters the Pentair control valve.
You will now be able to observe the rate of flow of bubbles in the Pyrex tube (transparent PVC tube soon becomes opaque because of the chlorine but Pyrex remains clear) and know if water is proceeding up the tube and then cascading down over the chlorine tablets. Adjust the Pentair control valve to check if the bubbles speed up and slow down.
3. Lastly, when you open the Pentair 320 to insert new chlorine tablets, the water will normally drain down and out of the canister. IMPORTANT - When you restart the pool pump, keep the cap OFF the canister but have it ready. Assuming you have the Pentair control valve set above 0 (zero) flow, you should soon see water starting to flow through your new PVC feeder tube and then entering and rising up in the canister. When it gets past the top of the chlorine tablets screw the cap on until it feels firm but not cranked hard. If it leaks a little, tighten until that stops. Now you have got rid of that potential air trap that can prevent water rising to completely cover the tablets. Do this EVERY TIME you add new tablets to the canister.80edc77f-aab6-45be-854b-dcd213e89f9c.jpg
Jun 09, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
No chlorine reading
Salt is sodium chloride, you can only measure salt levels now as your CL (cloride) is bound to a NA (sodium). Table salt =NACL, Your Intex system will tell you if your salt level is too high or too low but your old test equipment for free chlorine will continue to tell you no chlorine as it can't react with the chloride any longer as it is bound to the salt. That is why they tell you you never have to add more because the salt stabilizes it. Your chlorine is there it's bound to the salt. Use the pool it's fine and it makes your water feel really soft! Just keep the salt level right and your fine> It's confusing as they call the unit a chlorine generator! I had the same issue, called Intex and they told me the above.
Jun 01, 2009 | Intex Automatic Salt Water System for ...
Pool & Spa Logo
242 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
