Question about Linksys Wireless-G WRT54G Router
Modem working, router is not working - Linksys Wireless-G WRT54G Router
I can't get my Belkin G Wireless router to work with my Clear WiMax modem even after keying in the security key..is this router compatible with this modem?
Any router should work with any modem. Make sure you are running an ethernet cable from the WAN/Uplink port of the router to the modem, or in some cases it will be a USB cable. Also you can test your internet connection by plugging a computer directly into the modem.
Apr 04, 2012 | Belkin Computers & Internet
My new linksys router BEFS41 can't connect to a cable modem that is working. when computer is plugged direct to cable modem it works. Why can't it connect to the router?
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Aug 28, 2010 | Linksys EtherFast Cable/DSL Router
Got a new DSL modem from ISP and now wireless router won't work.
try to contact your ISP make sure you are not violating any rules then try resetting your router and modem check if that works
Mar 17, 2010 | Dynex 4-Port Ethernet Broadband Router...
I just switched from cable modem to dsl modem..dsl modem gets on the internet when connected directly to computer..once connected to router doesnt connect to internet
Your new ISP is DSL. the router was working before with the cable modem. The settings for the cable and DSL ISP are different. Now your computer is working when you connect it directly to the DSL modem. that means the modem is working.
The DSL modem works on 2 different modes.
You will need to check which mode is your modem working on and according to the settings of your modem you will need to set up the router.
To change the settings of the router, you will need to open the set up page of the router.
Click Here for more information about the router set up.
Feb 20, 2010 | Linksys WRT160N Wireless Router
We had to replace our modem & our wireless router isn't working
You have got a new modem. You will need to change the settings of the router according to the new modem.
First make sure that your computer is able to go online when connected directly to the modem. If that works then connect the computer to the router and the modem to the router.
open the set up page of the router and set up the router.
Click here for more info
Nov 28, 2009 | Dynex Wireless-G Broadband Router
Dynex router won't communicate with the modem.
If you connect the modem to the computer, does it go online ?
If your computer is online through the modem, then the modem is working properly.
Check the connections between the modem and the router.
Reset the router for 30 seconds , unplug the power to the router and plug it back in. Wait for 1 minute and set up the router again manually.
Nov 12, 2009 | Dynex DX-E401 Router
I have charter internet with a modem and i have a westell 327w wireless router/modem. How can i connect the two modems to work wirelessly?
I think the Westell Router/modem that you have must be the modem for the DSL connection.
Charter is a cable internet service provider.
You can not use 2 modems connected to each other.
You have a charter modem , you can purchase a wireless router only.
That will work.
Click Here for more info about routers
Oct 27, 2009 | Westell Wirespeed VersaLink...
Connect MSI RG54G2 to speadstream 4200
so that means if you connect the computer to the modem, it works but not with the router.
it seems that the router and the modem are not communicating with each other.
When you connect the computer to the modem , check the IP address through the modem. If ti is private IP address then you will need to change the settigns on the router.
Click Here for more info about networking
Oct 14, 2009 | MSI RG54G2 Router (MS-6848-002)
I dont know what the telephone light means
Are you trying to set up router ?
You can set up your router manually, without the CD.
Apr 14, 2009 | Belkin (F5D5231-4) Router
Speedstream 4100 does not work with router
you can't.
when the item name as modem/router. it means the main function is modem with added router function.
you can't connect 2 router/modem together. both need access to the internet and IPS for it function correctly.
however, you can connect 1 modem and one router.
Oct 19, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Linksys Wireless-G WRT54G Router Logo
484 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
