Question about Gateway Computers & Internet
DOS for gateway laptop model ML6720
Help!!! is there anyway that I can download a DOS onto a blank disc.My son's laptop will not operate in ANY mode. and he as lost the DOS disc
    Brigadier General:
  • 6,966 Answers
Pls try to download boot98se.exe and thereafter it will automatically install itself to a blank diskette. That would then be bootable and usable as a DOS boot disk. If you are running some other Operating System, this page may help you with making a bootable DOS disk.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 31, 2008
Can the gateway ml6720 realtek lan driver be used with the Ml6721?
Probably yes, I would go directly to the Realtek site and download it direct from the source. Use the newest driver.
Jun 04, 2014 | Gateway ML6720 ML6721 ML6725 Keyboard...
I have a gateway kav60 that wont start past the boot menu, it wont start in any mode(safe mode, normal, or safe with prompt). i have nothing hooked up to it, all i did was install new updates from...
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 25, 2012 | Acer Aspire One PC Notebook
I don't have a dell reboot disk or a blank disk to download onto is there anyway to reboot my dell laptop without this
There are actually 2 ways. The first is after you have turn your PC on and while it's trying to reboot press the F8 repeatedly and select Safe Mode. So it means that you will be using Safe Mode to boot up. The other way is to use the OS disc(e.g Windows) that you have.
Sep 13, 2010 | Computers & Internet
I have a gateway ML6720: gets into BIOS OK, but won't BOOT
Upon starting up your computer keep pressing the F8 key. You will see the repair screen come up. Choose the line where you can use the c:/ prompt so you can do the following
When the black DOS screen appears type in chkdsk /f /r
answer Y and reboot
The computer will run a check and repair on your DOS system
When done in a hour or less reboot and see if it will operate correctly.
It is best to have a system reboot disc handy if this happens again. I would create one on a CD if this fixes your problem
Jul 27, 2010 | Gateway Computers & Internet
Hello, I'm trying to update the bios on a Gateway solo 1450 laptop.Ive copied the files to a floppy disc but the computer won't boot with the disc in the drive. The message insists I remove any discs from...
you need to make a boot disk then copy the bios files onto the disk if you can not make a boot disk you can go to bootdisk.com and there you can find the correct boot disk for your OS.
Oct 30, 2009 | Computers & Internet
Y Daughter Has a gateway laptop model ML6720 which the fan has been seemingly noisy but I just noticed I don't think it is going on .What should I do and what harm can be done
This is the CPU cooling fan.
Take it to a repair shop. Laptops cannot been worked on easily.
Without the cooling fan, the CPU will eventually die and make take the hard drive with it.
Aug 09, 2009 | Gateway 506GR PC Desktop
I am trying to install software onto my MAC OSX and it will not work. Says cannot operate in DOS mode. I do not know what to do. The UM175 says Mac OSX compatible. Help!
I know sounds dumb but it appears your putting the wrong disc in the drive. Kind of the same error if you try to install a windows file.
Plug and play and update.
Mar 22, 2009 | Computers & Internet
Dos mode
to reformat, you have to boot from another source like a CD. you can't reformat a drive while it's being used, so get yourself an operating system disc and you can reformat/reinstall.
Jan 17, 2009 | IBM ThinkPad T21 Notebook
Computers & Internet Logo
104 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
