Question about Kitchen Ranges
MyCulligan MVP Controller water softener wont stop regenerating
  • 21 Answers
SOURCE: resin expelled from water softener during regeneration
this is a problem you have some broken parts inside the tank you need to get this fixed.  you are loosing your resin that is what sofens your water.
Posted on Jun 23, 2009
SOURCE: Culligan medalist softener: Water continues to
Its a most common problem with culligan seal pacs. If your softener is under 5 years old you have the worst softener on the market. Culligan was bought out about 5 years ago by a canada group. they changed every thing and nothing is made in the usa any more. You will have to buy a new one from culligan and pay over 90.00 for it. The old seal pacs lasted 15 years or more now your lucky if you get 2 years.
Posted on Nov 18, 2009
ftw1952
  • 10319 Answers
SOURCE: will not stop regenerating water keeps running
Check the units drain filter. If clogged up it will make this unit run constantly
Posted on Jan 24, 2010
  • 3600 Answers
SOURCE: our water softener regenerated last night...this
sure if it's a reverse osmosis the valve was plugged so when you added salt it slugged the system after being empty. Common problem for this system.
Posted on Feb 15, 2010
  • 569 Answers
SOURCE: Water Softener won't regenerate
mmmm.
I see they charge for a user manual!
I am not familiar with this controller. Is there a manual overide - a large screwdriver slot on the frint of the main shaft?
If so, you should try turning that (clockwise) to the next position and see if the moter will drive it from there. If not, then take it right through 360 degrees, one step at a time.
If it does not work on the next cycle then you may have to replace the controller.
Posted on Feb 20, 2010
Testimonial: "Very helpful, and was quick getting me a possible solution!"
How often should my softener regenerate
the regeneration period is set on the water consumption
after a set amount of water is used , it should regenerate automatically
use quality water filters prior to the softener to remove mud and particles that all affect the regeneration process
regeneration is the process of removing the elements that have been collected in the machine and to replenish the salt content in use
Sep 07, 2017 | Culligan Measuring Tools & Sensors
We add salt but never get soft water....2 years old
try manual regeneration, & turn up salt in take set regenerate to more frequent, check the softness again in a week with a proper tester.
Jul 02, 2015 | Addie Water Systems Metered Water Softener
My water softener has been regenerating for over 8 hours. will not stop. It is a MARK 100 water softener
Try upluging it or turning off the power --it may just need to be rebooted -- I think it is a computer controlled unit?
Feb 14, 2015 | Measuring Tools & Sensors
Will recharge/backwash clean out sediments
You can try several regenerations to see if it helps. But if the well guys did not "by-pass" the softener when working on the well and all that C!!##p got into the softener it is probably toast and either needs to be rebuilt or replaced.
RJH2O
Aug 12, 2014 | Kenmore High-Efficiency Water Softener
Harveys water softener leaking
Actually it is regenerating if it is filling the salt tank with water. It is just not drawing out the water/brine during the brining cycle. Check the eductor assembly it is most likely plugged with iron or debris. Clean thoroughly and manually cycle unit to brine draw. Usually second cycle, until the water level is back to normal then do a manual regeneration from beginning. Then regen 3 consecutive days.
Feb 05, 2014 | Reliance Water Dispensing & Filtration
Sestem is not using up salt and will not flush the lines when it is set up to .
Hi Joey,
There could be several reasons why your softener is not using salt. If it has a Demand Control the turbine that meters the water may be blocked and stuck so the softener doesn't realize that you are using any water, so it won't try to regenerate.
Your injector may be plugged, although this would cause the salt tank to become more full with each regeneration.
If you initiate a manual regeneration and regeneration does not happen you may need to replace the softener.
Knowing what make, model and age of your softener would help greatly in assessing. The best quality softeners last 15 to 18 years unless you have an Autotrol Turbulator in your softener, in which case add 25% more time; 19 to 23 years. There are a few brands that don't seem to last longer than 10 years...
Steve Scott CWS, CI
Sep 03, 2013 | Pentair Water Dispensing & Filtration
Water softener fills up with water
If you are referring to the salt tank filling with water, then the problem is the eductor assembly. This is where the brine is drawn from the salt tank. If it is plugged no brine or very little brine will be drawn during regeneration. You will need to clean the eductor assembly and manually regenerate the softener to regain softened water.
What model softener is it? It would help to bail most of the water out of the salt tank. How much depends on the model.
RJH2O
Jan 26, 2013 | Measuring Tools & Sensors
mmmm.
Feb 20, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
GE SmartWater Softener GNSF35ZO1
I am not familiar with your specific model of softener, but generally speaking, adding water to the brine tank is the last step of the regeneration process. This way the water can soak the salt until the next regeneration is called. Then, as you have determined, the valve does reverse direction and draws the brine solution through the resin.
There are other steps involved in regeneration, like back-washing and packing the resin, but you are mostly correct.
Hope this helps,
Kermit
Aug 15, 2008 | Kitchen Appliances - Others
Kitchen Ranges Logo
111 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
