Question about RCA Televison & Video
I need a wiring diagram of the flyback board and the board straight over top of that board {wire connects from flyback board } to the rear board. i took pics of everything but that 1 wire. board is new and installed but i havent hooked the wiring up yet
SOURCE: Schematic and/or wiring diagram - Magnavox TV Mod 20ms233s
the problem in my tv is the sound no have
Posted on Jul 04, 2008
SOURCE: I am replacing the flyback transformer
The wires don't come off the flyback. You have to take the front cover off where the speakers are. Trace them and unplug them.
Posted on Nov 08, 2008
  • 337 Answers
SOURCE: wiring diagram for 1997 pontiac grand am
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152800bccd7
Posted on Dec 18, 2008
ladywinn
  • 5138 Answers
SOURCE: focus wire from flyback transformer lost position?
Yes, yoke plug in should be next to or behind FBT.
Posted on Dec 22, 2008
gotgeek2
  • 565 Answers
SOURCE: Need the wiring diagram for a Presario sr1010nx motherboard
Here ya go:
http://h10032.www1.hp.com/ctg/Manual/c00225000.pdf
Posted on Feb 07, 2009
Rca 52" 3 light flash not turning on
Check circuit board for bulging at the top capacitors. The board you are looking for is the one with the flyback transformer. This transformer is the one with a thick red wire going to the top of it. Replace all bulging capacitors. Capacitors are the ones that look like little cans. While you are there resolder the bottom solder points on the flyback transformer. This should work, because it worked for me.
Aug 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Getting shadows and color is tinting green and yellow also there is a line across the top of screen
Locate flyback transformer. It's plastic cylindrical-shaped thing with one thin and one thick red High-Voltage wires coming from the top of it. Turn the board it soldered to around and re-solder all of it's connections applying generous amount of solder. Locate three gray-brown colored square shaped parts located right next to flyback transformer. They soldered in a row. It's fuses. Find the open one (or two) and replace them with 0.5A rated.
That should do it.
Russ.
Apr 04, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Removing the HV Wires from Flyback on RCA TV D52W19/
You really dont need it its only a wire.sliice and reconnect.
Feb 18, 2009 | RCA D52W19 52" Rear Projection Television
RCA
The flyback is the big black thing on the deflection board. usally has big red wire coming out the top. THe three small rectangular items are special fusable resistor. or fuses
Sep 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Panasonic PT-53WXD63G Flyback, H.O.T., and Triper
The small wires are disconnected at the focus and screen control block, and the large HV cable is disconnected from the HV splitter.you may have to reuse the large red wire if the new flyback doesnt have the HV lead attached. The Hot is the horizontal output transistor its mounted to a aluminum heat sink near the flyback.
Jul 24, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Flyback 259296
When you remove the rear panel look to the left side of the chassis and you will see the Flyback with the two wires coming out of the top one is a large thick red wire the other is a small wire. You can get a new replacement at the following link under 50.00 which includes free shipping and free support to help you install it by on line instant message with a repair tech.
http://servicemanuals.vstore.ca/
Jun 18, 2008 | RCA D52W19 52" Rear Projection Television
Rca tv
i assume you speaking of the fusable link that causes the convergence problem... IF the convergence option is not visable in the setup menu. then possibley FL231 is the problem this is a small rectangular fuse brown or tan in color. this is located on the deflection board on left of the set from the back. there is a large black component with a large wire coming out of the top. this is the flyback.. to the right of it on the board is three small rectangular componts brown or tan in color. the fl231 is the middle one of these. the curcit board has index markings like a map these components are located in Q5 Quadrant. When replacing this rember to resolder connections on flyback(that large black thing with wire out the top) This is why the fuse blew to begin with
Jun 08, 2008 | RCA P52937 52" Rear Projection Television
Flyback
go to the following link and leave them an email stating your model number and what your needing and they should have the flyback that you need. Its located on the board on the left side and has a large red wire coming out of the top which resembles a spark plug wire. Heres the link.
May 13, 2008 | Sony KP-51WS510 51" Rear Projection...
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
